Vand amplificatoare auto diverse marci
Re: Vand amplificatoare auto diverse marci
Mesajde adryan12 » 17 Mar 2012, 17:09
Preturi noi
PIONEER GM3400: - 130 ron
4x80W
MAGNAT CLASSIC 360 - 150 RON
4x90w / 2X90W+1X180W / 2X180W
Raspuns in frecventa: 5Hz ~ 50kHz
Sigurante: 2 x 25A
Dimensiuni: 402 x 254 x 54mm
Greutate: 4.5 kg
REXCEL KB 905 - 140 RON
4X100W
RAINBOW RL 2070: 100 ron
Mosfet, poate fi legat in punte,
2 x 70 W RMS
DRAGSTER DB 405 140 ron
4 x 50 w RMS 4 ohm
4 X 90 w RMS 2 ohm
Amplificator auto XXL AMP 444 140 ron
4 CHANNEL : 4x175 WATT ( 4x80 WATT RMS )
3- CHANNEL : 2x175 WATT + 1x350 WATT ( 2x 80 WATT + 1x160 WATT RMS )
2- CHANNEL : 2x350 WATT (2x160 WATT RMS )
Tel 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 23 Mar 2012, 09:49
Valabile in continuare, la care se mai adauga:
Amplificator auto COUGAR C500.4 - 150 ron
Putere maxima 4 x 400
Putere RMS 4 x 95W RMS
Posibilitatea de a se conecta in 4 ,3 , 2 canale
Bass Boost (6, 12 dB).
Toate amplificatoarele sunt in perfecta stare de functionare.
adryan12
Maşina: Seat
Mesajde adryan12 » 31 Mar 2012, 19:13
MAGNAT CLASSIC 360 Vandut
RAINBOW RL 2070 Vandut
Valabile
4x80W
4X100W
DRAGSTER DB 405 - 140 ron
4 x 50 w RMS 4 ohm
4 X 90 w RMS 2 ohm
XXL AMP 444 - 140 ron
WECONIC VX 4200 - 160 ron
4 x 50Wrms @ 4 ohm
2 x 120Wrms @ 4 ohm
Filtru canal 1/2 LPF
Filtru canal 3/4 HPF
High-Level-Input
Greutate 4,5 kg
adryan12
Maşina: Seat
Mesajde adryan12 » 07 Apr 2012, 20:51
DRAGSTER DB 405 - Vandut
Se mai adauga la vanzare
IMPACT LK454 - 200 ron
Power RMS (4 Ohms) 75W x 4
tri mode operation
Bass Boost (Variable) 0~ +18dB
High Pass Crossover 100Hz
Low Pass Crossover (Variable) Continuously Variable 35Hz ~ 155Hz
Bridged (4 Ohms) Power 250W x 2
adryan12
Maşina: Seat
Mesajde adryan12 » 08 Apr 2012, 12:32
4x80W
4X100W
4 x 50Wrms @ 4 ohm
2 x 120Wrms @ 4 ohm
High-Level-Input
Greutate 4,5 kg
tri mode operation
Audison LR72 - 170 ron
MAX DYNAMIC POWER (2 Ch x 4 Ohms) 75 W
MAX DYNAMIC POWER (1 Ch x 4 Ohms) Bridge 225 W
CONT. NOMINAL POWER (Tol. +10%; -5%)
2 Ch x 4 Ohms; 0.3% THD; 12 VDC 45 W (RMS)
CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 50 W (RMS)
CONT. OUT POWER (2 Ch x 2 Ohms; 13.8 VDC) 75 W (RMS)
MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 150 W (RMS)
DISTORTION THD (1 KHz; 90% Nominal Pwr) 0.07 %
BANDWIDTH (-3 dB; Nominal Pwr) 4 Hz ÷ 100 KHz
DAMPING FACTOR (4 Ohms) 150
RISE TIME 4.5 μS
SIGNAL / NOISE RATIO 98 dBA
INPUT SENSITIVITY 0.3 V ÷ 4 VRMS
INPUT IMPEDANCE 15 KOhms
LOAD IMPEDANCE Stereo 8 - 4 - 2 Ohms
LOAD IMPEDANCE Mono 8 - 4 Ohms
Audison SR8055 - 170 ron
CONT. OUT POWER (2 Ch x 4 Ohms; 13.8 VDC) 55 W (RMS)
MONO OUT POWER (1 Ch x 4 Ohms; 13.8 VDC) Bridge 110 W (RMS)
adryan12
Maşina: Seat
Mesajde adryan12 » 20 Apr 2012, 16:28
COUGAR C500.4 - Vandut
XXL AMP 444 - Vandut
adryan12
Maşina: Seat
Mesajde adryan12 » 05 Mai 2012, 14:06
4x80W
REXCEL KB 905 - 130 RON
4X100W
WECONIC VX 4200 - 140 ron
4 x 50Wrms @ 4 ohm
2 x 120Wrms @ 4 ohm
High-Level-Input
Greutate 4,5 kg
IMPACT LK454 - 180 ron
tri mode operation
Audison LR72 - 130 ron
RISE TIME 4.5 μS
Audison SR8055 - 130 ron
OSIO NRG4070X - 150 ron
4 x 70 Watt RMS @ 4 ohm
4 x 85 Watt RMS @ 2 ohm
2 x 140 Watt RMS @ 4 ohm
- THD: 0.05%
- S/N Ratio: >100 dB A
- High level input
- Low Pass Filter 40~250Hz @ 12dB/oct
- High Pass Filter 40~250Hz @ 12dB/oct
Tel 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 28 Mai 2012, 16:13
WECONIC - Vandut
PIONEER - Vandut
4X100W
RISE TIME 4.5 μS
tri mode operation
- THD: 0.05%
- High level input
ESX V502 - 130 ron
2X50W rms / 4 ohm
2X90W rms / 2 ohm
1X180W / 4 ohm
High pass - 80 Hz
Low pass - 50Hz - 150Hz
Bass boost 12db@40Hz
Tel 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 22 Iun 2012, 13:09
ACTUALIZARE
IMPACT LK454 - 160 ron
REXCEL KB 905 - 110 RON
Audison LR72 - 110 ron
Audison SR8055 - 110 ron
OSIO NRG4070X - 140 ron
ESX V502 - 110 ron
CEEROY CQ280 - 130 ron
4x70W
Posibilitate functionare sistem 2.0 / 2.1 / 4.0
reglaj flat / low pass 80Hz / high pass 150Hz - pe canal 3/4
reglaj nivel intrare si bass/treble pe canal 1/2
La aceste preturi se mai adauga eventualele taxe de transport.
adryan12
Maşina: Seat
Mesajde adryan12 » 22 Iul 2012, 13:09
ESX V502 - VANDUT
OSIO NRG4070X - VANDUT
VALABILE IN CONTINUARE
DUB 1002 - 130 RON
RMS Power @ 4 ohms 100 watts x 2 channels
RMS Power @ 2 ohms 175 watts x 2 channels
Bridged RMS Power 220 watts x 1 channels
Peak Power Output 440 watts approx.
Number of Channels 2
Total RMS Power Output 350 watts
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
Built-in Crossover
Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 50 - 250 Hz
Low-Pass Crossover Frequency 50 - 250 Hz
Signal-to-Noise Ratio 95 dB
Bass Boost 0 / 12 dB
INFINITY RA5004 - 170 RON
Amplificator 4/3/2 canale
Power max.: 450 W
RMS power output into 2 ohms :4 x 75 W
RMS power output into 4 ohms :4 x 50 W
Frequency response: 10 Hz - 40 kHz
Tel 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 10 Aug 2012, 13:03
Raman valabile in continuare
RED STAR AMP 500 - 170 ron
4 × 50 Watt 4 Ohm + 1 × 132 Watt 4 Ohm
4 × 50 Watt 4 Ohm + 1 × 208 Watt 2 Ohm
adryan12
Maşina: Seat
Mesajde adryan12 » 24 Aug 2012, 19:29
Signat ROC 1 - 160 ron
Tel 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 21 Sep 2012, 14:44
tri mode operation
4X50 W rms
2X125 W rms
KENWOOD KAC 744 - 120 ron
4X40 W rms - 4 ohm
2X40 + 1X110 W rms - 4 ohm
2X110 W rms - 4 ohm
4X55 W rms - 2 ohm
AK SOUND ARV5150 – 200ron
RMS power@4ohm: 50W x 4CH + 50W (Center) + 150W (Woofer)
Bridge mode power@4ohm: 150W x 2CH + 50W (Center) + 150W (Woofer)
THD@4ohm: <1%
S/N (A-weighted): >95dB
Input sensitivity: 0.15 - 6V
Frequency response: 20Hz - 40KHz
AK SOUND AKG 4000 – 160ron
potencia RMS 4 Ohm: 100 X 4 + 300 SUBOUT
dimens&otilde;es : 252 X 400 X 50 mm
impedancia: 4 Ohm ESTABLE
gama de frecuencias: 20 Hz - 40 KHz
VIETA PW-5065 – 220ron
RMS a 4 Ohms: 4x65W + 1x130W
RMS a 2 Ohms: 4x95W + 1x180W
RMS a modo mono 4Ohms: 2x190W + 1x130W
Ce nu mai apare in lista s-a vandut.
adryan12
Maşina: Seat
Mesajde vl06rzt » 21 Sep 2012, 15:07
Salut
Iti dau 120 de lei pe :
Daca vrei imi dai pm si discutam ..O zi buna !
Ford Focus 1.6 16 valve 2005 berlina
vl06rzt
Localitate: Rm.Valcea
Maşina: Focus 2005,1.6 Benzina 100 CP
Mesajde adryan12 » 21 Sep 2012, 15:11
Salut, nu pot accepta suma propusa de tine. Este si asa un pret destul de mic, tinand cont ca este un amplificator pe 5 canale.
adryan12
Maşina: Seat
Mesajde vl06rzt » 21 Sep 2012, 15:24
Salut
O sa ma mai gandesc la o oferta decenta :)
vl06rzt
Mesajde adryan12 » 06 Oct 2012, 13:59
ACTUALIZARE
tri mode operation
4X50 W rms
2X125 W rms
4X40 W rms - 4 ohm
2X110 W rms - 4 ohm
4X55 W rms - 2 ohm
THD@4ohm: <1%
COUSTIC C400 – 250 ron
amplificator 1 canal
putere RMS:
1 x 250W (4 Ohmi)
1 x 400W (2 Ohmi)
raspuns in frecventa: 20Hz - 200Hz
raport semnal/zgomot: 75dB
logo iluminat
B-52 MOS-700 – 160 ron
4X175W
Variable subwoofer double crossover
2 Ohms stable operation with output power increase
Tri-mode imput configuration
BLAUPUNKT GTA 200 FLASH – 130 ron
Max Power 2 x 90 Watt / 4 Ω
Max Power 1 x 350 Watt / 4 Ω
Max Power 2 x 140 Watt / 2 Ω
RMS Power 2 x 45 Watt / 4 Ω
RMS Power 1 x 140 Watt / 4
RMS Power 2 x 70 Watt / 2 Ω
Stability 2 Ω
Input-sensitivity 0,1 - 8 V
Low-pass filter 40 - 160 Hz
High-pass filter 100 Hz
Bass Boost 0-9-18 dB
BLAUPUNKT GTA 4100 – 160 ron
Max Power : 4 x 100 Watt / 4 Ohm
Max Power : 2 x 320 Watt / 4 Ohm
RMS Power : 4 x 50 Watt / 4 Ohm
RMS Power : 2 x 150 Watt / 4 Ohm
TEL 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 24 Oct 2012, 08:47
tri mode operation
4X50 W rms
2X125 W rms
4X40 W rms - 4 ohm
2X110 W rms - 4 ohm
4X55 W rms - 2 ohm
THD@4ohm: <1%
putere RMS:
1 x 250W (4 Ohmi)
1 x 400W (2 Ohmi)
logo iluminat
4X175W
MACROM 42.25 - 130 ron
2/1 CHANNEL AMP
RMS Power 2 X 100 W @ 2 Ω
2 X 50 W @ 4Ω
Bridged power 160 W @ 4 Ω
Crossover Variable from 30Hz to 600 Hz,
LP or HP, 12dB/Oct
Input mode selector mono, stereo or mixed (L+R)
TEL 0769607934
adryan12
Maşina: Seat
Mesajde Ruffy RUF » 31 Oct 2012, 19:17
M-ar interesa un amplificator in 4 canale pe care sa pot lega un subwoofer de 300-350w rms si sa pot pune si 2 ovale pe el!
Sau un amplificator in 2 canale/monobloc daca nu!
As dori cu specificatiile de mai sus sa duca 350rms.
Pot oferi la schimb un blaupunkt gta 2 special mkII si diferenta in bani sau poate te intereseaza altceva de la mine.
Te astept pe messenger si imi poti arate ceva poze si detalii la id: ab77ruf
O seara buna, mersi!
Mondeo mk1 TD ... RS kitt
Ruffy RUF
Localitate: Alba Iulia
Maşina: Mondeo mk1 1.8 TD RFN + RS Kitt OEM
VIN: WFOFXXGBBFRS26771
Mesajde adryan12 » 12 Dec 2012, 11:05
tri mode operation
4X50 W rms
2X125 W rms
4X40 W rms - 4 ohm
2X110 W rms - 4 ohm
4X55 W rms - 2 ohm
THD@4ohm: <1%
putere RMS:
1 x 250W (4 Ohmi)
1 x 400W (2 Ohmi)
logo iluminat
4X175W
2/1 CHANNEL AMP
2 X 50 W @ 4Ω
LP or HP, 12dB/Oct
MICROMAXX MM80501- 150ron
4 x 110w / 2 x 220w (4x 70 w RMS)
20Hz – 20 KHz
Flat/HPF/Low PASS (22-360 Hz)
Bass Boost control
PROXIUM BXD1501 – 130 ron
1X150Wrms
Bass Boost
TEL 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 12 Mar 2013, 11:19
IMPACT LK454 - 150 ron
tri mode operation
RED STAR AMP 500 - 160 ron
Signat ROC 1 - 140 ron
4X50 W rms
2X125 W rms
VIETA PW-5065 – 190ron
COUSTIC C400 – 210 ron
putere RMS:
1 x 250W (4 Ohmi)
1 x 400W (2 Ohmi)
logo iluminat
B-52 MOS-700 – 140 ron
4X175W
BLAUPUNKT GTA 4100 – 150 ron
MACROM 42.25 – 120 ron
2/1 CHANNEL AMP
2 X 50 W @ 4Ω
LP or HP, 12dB/Oct
MICROMAXX MM80501- 140ron
20Hz – 20 KHz
Bass Boost control
PROXIUM BXD1501 – 120 ron
1X150Wrms
Bass Boost
AK SOUND AKG 4000 – 150ron
RMS 4 Ohm: 100 X 4 + 300 SUBOUT – 4 ohm
dimensiuni : 252 X 400 X 50 mm
gama de frecventa: 20 Hz - 40 KHz
Magnat Rave 300 – 130 ron
2 x 150W / 4 ohm
1 x 300 W / 4 ohm
Signat ROC 3 – 140 ron
4 × 40 Watt rms
1 × 142 Watt canal 1 + 2 - 4 Ohm
2 × 104 Watt canal 1 + 2 / 3 + 4 - 4 Ohm
Sinus Live 504 – 140 ron
4X50 W rms – 4 ohm
Stabil 2 ohm
Takara TKR 5000 – 140 ron
amplificator 4 canale
TEL 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 25 Apr 2013, 09:11
tri mode operation
4X50 W rms
2X125 W rms
putere RMS:
1 x 250W (4 Ohmi)
1 x 400W (2 Ohmi)
logo iluminat
4X175W
2/1 CHANNEL AMP
2 X 50 W @ 4Ω
LP or HP, 12dB/Oct
20Hz – 20 KHz
Bass Boost control
1X150Wrms
Bass Boost
4 × 40 Watt rms
4X50 W rms – 4 ohm
Stabil 2 ohm
TEL 0769607934
adryan12
Maşina: Seat
Mesajde adryan12 » 14 Oct 2013, 09:56
RED STAR AMP 500 - 130 ron
Signat ROC 1 - 120 ron
4X50 W rms
2X125 W rms
VIETA PW-5065 – 150ron
B-52 MOS-700 – 120 ron
4X175W
MICROMAXX MM80501- 120ron
20Hz – 20 KHz
Bass Boost control
PROXIUM BXD1501 – 100 ron
1X150Wrms
Bass Boost
Signat ROC 3 – 120 ron
4 × 40 Watt rms
Sinus Live 504 – 120 ron
4X50 W rms – 4 ohm
Stabil 2 ohm
Takara TKR 5000 – 120 ron
TEL 0769607934
adryan12
Maşina: Seat
Anterior
