Vand lada termoelectrica WAECO TB-15
Mesajde Twist » 14 Apr 2013, 12:57
Modelul cotiera de la Waeco , nu ocupa spatiu inutil in portbagaj, usor de ajuns la ea chiar si in timpul mersului, se aseaza pe bancheta spate in mijloc si se prinde cu centura de siguranta.
Ideala si vara si iarna, RACESTE cu 20 grade mai putin ca in exterior si INCALZESTE cu +65 grade mai mult fata de exterior.
Functia de incalzire este excelenta iarna, tine sandwich-urile si ceaiul calde.
Are protectie la voltaj scazut incorporata, isi taie singura alimentarea cand bateria e slaba, lasand mereu curent de pornire.
Volum 15 litri, consum 40W.
External dimensions (w x h x d) 282 x 328 x 440mm.
Internal dimensions (w x h x d) 204 x 261 x 358mm (max).
Weight 5.2Kg.
LED indicators for cooling/heating function and battery monitor, safe fastening on the vehicle seat with the safety belt, extensible fastening rail to avoid tilting in case of a sudden stop, safe pressure closure, ABS (Active Battery Security), accommodates 1.5- and 2-litre returnable bottles, can be switched to cold/warm, fold-up grid tray, serves as an armrest for extra comfort when fitted on the rear seat.
http://www.waeco.com/en/products/4179_3 ... tOrigID=57
PRET 300 RON + transport, aproximativ la jumatate fata de pretul de noua.
Foarte putin folosita, nu are urme de uzura sau defecte.
0723105105
Twist
Re: Vand lada termoelectrica WAECO TB-15
Mesajde Twist » 18 Apr 2013, 19:25
VANDUT.
Se poate inchide.
Twist
