Sratie Radio CB Luiton + Antena 70 cm
Mesajde petriangabor » 24 Mar 2013, 13:15
Vand Statie radio CB Luiton + Antena 70 cm impecabile,Arata si functioneaza impecabil,fara reparatii.
Caracteristici Statie si antena LT-268
4W transmisie
40 canale AM/FM
Canal 9 si 19
Schimbare AM/FM
Frequency range 25.615 - 28.305 MHz
Frequency control P.L.L.
Operating temperature -10°/+55°C
DC input voltage 13.8Vdc ±15%
Size 115 (L) x 38 (A) x 150 (P) mm
Weight 0.8 kg
Antena Avanti Squadra magnetica 700 mm
Producator Avanti
Antena cu talpa magnetica, lungime antena 0.7m diametru magnet 9cm
Prezentare produs: Â Â Frecventa: 26.965-27.405 MHz
Numar de canale: 40
Putere maxima suportata: 100W
Minimum S.W.R. 1:1.2
Gain 1.5 dB
Impedance 50 Ohm
Cablu RG 58 lungime: 2750 mm
Tip Accesoriu: Â Â Antena magneticadtz
Diametru magnet : 9cm
Accept variante la scimb cu set Jenti aliaj 4x108 pt ford
Pret negociabil 380 RON Detali la tel:0754885104
Fişierul ataşat antena-avanti-squadra-magnetica-700-mm-1816384[1].jpg nu mai este disponibil
Traim degeaba
petriangabor
Localitate: campulung arges
Maşina: Ford Escort GAL 1,4 benzina 1997 hatckbak
VIN: WFOBXXGCABTY69022
Re: Sratie Radio CB Luiton + Antena 70 cm
Mesajde petriangabor » 17 Iun 2013, 10:03
300 RON CU TOT CU ANTENA URGENT
Traim degeaba
petriangabor
