Statie auto Kenwood 9152D+Condensator Power Acoustick 1.5F
Mesajde KnupZ » 23 Noi 2007, 14:28
KAC-9152D main features:
1,800 Watts max power
500 Watts x 1 max (4 ohms) RMS
900 Watts x 1 (2 ohms) RMS
900 Watts x 1 (1 ohms) RMS
Wired remote control to adjust boost level and frequency included
'Dual mono drive' configuration option (requires two KAC-9152D amplifiers & specialist knowledge!)
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct) to cut unwanted ultra-low frequencies
'Kenwood logo triangle' design power indicator LED
1 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Power MOSFET switching power supply
'D' class amplification circuits throughout, using switching techniques instead of the linear methods used in Class 'A' or 'B' type amplifiers. Class 'D' is a significantly more efficient than Class 'A' or 'B', resulting in greater power with less heat generation, higher stability and improved reliability
2 x 30 amp power supply fuses
Dimensions (WxHxD) : 380 x 61 x 286 mm
Complete with full fitting and operating guide
Power Acoustik
* Digital Power Capacitor
* 1.5 Farad
* 24 Volts DC
* Digital Display
* Brilliant Silver Aluminized
* Mounting Brackets
* Double Clamp Blister Packaging
Ambele sunt in stare foarte buna,aduse de mine personal din state.
Condensatorul 50 eu
Statia 230 eu
Ambele 270 eu
tel, 0722640539
(245.4 KiB) Descărcat de 311 ori
(35.4 KiB) Descărcat de 311 ori
KnupZ
owned
Mesajde KnupZ » 29 Noi 2007, 04:53
mai scadem 5 euro de la fiecare :lol:
KnupZ
owned
Mesajde Maddogul » 29 Noi 2007, 15:19
Condensatorul de 1.2 Farad :D
Oricum bun pretz
Cu Stima
Mondeo MK2 '98 2.0 130Cp '97
Maddog Garage
Maddogul
Maşina: Fiesta Mk5 1.7 VCT
VIN: WF0FXXGAGFRA56025
Mesajde KnupZ » 29 Noi 2007, 19:04
la specificati scrie 1.5f pe el e scris 1.2f iar in functiune pe afisajul digital arata 1.4f deci... cam tot aia e :)
KnupZ
owned
Mesajde KnupZ » 02 Dec 2007, 19:07
inca 5 eu mai scadem :D
KnupZ
owned
Mesajde Cosmin. » 09 Ian 2008, 04:57
Pana la urma cat scoate la 4 ohm in RMS? Sau e 500W RMS? Nu de alta, dar ma bulverseaza "max" ala scris acolo :)
Cosmin.
Localitate: UK
Mesajde KnupZ » 09 Ian 2008, 13:48
500 rms in 4 ohm :)
KnupZ
owned
Mesajde vidanjoru » 09 Ian 2008, 17:19
Îmi poţi explica şi mie ce face condensatorul ăla exact??
Mondeo 2007, 2.0 TDCi, 140CP, Titanium X, 4uşi, Stardust Silver
Alfa Romeo 147, 2.0 Twin Spark Selespeed, 150CP, 5uşi, rosso alfa
Sic vis pacem, para bellum.
vidanjoru
Localitate: Galaţi
