Vand SPEC clutch kit Stage 2+ & volanta Focus RS MK2 ST MK2
Mesajde mihaidd » 26 Sep 2013, 19:59
SPEC clutch kit Stage 2+ & flywheel Ford Focus RS MK2 ST MK2 or Volvo T5
custom billet single mass flywheel and carbon graphite kevlar clutch
Kitul include: disc ambreiaj, placa presiune, volanta custom single mass
Used for about 400km for engine break-in, before other parts were bolted on & before new remap and clutch upgrade.
Kit includes clutch disc, pressure plate, custom single-mass flywheel.
For international postage rates, please contact us, we usually send via EMS at flat cost rates, other carriers can be quoted upon request.
SPEC Stage 2 + Clutch Kit - Ford Focus RS MK2
SPEC CLUTCH & FLYWHEEL - Shift To A Higher Standard
SPEC clutches and flywheels are developed and manufactured in the USA using the most advanced methods under the most strict of tolerances. A commitment to offering products of the highest quality is the core value upon which the company has been built.
SPEC clutches and flywheels are manufactured for specific driving environments, and are recommended based on how each car reacts to changes in supporting modifications and rotating mass. SPEC products are NOT built on a one-fits-all philosophy, though they can be used for an array of driving habits and racing/high performance applications.
Manufactured from only the highest quality steel and aluminum, SPEC offers the only flywheels on the market manufactured to a .001 machine tolerance, guaranteeing a flat seating surface for the clutch and smooth rotational qualities for perfect balance and extended engine life.
This clutch kit is rated to hold up to 475 lbft (644Nm) of torque.
Types of Driving:
Street, Drag, Pulling, Autocross
Features a multi-friction disc in a full faced configuration with carbon semi-metallic on one side and Kevlar on the other. Bridging the gap between stage 2 and stage 3, the 2+ offers drivability and engagement quality characteristic of the stage 2, but with a 15-20% higher torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Great for street, drag, autocross, road racing, pulling, rallye and drift.
High clamp pressure plate*
Hybrid Kevlar and Carbon-Graphite Friction material
High torque sprung hub and disc assembly
Imagine Imagine Imagine Imagine Imagine Imagine Imagine
Pret: 700 EUR tot pachetul.
Contact: mihaidd@gmail.com
+40731495898
mihaidd
Maşina: Daewoo Cielo STD LPG 2005
VIN: 12345678901234567
