Timp Liber
AUTOMODELISM
Include si Hobby :D
Mesajde Cosmin. » 24 Dec 2007, 17:25
Sunt destul de rapide, a mea prinde in jur de 25km/h :)
On the other hand, sunt unele cu motoare cu ardere interna care fac 0-60km/h in 2-3 secunde :lol:
Cosmin.
Localitate: UK
Mesajde Trancer » 24 Dec 2007, 23:24
vreau si eu una poate bate un logan ceva :P
Trancer
Localitate: BrasoV
Maşina: Ford Focus II 2007 1.8 TDCi Trend ChampionsLeague kiT ST + Navi
VIN: WF05XXWPD57L69879
Mesajde Cosmin. » 25 Dec 2007, 01:07
http://www.redrockethobbies.com/Product ... =TechSpecs
Uite aci. Erau mai multe. BTW. Alea sunt mile pe ora :lol: :lol: :lol:
$1 scrie:$2eatures
* Machined aluminum front rims for precision straight runs
* Thin rubber front tires for precise steering
* Authentic rail front end system with adjustable ride height
* Rail cup tie rod steering system
* 100cc fuel tank for multiple run capability
* Sealed radio box protects electronics from any impact
* Custom tuned exhaust system for top RPM speed
* High traction mounted and trued foam tires for the lowest estimated time
* Fully adjustable rear ride height for low clearance runs
* Fully functional and adjustable rear spoiler
* Front spoiler to enhance traction
* 2 speed transmission for best off the line and top speed
* T6 lightweight aluminum chassis for proper flexibility and traction
* Cantered steering system for exact straight line runs
* Custom painted and trimmed body
Cosmin.
Localitate: UK
Mesajde papi » 25 Dec 2007, 01:26
eu am gasit masinute de genu asta in metro care prindeau 15km/h dasta am intrebat
Sunt un DOMN nu calc babe si nu conduc beat.
papi
Mesajde Trancer » 25 Dec 2007, 01:32
alea de metro sunt cam praf :P am si eu un nissan 350z dar nu e stralucit e asa de fun insa astea sunt smekerie rau
Trancer
Localitate: BrasoV
Mesajde Cosmin. » 25 Dec 2007, 01:41
Si motorasele electrice sunt diferite ca performante. Oricum, poti sa adaugi ceva gen supraalimentare daca stii ceva electronica, ba chiar si un boost gen NOS, dar exista riscul sa prajesti motorul. Ca in realitate :lol:
Cosmin.
Localitate: UK
Mesajde VIPER » 25 Dec 2007, 15:36
Nu faceti mai bine un topic separat? Am si masini termice acasa (1/8 si 1/10), si vreo 2 electrice de competitie 1/10, deci hai sa facem topic separat...
VIPER
Localitate: Bucuresti, RO
Mesajde Cosmin. » 25 Dec 2007, 16:52
Pai e nevoie de un moderator sa ia ce este pe aici si sa lipeasca intr-un nou topic. Eu sunt de acord. Ba chiar am si un Skyline R32 dupa looks, dar este motorul decedat iar telecomanda este bucati si as avea nevoie de niste sfaturi.
Hai cu split-ul :D
Cosmin.
Localitate: UK
Mesajde VIPER » 25 Dec 2007, 18:49
OK, am facut topic separat.
Acum cativa ani m-a rugat un amic sa-i fac un articol despre automodelism, pentru a fi publicat intr-o revista auto. Avand in vedere ca este al meu, il scriu si aici. Va reamintesc, este scris acum 3 ani. Nu dati cu pietre, asa a aparut si in revista.
"O sa incep cu o prezentare pe care am facut-o pentru o firma importatoare din Romania (nu dau nume sa nu fie probleme) si care sper sa apara curand si publicata intr-o revista auto (AUTOMONDIAL numarul 86 - Mai 2004):
In ultima vreme cuvantul automodelism s-a facut auzit din ce in ce mai des. Mai intai hai sa vedem care este diferenta intre un automodel si o masinuta cu radiocomanda asa cum o stiam cu totii…
Masinutele cu radiocomanda, cele pe care le vedem in orice magazin, sunt doar niste jucarii. Sunt foarte simplu de comandat la distanta, miscarile lor sunt destul de bruste – virajul stanga sau dreapta se face sub un singur unghi, iar acceleratia are o singura pozitie, viteza maxima inainte, sau maxim inapoi. Caroseriile sunt din plastic dur, rotile au “pneuri” din plastic, viteza maxima de deplasare intre 10-12km/h.
Automodelele au depasit stadiul de jucarie. Majoritatea chiar prezinta in instructiuni avertismentul: interzis copiilor sub 14 ani! Principala diferenta intre un automodel si o masinuta radiocomandata este comanda proportionala: pe scurt si simplu spus, automodelul raspunde la comenzile de directie si acceleratie/frana exact cat se comanda din statie. Ii dam comanda “putin stanga”, rotile se rotesc “putin stanga”, nu total ca la jucarii. Acceleratia este de asemenea progresiva, ca la un autoturism normal. Caroseriile automodelelor sunt in general din lexan, un material rezistent la socuri dar deformabil, facut sa apere componentele interne. Gasim multe asemanari intre un automodel si un autoturism: amortizoare, diferentiale, planetare, bascule, etc.
Automodelele se impart in 2 mari categorii: cu motor termic si cu motor electric. Cele cu motor termic folosesc un combustibil compus din alcool metilic (metanol, ATENTIE, este otravitor!!!), ulei de ricin si, in functie de necesitate, intre 5 si 30% nitrometan. Motoarele termice sunt in 2 timpi, au 1 cilindru cu piston, iar aprinderea se face cu o bujie incandescenta. Au capacitati cilindrice de 2.11cm3, 2.5cm3, 3.5cm3, 4.1cm3 si chiar mai mari. Puterea motoarelor pleaca de la 0.5CP si poate ajunge la peste 3CP, la turatii cuprinse intre 18000 si peste 45000 rpm! De aceea vitezele maxime pot depasi 60-80km/h! Acceleratia de la 0 la 100km/h se face, la modelele de varf, in 1.5 secunde!!!
Automodelele cu motor electric sunt alimentate cu acumulatori de capacitate mare, alesi special sa reziste la solicitarile extreme ale motoarelor electrice folosite. Acestea pot ajunge si ele la 40000rpm rezultand viteze ale automodelelor de peste 60-80km/h!
Un punct comun al automodelelor termice si electrice este modalitatea in care primesc si executa comenzile de la distanta: receptorul radiocomenzii (amplasat pe automodel) trimite informatia primita catre niste servomecanisme care vor actiona directia (la ambele tipuri de automodele) si acceleratia/frana (la cele termice, la cele electrice apare un variator electronic de turatie care se ocupa de partea de acceleratie/frana).
Am mai putea imparti automodelele si in functie de terenul pe care alearga: off-road (cele care alearag pe teren accidentat – nisip, noroi, iarba, zapada) si on-road (cele care alearga pe piste special amenajate, pe asfalt, pe mocheta).
Automodelismul poate fi impartit in 2 "ramuri": hobby si sport. Partea de hobby e destul de clara: iti iei un automodel doar pentru distractie, eventual curse si intreceri prietenesti. In acest caz nu conteaza foarte mult calitatea automodelului, se pune mai mult accent pe caroserie, pe destinatia automodelului, pe pret.
La partea de sport se schimba radical datele problemei... Aici conteaza totul, de la pneuri la motoare de ultima generatie!
Hai sa vedem care sunt tipurile generale de automodele, apoi cele inscrise in competitiile sportive:
Automodele cu motor termic:
- off-road: scara 1:4, 1:5, 1:6, 1:8, 1:10. Motoare de la 2cm3 in sus. Tipuri de automodele: monster-truck, buggy, stadium-truck, rally (ultimul poate fi transformat si in on-road cu mici modificari). Pot fi cu tractiune pe 2 sau pe 4 roti.
- on-road: scara 1:4, 1:5, 1:8, 1:10. Motoare la fel. Tipuri: dedicate pentru pista sau pentru orice teren plan.
La scara 1:4 si 1:5 avem automodele mai speciale, foarte apropiate de cele reale, cu motoare alimentate cu benzina, aprindere cu scanteie, frane cu disc pe fiecare roata.
Automodele cu motor electric:
- off-road: scara 1:8, 1:10, 1:18, 1:24. Tipuri de automodele: monster-truck, buggy, stadium-truck, rally. Tractiune 2WD sau 4WD.
- on-road: scara 1:8, 1:10, 1:12, 1:18, 1:24. Tractiune 2WD sau 4WD.
Automodelismul ca sport
Romania este afiliata la EFRA - European Federation of Radiooperated Model Automobiles ( http://www.efra.se ). Clasele de concurs in Romania sunt:
a. Automodele de viteza (captive), clasele A-1,2,3,4,5 seniori, B1,2 juniori si B-3 seniori.
b. Automodele radiocomandate cu motoare termice, clasele 1/8 Track 2WD (Sport/Gr.C) si 4WD (Sport/Gr.C), seniori si juniori, 1/10 I.C. Track (200mm + 235mm) seniori.
c. Automodele radiocomandate cu motoare electrice, clasele 1/12 Track si EB, 1/10 Track (Sport/Gr.C), 1/10 Off-road 2WD si 4WD, seniori si juniori si 1/10 Touring Car seniori."
VIPER
Re: AUTOMODELISM
Mesajde Cosmin. » 16 Mai 2008, 07:12
Reinviu topicul. La noi in tara nu exista magazin online pentru radiomodele? Si aici ma refer nu numai la automodele, cat si la elicopterase, avionase, barcute, etc :D
LE: gasit http://www.radiomodele.ro/shop/
Stiti ceva de ei? Mi-a atras atentia radiomodelul de drift :D :D
Cosmin.
Localitate: UK
Re: AUTOMODELISM
Mesajde Officer » 16 Mai 2008, 09:51
Ca scump hobby-ul asta. O turbina de jucarie din asta e cat una de camion ;;) http://www.radiomodele.ro/shop/index.ph ... ucts_id=10
Officer
Elodia
Localitate: Ilfov
Maşina: Nu mai am ford :(
Re: AUTOMODELISM
Mesajde VIPER » 16 Mai 2008, 11:19
$1 scrie:$2einviu topicul. La noi in tara nu exista magazin online pentru radiomodele? Si aici ma refer nu numai la automodele, cat si la elicopterase, avionase, barcute, etc :D
Nu te arunca la primul magazin ca sunt destule si inca au ceva vechime:
http://www.sierra.ro
http://www.phoenixmodels.ro
http://www.autoart.ro la sectiunea automodele (preturi crima!)
http://www.aeromodelism.com
http://www.azmodels.ro
VIPER
Re: AUTOMODELISM
Mesajde buggyracing » 07 Feb 2009, 17:04
as mai adauga si alt magazin:
http://www.ole.ro
... doar pentru automodele
buggyracing
Maşina: buggy
Re: AUTOMODELISM
Mesajde Darth-Claudiu » 07 Feb 2009, 19:35
http://www.cooltoys.ro/ (are si filmulete la fiecare produs).
HPi Savage XL 5.9 RTR - mai lasa omul si la pret...dar mai bine bag banutii intr-o pereche de schiuri adevarate, ca daca mai pun la socoteala si piesele, combustibilul, etc ajung sa bag in masinuta asta mai multi bani decat in Focus...Nu stiu daca vine cu telecomanda aia smechera care-si schimba singura frecventele in cazul in care interfereaza cu altceva dar m-a dat pe spate genul asta de jucarie cand a venit un coleg cu ea la serviciu.
PS: Am vazut anuntul lui Viper cu masinutele electrice si eram ferm convins ca-i vine manusa topicul asta :D . Viper are junior, eu nu, asa ca daca e sa fie, va fi una mare si rea...ca pentru baieti mari...
Regret nothing. Fear less.
Buy Romanian! Save your job!
Darth-Claudiu
Re: AUTOMODELISM
Mesajde buggyracing » 15 Mar 2009, 13:58
nu e chiar asa de scump hobby-ul ...
au scris candva in Evenimentul zilei despre automodelism si m-am speriat cand am auzit "hobby de mii de euro" :D
buggyracing
Maşina: buggy
Re: AUTOMODELISM
Mesajde radiomodele » 18 Iun 2009, 00:00
Salut
Eu sunt inculpatul de la cateva posturi mai sus (de anul trecut, adica). http://www.radiomodele.ro este site-ul meu si daca doriti detalii va rog nu ezitati sa ma contactati. Discutam de la detalii tehnice pana la cele despre preturi.
Prefer asa decat sa citesc de unii si altii ba ca lasa la pret, ba ca sunt seriosi... sau putem discuta aici desi nu stiu daca este cel mai potrivit loc :)
Daca postul nu-si are locul aici, rog moderatorii sa il mute/stearga, eu mi-am facut datoria sa incerc.
Multumesc si va astept cu interes.
radiomodele
Maşina: Fiesta
Re: AUTOMODELISM
Mesajde shine » 18 Iun 2009, 07:23
intamplarea face ca acum cateva seri la o intalnire nocturna, unul dintre automodelele care se invarteau pe la Piata Constitutiei sa sfarseasca destul de urat sub o Skoda Octavia :(
shine
Membru reincarnat
VIN: EuPreferDemisecul
Re: AUTOMODELISM
Mesajde VIPER » 18 Iun 2009, 11:56
Un automodel nu e tocmai simplu de condus, mai ales daca e mai performant... E ca la masinile "mari"...
VIPER
Re: AUTOMODELISM
Mesajde KomandantuR » 18 Iun 2009, 13:09
E mult mai greu decat la masinile mari (cel putin pt mine). Adica in "masina mare" stai tot timpul cu fata, stanga-i stanga, dreapta e dreapta. Dar cand "aia mica" vine spre tine trebuie sa inversezi rapid in subconstient comenzile. Si sunt asa de virajate circuitele alea... :D
KomandantuR
VIN: WF05XXGCD57L20779
Re: AUTOMODELISM
Mesajde viperasp » 21 Iun 2009, 09:55
Mai adaugati la lista un site cu preturi bune ... RCW
viperasp
Maşina: Ford Ka '02
Re: AUTOMODELISM
Mesajde radiomodele » 22 Iul 2009, 13:49
Pentru cei interesati, am deschis si o sectiune de fotografii ale produselor livrate de magazinul radiomodele pe flickr
radiomodele
Maşina: Fiesta
Re: AUTOMODELISM
Mesajde irsido » 31 Iul 2009, 13:52
Pentru cei pasionati de aceste jucarii, de o saptamana s-a deschis in parcul Tineretului, in spatele Palatului copiilor o pista foarte frumos amenajata unde puteti tura motarasele. In weekendul trecut erau cativa pasionati care se invarteau pe acolo.
Intradevar, sunt foarte frumoase masinutele si se merita ca hobby.
Mondeo Mk4 2.0i
irsido
Maşina: Mondeo Mk4 2.0i
Re: AUTOMODELISM
Mesajde forbidden27 » 27 Aug 2009, 13:11
Proudly owner al unui monster-truck Thunder Tiger MTA4. Este intradevar o "jucarie" pe care cu greu o lasi din mana. Problema este ca necesita ceva investitie, sunt destul de scumpe, de asemenea, piesele de schimb si consumabilele sunt cam scumpe. Motorul termic necesita ceva cunostinte, timp si nervi consumati pana ajungi la niste reglaje bune. Combustibilul este de asemenea la un pret destul de mare si trebuie avut grija in alegerea lui. Piese de schimb se gasesc cam greu in Romania, sunt magazine care aduc la comanda, timpul de livrare fiind destul de mare. In schimb, satisfactiile sunt foarte mari. In fiecare zi, la fiecare iesire o sa observati ca poate si mai mult. Am facut liniuta cu Mondeo al fratelui meu, il rup pe 200 metri. Trebuie avut mare grija cu ele, de obicei strange foarte multi admiratori, in special copii. Exista riscul de a lovi pe cineva, cu consecinte destul de neplacute. Are in jur de 5,5 Kg si atinge viteze de 65-70 km/h.
Recomand celor ce doresc sa achizitioneze asa ceva, firmele HPI, Thunder Tiger si Kyosho. Sunt si modele mai ieftine pe piata, de obicei chinezarii cu viata scurta si modele foarte performante, cu preturi pe masura (>1000E).
Film cu monstruletul in semnatura mea.
Modelul a fost achizitionat de la http://www.modelmaniac.ro.
-Thunder Tiger MTA-4
-Losi XXL2
forbidden27
Localitate: Slobozia
VIN: WF0DXXGBBD8G04304
Re: AUTOMODELISM
Mesajde VIPER » 27 Aug 2009, 13:19
Tamiya, Mugen, X-Ray, Traxxas, Duratrax, Hot Bodies si ar mai fi destule nume grele in domeniu ;)
VIPER
Înapoi la Timp Liber
