piese ford escort mondeo si fiat stilo,bara fata nova...POZE
Mesajde fla_tun » 18 Sep 2013, 21:57
vand urmatoarele piese Sh perfect funtionale...:
Bara fata Dacia Super nova putin crapata la proiector 40lei
fise bujii ford focus 40lei
fise+bobina inductie ford mondeo/escort 40lei bobina/40lei fisele sau 70lei ambele
bucsi bara stabilizatoare fiat stilo ca noi 30lei
far stanga ford mondeo 40lei
pompa injectie ford mondeo 1.8td 150lei ca defect trebuie schimbate garniturile deoarece pierde motorina
disc ambreiaj nou delphi ford escort/mondeo 1.6 16v 35lei
grila capota ford escort 1994 20lei
pompa ABS ford escort 1994 40lei
timonerie fiat stilo 4 usi 40lei
calculator ABS ford escort 30lei
modul aprindere electronica ford escort 1.4 si 1.6 40lei
pompa servo frana ford escort 1995 35lei
macara geam electric dreapta fata fiat stilo 4 usi 40lei
pompa ulei ford escort/mondeo 1.6 16v 30lei
tablou sigurante cu ABS ford escort 1.6 1994
rampa injectoare ford escort/mondeo 1.6 1.8 16v 60lei
pompa apa ford escort 1.4 35lei
pompa apa ford escort mondeo 1.6 16v 40lei
far dreapta ford escort 40lei
injectoare ford escort/mondeo 1.6 1.8 16v 3buc 45lei
furtun y ford focus 2.0 20lei
macarale geam electric fata + instalatia electrica ford escort 4 usi 80lei
DISC AMBREIAJ 1.6 16V
POMPA INJECTIE 1.8TD
FAR MONDEO
BUCSI BARA STABILIZATOARE FIAT STILO
FISE+BOBINA MONDEO/ESCORT
FISE FOCUS
BARA NOVA
BARA NOVA
fla_tun
Localitate: Targoviste
VIN: WF0NXXGBBNXC72134
Re: piese ford escort mondeo si fiat stilo,bara fata nova...
Mesajde balu16v » 18 Sep 2013, 22:51
nu e cumva disponibil suportul de la bobina focus? [cel din poza]
balu16v
Localitate: Tg-Mures
Maşina: Mondeo MK2 1.8 GHIA
VIN: WF0AXXGBBATS12345
Mesajde fla_tun » 19 Sep 2013, 09:20
din pacate nu este disponibil
SE MAI ADAUGA BRATE FARA PIVOTI DAR CU BUCSI BUNE PT MONDEO MK2 40LEI
POMPA ULEI 1.6 16V
MACARA GEAM ELECTRIC DREAPTA FIAT STILO
POMPA SERVO FRANA fORD
MODUL APRINDERE ELECTRONICA 1.6 16V
CALCULATOR ABS FORD ESCORT
TIMONERIE FIAT STILO
POMPA ABS FORD ESCORT
masca capota ford escort
fla_tun
Mesajde fla_tun » 24 Sep 2013, 11:21
preturi de criza
far dreapta escort
far dreapta escort
pompa apa 1.6 16v
pompa apa 1.6 16v
pompa apa escort 1.4
rampa injectoare 1.6 1.8 16v
fla_tun
Mesajde fla_tun » 30 Sep 2013, 15:17
pompa injectie mondeo 1.8tdi scade la 120lei
fla_tun
Mesajde fla_tun » 07 Oct 2013, 20:51
Valabil...preturi fff mici
fla_tun
Mesajde fla_tun » 11 Oct 2013, 20:01
s-a dat farul de escort si macaraua de stilo...restu valabile...
fla_tun
Mesajde fla_tun » 20 Oct 2013, 21:25
up...preturi f mici.
fla_tun
Mesajde madatzuhk » 11 Noi 2013, 02:36
Salut, ai cumva maner de usa pe dreapta din exterior pt escort mk5 si ialele + contactul ( partea mecanica ) + cheia.
Astept msg cu pretul la fiecare in parte. !
Ford Escort Cabrio Mk6
Ford Focus Mk1
madatzuhk
Maşina: Ford Escort Cabrio
VIN: WF0LXXGKALRY93531
Mesajde fla_tun » 11 Noi 2013, 08:06
salut,am manere si yale fara chei pt modelul 1990-1994
fla_tun
Mesajde Eu Alex » 22 Noi 2013, 23:29
Pompa injectie mondeo o mai ai?
Eu Alex
Maşina: Ford Escort Ghia 1.8 TD, 66Kw, 90CP
VIN: WF0NXXGCANVP18505
Mesajde fla_tun » 23 Noi 2013, 09:34
nu ma este..;(
fla_tun
Mesajde mugurut » 13 Mar 2014, 17:53
Buna ziua.Am un Ford Escort hatchback in 3 portiere,din '94 si pentru el as avea nevoie de:motor complet(1600 Zetec,L1E/serie PE25732;am dat seria in ideea ca motorul va fi cu serie apropiata pentru compatibilitate maxima cu cel actual) sau chiulasa completa(asta nu aflu decat dupa demontare,fiind rupta curea de distributie),discuri de frana-2 buc.,sonda lambda,macara portiera stanga,maner exterior portiera stanga,chedere portiere,capitonaj compartiment motor,esapament complet de la catalizator la finala,oglinda ext. stg.fara reglaj int..La momentul asta ma intereseaza disponibilitatea si pretul.Multumesc anticipat.Mugurel Popa
mugurut
Localitate: Piatra Neamt
Maşina: Ford Escort CL/trei portiere 1994,1.6/16V/90CP
VIN: WF0BXXGCABPE25732
Mesajde fla_tun » 13 Mar 2014, 20:23
din ce ati enumerat mai sus am doar macara portiera stanga si maner exterior portiera stanga. ambele la 40lei.si vile pot trimite p 21 martie ca acum sunt plecat prinn tara un pic.daca nu gasiti va rog mai imi dati de stire si poate va fac rost la pret bun.
daca va fac rost de toate aceste piese la mine var costa 800lei tot ce ati cerut,asta cu motor complet,sau 700 doar cu chiuloasa
stima
fla_tun
Mesajde mugurut » 14 Mar 2014, 13:00
Salut.Ar fi super daca m-ai descurca cu toate.Sincer sa fiu motorul doare cel mai mult,dar am nevoie de tot ce am zis mai inainte.Asa ca astept semne bune de la dumneavoastra.Cu stima.Si drumuri bune.
mugurut
Mesajde fla_tun » 15 Mar 2014, 00:06
ok,dar daca fac rost cum intrati in posesia lor?veniti dupa ele la targoviste?
fla_tun
Mesajde mugurut » 16 Mar 2014, 22:28
Salut.Ramane sa-mi trimiteti manerul si macaraua.Si daca aveti un set de fise bijii.Multumesc.
mugurut
Mesajde fla_tun » 17 Mar 2014, 08:51
am si fisele la 40lei setul de 4.si 40 macaraua cu manerul.in total 80
macaraua manuala pt 2 usi
si o adresa cu numele unde sa le trimit
fla_tun
Mesajde mugurut » 17 Mar 2014, 19:18
Ok.Va trimit datele in pm.
mugurut
Mesajde hachikoBOSS » 18 Mar 2014, 00:36
fisele merg pe ford mondeo mk3 benzina?
hachikoBOSS
Mesajde fla_tun » 18 Mar 2014, 08:31
pai sunt 2 modele de fise,le am p ambele.mai jos ai niste poze cu ele,care din ele sunt la fel cu ce iti trebuie?
fla_tun
Mesajde fla_tun » 18 Mar 2014, 08:33
fisele din poza sunt cu titlu de prezentare,dar tind sa cred ca cele din a 2 poza sunt cele care iti trebuie.
fla_tun
Mesajde mugurut » 18 Mar 2014, 09:01
Salut.Piesele de care am vorbit le trimiti,nu?Adica macara fata stg.,maner ext. portiera stg.,set fise bujii.Sa nu crezi ca am renuntat si la ele.Multumesc.Cu stima.
mugurut
Mesajde fla_tun » 18 Mar 2014, 09:57
bineinteles ca le voi trimite,dar vam zis ca luni sau marti cel tarziu.
fla_tun
Mesajde hachikoBOSS » 18 Mar 2014, 15:53
fise ford mondeo mk3 1.8 ?
hachikoBOSS
Mesajde fla_tun » 18 Mar 2014, 19:30
vam pus mai sus 2 poze,car din ele vi-se potrivesc ca sunt 2 modele....unul cu mufa de intra in boboina mai mare si unu cu mufa mai mica.eu cred ca sunt cele cu mufa mica.
fla_tun
Mesajde hachikoBOSS » 19 Mar 2014, 21:01
prima poza, cele de intra in bobina..la ce pret sunt?
hachikoBOSS
Mesajde fla_tun » 19 Mar 2014, 21:26
sunt 40lei setul,dar sigur sunt ca cele din prma poza adik cele cu mufa mai larga
fla_tun
Mesajde hachikoBOSS » 19 Mar 2014, 21:35
si sunt cele originale de la ford?
hachikoBOSS
Mesajde fla_tun » 19 Mar 2014, 21:49
toate piesele pe care le vand in acest topic sunt originale ford
fla_tun
Utilizatorii ce navighează pe acest forum: danenache2004 şi 2 vizitatori
