Revizia de 120.000 km. Sfaturi, va rog!
Mesajde Kugarth » 05 Apr 2007, 19:09
Miercuri dimineata sunt programat la service-ul de la reprezentanta Ford din Craiova pentru revizia de 120.000 km. Din cate am citit pe aici, personalul din service-urile din toata tzara este cam varza. Va rog sa-mi spuneti si mie (din experienta proprie sau chiar din auzite) cam la ce ar trebui sa ma astept de la ei si mai ales la ce ar trebui sa fiu mai atent.
"Il Toro"
Inscrie-te in grupul ClubFord Craiova pentru a primi prin PM (private message) mesajele importante.
Kugarth
Localitate: Craiova
Maşina: Mondeo 2004, TDCI, 2L, 133 CP, Ghia
VIN: ____PinotNoir____
Mesajde adispan » 05 Apr 2007, 22:55
uite ce am gasit intrun Haynes referitor la revizia de 60,000 mile (aprox 100,000 km), pt modelele facute pana in 1997
Check the electrical system
Check the battery
Check the seat belts
Check the auxiliary drivebelt
Check for fluid leaks and hose condition
Check the condition of all wiring
Check all air conditioning components
Change the engine oil and filter
Check the manual transmission oil level
Check the adjustment of the clutch pedal
Lubricate the automatic transmission linkage
Check the steering, suspension and wheels
Check the driveshaft gaiters and CV joints
Check the exhaust system
Check the underbody, and all fuel/brake lines
Check the brake system
Check and lubricate the doors and bonnet
Check the security of all roadwheel nuts
Road test. Check the level of the automatic
transmission fluid with the engine still hot, after the road test
Renew the ventilation system pollen filter
Renew the coolant
Renew the air filter element. Note that this task must be carried out at more frequent intervals if the vehicle is used in dusty or polluted conditions
Check the Positive Crankcase Ventilation (PCV) system, and clean the filter
Renew the spark plugs
Renew the timing belt
Renew the fuel filter
Renew the brake fluid
adispan
VIN: WF03XXGCD36M19528
Mesajde Kugarth » 06 Apr 2007, 09:29
Presupun ca la terminarea reviziei, cand ma duc sa iau masina, mi se prezinta o foaie cu ce s-a schimbat, verificat, etc
Tinand cont ca eu nu stau langa ei (as vrea eu dar nu cred ca ma lasa) atat timp cat ei umbla pe la ea, ce pot face sa ma asigur ca ei chiar au schimbat, verificat pe acolo?
Si repet intrebarea initiala: cam la ce ar trebui sa ma astept de la ei si mai ales la ce ar trebui sa fiu mai atent?
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde vctoras » 10 Apr 2007, 11:42
$1 scrie:$2resupun ca la terminarea reviziei, cand ma duc sa iau masina, mi se prezinta o foaie cu ce s-a schimbat, verificat, etc
Am fost anul trecut la ei pentru un test pe calculator si mi-au placut.Au fost foarte amabili si aveau un tester foarte bun.M-au lasat sa stau langa masina si mecanicul mi-a explicat ce probleme aveam si ce se poate intampla daca nu le remediez.Chiar mi-au trecut la manopera mai putin decat era normal pentru ca le-am spus ca este scump si nu vroiam sa intru.
Ford Focus 1.8TDDI 90Cp,2000
vctoras
Localitate: Motru
VIN: WF0NXXGCDNYL74053
Mesajde Kugarth » 11 Apr 2007, 22:05
Am fost ... a fost acceptabil, am putut sta langa masina o perioada (cand au pus-o pe calculator) ... toata distractia a costat 990 ron ...
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde vctoras » 12 Apr 2007, 07:39
$1 scrie:$2m fost ... a fost acceptabil, am putut sta langa masina o perioada (cand au pus-o pe calculator) ... toata distractia a costat 990 ron ...
De ce "acceptabil"si ce au schimbat de au ajuns la 990lei?
vctoras
Localitate: Motru
Mesajde Kugarth » 12 Apr 2007, 12:28
Doar acceptabil si nu bine (sau rau) pentru ca:
- nu am vazut masina la inceput (au dus-o intr-o hala din spate). Partea buna este ca nu s-au plimbat cu ea, nu au zgariat-o sau altceva din ce am citit pe aici pe forum ca se poate intampla.
- au vorbit frumos, s-au miscat destul de repejor (2 ore), m-au lasat sa stau langa masina cand au adus-o in hala principala.
- nu-mi place ca nu am garantia ca ei chiar au schimbat ceva pe acolo :D
- nu-mi place ca aveau cafeaua de la tonomat pe bani :D (la autovit era moca :) )
Uite lista cu ce au facut exact:
PlusAuto
(143.48 KiB) Descărcat de 324 ori
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde verga_Cip » 12 Apr 2007, 12:59
Filtrul de ulei e acceptabil... celelalte filtre e inadmisibil... moaama ce preturi!
Hmm.... ulei texaco... ciudata alegere.
In rest e ok. Acum, nu e mult 10 milioane ... mi se pare cat de cat rezonabil.
Daca tineai neaparat, jumatate ii castigai daca faceai tu operatiunea.
Eu am schimbat uleiul aseara, am verificat electromotorul si cureaua de distributie si m-a costat 30 RON.
Filtrele de motorina si aer le-am schimbat eu. Filtrele la mine au costat 150 RON.
Ma surprinde ca nu a verificat cureaua de accesorii.. .sau trebuia sa mentionezi tu?!!? macar verificare.. cred eu.
Bafta
Mesajde vctoras » 12 Apr 2007, 13:05
Multumesc.Au scris ca se recomanda curatarea supapei EGR.Ai intrebat daca este scump sau ceva despre asta, probabil este vorba despre o substanta de curatat.
vctoras
Localitate: Motru
Mesajde Officer » 12 Apr 2007, 13:43
Cam ca peste tot...se scot si ei la consumabile...masina e buna :)
Officer
Elodia
Localitate: Ilfov
Maşina: Nu mai am ford :(
Mesajde Kugarth » 12 Apr 2007, 15:09
$1 scrie:$2ultumesc.Au scris ca se recomanda curatarea supapei EGR.Ai intrebat daca este scump sau ceva despre asta, probabil este vorba despre o substanta de curatat.
Curatarea supapei costa 200 ron ... la ei :)
2 discuri + placutele de frana, 1100 ron!!! (350 ron/disc + 350 ron placutele) + manopera ... chiar sare de 1100 ron ...
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde Officer » 12 Apr 2007, 15:30
discurile si placutele sunt la dublu fata de preturile de la ford_mazda si for car
Officer
Elodia
Localitate: Ilfov
Mesajde catanea » 12 Apr 2007, 18:08
@Kugarth De ce ti-au pus TExaco ? asa ai cerut tu ? daca nu ai cerut macar te-au intrebat de care sa-ti puna ?
Este peste puterile mele sa inteleg de ce un service autorizat Ford nu promoiveaza, asa cum e normal, produse de origine, in speta uleiul Ford 5W30.....
Of, of ...mai mai
Fusion 2006, 1.4 TDCi, 68 CP
catanea
Mesajde Kugarth » 12 Apr 2007, 21:05
$1 scrie:$2Kugarth De ce ti-au pus TExaco ? asa ai cerut tu ? daca nu ai cerut macar te-au intrebat de care sa-ti puna ?
Of, of ...mai mai
M-au intrebat: texaco la 38+tva sau mobil (parca) la aproape 50 + tva. Tinand cont ca-l shimb la 10.000 ... am ales o varianta ceva mai ieftina.
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde catanea » 12 Apr 2007, 21:38
Tot n-am inteles, ulei Ford nu aveau ?
catanea
Mesajde Kugarth » 12 Apr 2007, 23:54
$1 scrie:$2ot n-am inteles, ulei Ford nu aveau ?
Nu stiu daca aveau sau nu. Presupun totusi ca ma intrebau daca aveau. A venit cel care mi-a facut receptia la masina si m-a intrebat de care ulei sa puna: texaco la 38+tva sau mobil la aproape 50 + tva. Asta a fost tot ... nu a pomenit nimic de ulei Ford!
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde vctoras » 13 Apr 2007, 06:20
Ford nu produce ulei.Cand am intrebat la FORCARdespre producatorul acestui ulei mi-au spus ca nu stiu cine il produce si ca il importa din Germania.Probabil prefera un ulei cu norma Ford.
vctoras
Localitate: Motru
Mesajde verga_Cip » 13 Apr 2007, 07:59
Deviem subiectul dar e spre bine cred. Daca Ford recomanda Aral sau Mobil ... de ce se pune Texaco?!? uite sunt curios daca pe cutie scrie specificatia FORD.
Mesajde Kugarth » 13 Apr 2007, 08:54
$1 scrie:$2eviem subiectul dar e spre bine cred. Daca Ford recomanda Aral sau Mobil ... de ce se pune Texaco?!? uite sunt curios daca pe cutie scrie specificatia FORD.
Asta nu mai stiu ca nu am vazut cutia. Defapt nu am vazut nimic ... nici nu am siguranta ca au schimbat filtrele ... cred ca o sa le desfac sa ma uit la ele ...
"Il Toro"
Kugarth
Localitate: Craiova
Mesajde Mihai L » 13 Apr 2007, 09:33
Catanea se pare ca are dreptate: pe http://www.ford.ro se recomanda uleiul Ford Formula E 5W - 30, care printre altele este chiar la promotie.
http://www.ford.ro/index,31,550
LE: Pe langa asta se recomanda si utilizarea in exclusivitate a pieselor originale - http://www.ford.ro/index,31,548
Doua scurte citate, foarte interesante:
Brandul Ford
Cereti intotdeauna sa vedeti ambalajul original Ford si verificati prezenta ovalului Ford pe produs.
Distributia pieselor
- Siguranta utilizarii de piese originale este asigurata numai in cazul achizitionarii produselor prin intermediul partenerilor oficiali ai retelei de distributie Ford.
- In cazul eventualelor nelamuriri in ceea ce priveste originea pieselor achizitionate te rugam sa contactezi Romcar, unic importator autorizat pentru Romania, la adresa de email: relatii.clienti@ford.ro
