Arhiva Comercial
Revizie Mondeo MK3 TDCI 130 CP - 100.000 KM
Mesajde skin_head » 17 Mai 2009, 10:18
Va salut.
Pentru ca nu mai am cartea de service a masinii iar masina are 95.000 km, sunt curios ce se schimba la nr asta de km - ma refer aici pe langa filtre, ulei, eventual placute, daca mai este ceva prevazut a fi schimbat - poate curele accesorii?
Am cautat pe forum dar nu am gasit un plan de revizii.
Mersi anticipat.
Ex-Mondeo Ghia 2002, TDCI, 130 CP
skin_head
Re: Revizie Mondeo MK3 TDCI 130 CP - 100.000 KM
Mesajde idaniel » 21 Mai 2009, 19:25
Service Schedule - Mondeo 2001 [DURATORQ-TDCI/MAN] - 6 Years (75000 ml)
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and horn Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Outside Vehicle
Door check straps + Check operation/grease (steel check straps only)
Hood latch/safety catch & hinges + Check operation/grease
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: °C
Coolant expansion tank, power steering fluid, washer reservoirs and battery Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Battery terminals Clean, if necessary/grease
Odour filter Renew
Fuel filter Renew
Induction air filter Renew (more often in polluted conditions)
Under Vehicle
Engine Drain oil and renew oil filter
Steering, suspension linkage, ball joints, driveshaft joints and gaiters Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle, transfer box Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust Check for routing, damage, chafing and leaks
Underbody + Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth
RF mm, LF mm, LR mm, RR mm
Brake system + With wheels/drums off, check brake pads, discs, linings for wear and check brake cylinders and drums for condition; check rubber components for deterioration
Outside Vehicle
Engine Refill engine oil
Brake fluid Check level - in the case of abnormal fluid loss only, a separate order is required to investigate and rectify
Tyres Adjust pressure
Spare wheel Adjust pressure, check wear - condition (note tread depth)
mm
Luggage compartment lamp + Check operation - if applicable
Wheel nuts Tighten to correct torque and check for correct type. Check for rim damage
Wheel covers Check for damages, especially at retainer system
Service reminder sticker Affix to driver side B pillar
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system Every 4 years - Check/clean pressure cap, renew if there is seal deterioration
Cooling system Every 10 years - Orange/pink coloured coolant. Drain, flush and refill with purple Super Plus (LTS 24 122 4)
Cooling system Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Auxiliary drive belts Every 150 000 miles/10 years - Renew front belt (LTS 21 567 5)
Auxiliary drive belts Every 100 000 miles/10 years - Renew rear belt (LTS 21 567 5)
Visual body & paint check Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above - see detailed Check Sheet - if applicable (LTS 54 555 1 +)
Extra Services and Additional Offers * (optional - upon customer request / charged seperately)
Odour filter plus Upgrade odour filter to odour filter plus
+ Visual body and paint check should be carried out during these operations on vehicles built from 03/2002 onwards - see detailed Check Sheet if applicable.
Separate labour charge dependant on market regulations.
idaniel
Localitate: BISTRITA
Maşina: FORD MONDEO, 2004, 1998cm3, 130CP, VIVA
VIN: WFOWXXGBBW4R32358
Mesajde idaniel » 21 Mai 2009, 19:27
Pentru detalii vezi site-ul asta :
http://www.etis.ford.com/fordservice
idaniel
Mesajde skin_head » 23 Mai 2009, 08:01
Foarte tare informatia.
Ms frumos.
skin_head
Înapoi la Arhiva Comercial
