VAND Statie+ subwoofer MAC MPX2000
Mesajde Eu Alex » 30 Ian 2014, 13:01
Cum scrie si in titlu se vand!
Statia:
Max. power output* into 4 Ω 2x180/ 1x500 Watt
RMS power output** into 4 Ω 2x60/ 1x150 Watt
Max. power output* into 2 Ω 2x250 Watt
RMS power output** into 2 Ω 2x80 Watt
Frequency response 5 – 50 kHz (-3 dB)
THD < 0,05 % (1 kHz)
Signal-to-noise ratio > 100 dB
Input sensitivity 0,4 – 4 V
Dimensions (W x L x D) 239 x 59 x 226 mm
Input impedance 20 kOhm
Power impedance 12 V minus an Masse
Weight 1,9 kg
Highlights
2 ohm stable
Variable low pass 40 – 300 Hz (12 dB per octave)
Variable high pass 40 – 300 Hz (12 dB per octave)
Variable bass boost 0...12 dB at 45 Hz
Bridge- / Tri-mode capability
Protection circuit that safeguards against short circuits, DC-offset and overheating
Green operation and red protection indication LED
* (Sinus Burst 2:8, 1 kHz) 14,4 V
**(DIN 45 324) 14,4 V
Pentru subwoofer se vad detaliile in poza.
Pentru Bucuresti se pot proba pe masina mea
Pret: 350ron
Tel:0761453772
Eu Alex
Maşina: Ford Escort Ghia 1.8 TD, 66Kw, 90CP
VIN: WF0NXXGCANVP18505
Re: VAND Statie+ subwoofer MAC MPX2000
Mesajde Eu Alex » 02 Feb 2014, 14:11
Up!
Eu Alex
Mesajde Eu Alex » 05 Feb 2014, 17:17
Up!
Eu Alex
Mesajde Eu Alex » 08 Feb 2014, 19:18
Se poate inchide, multumesc pentru gazduire!!
Eu Alex
