Dezmembrez Ford Mondeo 3 2002
Mesajde Dan Mihay » 04 Mai 2012, 00:26
Dezmembrez Ford Mondeo MK3 1.8 si 2.0
Se vinde orice piesa, la preturi bune.
Locatie Bucuresti
PIESE DIN DEZMEMBRARI
ELEMENTE CAROSERIE
aripa fata - 100 LEI
capota motor - 300 LEI
haion - 200 LEI
bara protectie fata – spate - 300 LEI
portiere - 350 LEI
trager - 200 LEI
armatura bara - 200 LEI
lonjeron - 250 LEI
contra aripa - 100 LEI
stalp - 200 LEI
prag - 100 LEI
ELEMENTE OPTICE
far - 200 LEI
semnalizator 40 LEI
stop - 150 LEI
geam portiera - 100 LEI
parbriz cu degibrare - 350 LEI
oglinda - 100 LEI
ELEMENTE/ANEXE MOTOR
alternator - 250 LEI
electromotor - 250 LEI
compresor AC - 250 LEI
Pompa servo directie - 250 LEI
injector - 300 LEI
pompa injectie - 750 LEI
galerie admisie - 400 LEI
galerie evacuare - 250 LEI
chiuloasa - 700 LEI
bloc motor - 500 LEI
vibrochen - 250 LEI
baie ulei 200 LEI
pompa ulei 250 LEI
ELEMENTE DIRECTIE/SUSPENSIE/TREN RULARE
arc elicoidal - 100 LEI
telescop - 100 lei
amortizor - 150 lei
caseta directie - 500 LEI
conducta servo directie - 60 LEI
brat roata - 200 LEI
fuzeta - 200 LEI
port-fuzeta - 100 LEI
jug motor - 300 LEI
ELEMENTE RACIRE MOTOR/HABITACLU
radiator apa - 200 LEI
radiator clima - 300 LEI
electroventilator - 200 LEI
aeroterma ford mondeo - 200 LEI
ELEMENTE SIGURANTA
airbag sofer - 300 LEI
airbag pasager - 150 LEI
airbag lateral - 150 LEI
calculator airbag - 200 LEI
centura siguranta - 40 LEI
ELEMENTE TRANSMISIE
cutie viteze - 700 LEI
Volanta - 700 LEI
planetara - 250 LEI
timonerie - 250 LEI
ELEMENTE FRANARE
etrier frana 100 LEI
disc frana 100 LEI
pompa servo frana - 230 LEI
modul abs - 300 LEI
senzor abs - 100 LEI
ELEMENTE ELECTRICE
calculator motor - 300 LEI
panou comanda ac clima - 100 LEI
macara geam - 150 LEI
broasca usa - 80 LEI
ceas de bord - 150 LEI
contact pornire - 100 LEI
Bloc lumini ford mondeo - 200 LEI
0761703837
Dan Mihay
Re: Dezmembrez Ford Mondeo 3 2002
Mesajde mircionixs » 05 Mai 2012, 00:48
sal dan, vreau si eu pompa de servo pt un mondeo model 2001 tddi 2.0 115cp si furtunul de la interculer cel in forma de S cu capetele diferite. Le ai pe stoc? Asi dori in nr de tel sa vb.
Mondeo MK3 breack TDDI 2.0 115cp 2001
mircionixs
Mesajde Dan Mihay » 05 Mai 2012, 09:39
0784664020
0761703837
Dan Mihay
Mesajde Dan Mihay » 05 Mai 2012, 21:19
pentru mircionixs, nu am furtunul de la intercooler, am pompa de servo la 200 lei
0761703837
Dan Mihay
Mesajde xetix » 05 Mai 2012, 21:46
Ce culoare este ? Daca e moondust silver sunt interesat de o aripa.
http://www.helpioana.ro
xetix
VIN: WF05XXGBB54A52019
Mesajde Dan Mihay » 05 Mai 2012, 23:47
are culoarea bleu ciel
0761703837
Dan Mihay
Mesajde ddg71 » 06 Mai 2012, 09:34
aveti radiator aer conditionat exact ca modelul din poza ?
ddg71
Maşina: FORD ABSOLUTE BLACK 2.0 TDCI 180 CP POWERSHIFT
VIN: WF0EXXWPCEGK62133
Mesajde Dan Mihay » 06 Mai 2012, 11:01
Pentru ce Mondeo e? din ce an e? si ce motor are masina?
0761703837
Dan Mihay
Mesajde Dan Mihay » 09 Mai 2012, 04:07
UP
0761703837
Dan Mihay
Mesajde badboy20cm » 09 Mai 2012, 10:25
racord flexibil toba ...,este sub masina in partea din fata ,acea bucata de racord flexibil de intra in catalizator???pret
badboy20cm
VIN: WF0WXXGBBW1U89568
Mesajde Dan Mihay » 09 Mai 2012, 12:58
am racordul la 150 lei
0761703837
Dan Mihay
Mesajde NELU69 » 09 Mai 2012, 21:03
buna,am nevoie de piulite jante aliaj daca mai aveti si cric.
Ford Mondeo 2.0 TDCI 2004 GHIA
tel 0766366166;
Y id pop_cipi
NELU69
Localitate: northampton uk
Maşina: FORD MONDEO
VIN: WF0EXXGBBEDA49984
Mesajde Dan Mihay » 09 Mai 2012, 21:38
piulitele le-am vandut, am cricuul la 50 lei
0761703837
Dan Mihay
Mesajde NELU69 » 10 Mai 2012, 16:36
parbrizul e dat jos de pe masina si capetii sarmelor din el sunt ok,nu s-au rupt?
tel 0766366166;
Y id pop_cipi
NELU69
Maşina: FORD MONDEO
Mesajde Dan Mihay » 10 Mai 2012, 22:19
parbrizul nu este dat jos dupa masina, il pot da daca esti hotarat sa il cumperi, cand a fost adusa masina, degivrarea functiona. stima
0761703837
Dan Mihay
Mesajde mihu_st » 11 Mai 2012, 14:39
injectoarele in ce stare sunt ce cod au
mihu_st
Maşina: Ford mondeo tdci 2003 131 cai
Mesajde NELU69 » 11 Mai 2012, 17:22
daca nu e lovit de pietre,si nu il strici cand il dai jos(eu am patit-o) vreau sa il cumpar.eu stau in sect 2.
tel 0766366166;
Y id pop_cipi
NELU69
Maşina: FORD MONDEO
Mesajde lily_efs_2000 » 11 Mai 2012, 17:50
Salut. Am incercat sa te sun, dar nr nu e alocat. Ma intereseaza compresorul de AC pt un for focus II, 1.6 benzina, 101 cp, daca e ok si in ce bani. Tel: 0740/43.19.86. Ms.
lily_efs_2000
Localitate: IASI
Mesajde p_m_1959 » 11 Mai 2012, 17:57
M-ar interesa compresorul de aer daca este compatibil pentru un ford mondeo tddi din 2002,cap. 1998cm,90 CP tipul motorului D5BA
p_m_1959
Maşina: ford mondeo 2002 1998 66kw standard
VIN: WFOWXXGBBW2PO2531
Mesajde Dan Mihay » 11 Mai 2012, 21:01
@mihu_st injectoarele au fost testate, nu au niciun fel fe problema. Cel mai bine ar fi sa vi sa le vezi, sa le testam la tine, inca nu sunt date jos dupa masina!
@nelu69 In ce sens l-ai stricat cand l-ai dat jos? nu are lovituri de pietre. il poti vedea in berceni
@lily_efs_2000 am piese doar de mondeo, nu cred ca se potriveste compresorul pe focus
@p_m_1959 Din cate stiu nu se potriveste!
0761703837
Dan Mihay
Mesajde mihu_st » 11 Mai 2012, 22:03
spunemi de unde esti eu stau in buc
mihu_st
Mesajde Dan Mihay » 11 Mai 2012, 22:55
berceni. ma poti suna maine..pe la pranz si vorbim 0784664420
0761703837
Dan Mihay
Mesajde valik82 » 12 Mai 2012, 11:19
regulatorul de turatie de la electroventilator il ai? asta in cazul in care ai doar un singur ventilator mare,nu doua mai mici,si pret te rog!
valik82
Localitate: focsani
Maşina: Ford Focus 2 facelift
Mesajde Dan Mihay » 12 Mai 2012, 15:42
astept poze cu el. multumesc
0761703837
Dan Mihay
Mesajde Dan Mihay » 14 Mai 2012, 13:19
Up !
0761703837
Dan Mihay
Mesajde ciolpi » 15 Mai 2012, 13:17
salut
sunt cu volan pe stanga sau pe dreapta ?
daca sunt pe stanga as dori sa stiu daca se potriveste caseta de directie la tdci.
mersi.
ciolpi
Localitate: Ploiesti
Maşina: Ford Mondeo 2006 115CP 2.0 TDCI
VIN: WF04XXGBB46M56592
Mesajde Dan Mihay » 15 Mai 2012, 20:11
salut.sunt cu volan dreapta. e posibil sa se potriveasca ! nu stiu exact
0761703837
Dan Mihay
Mesajde Dan Mihay » 17 Mai 2012, 22:43
Nou!!! Aduc seturi de jante noi sau SH cu sau fara cauciucuri , la comanda, la preturi mai mici decat in Romania. Pentru comenzi lasati PM cu model , specificatii si poza pentru oferta !
0761703837
Dan Mihay
Mesajde Dan Mihay » 20 Mai 2012, 01:01
Dan Mihay
Mesajde valik82 » 20 Mai 2012, 19:01
nu am timp sa fac poze si nici nu cred ca pot. ar insemna sa dau ventilatorul jos. cat este pretul ventilatorului cu tot cu carcasa si ce are pe ea?
valik82
Localitate: focsani
