Noutăţi auto
Noul Ford Taurus
Re: Noul Ford Taurus
Mesajde addrian » 03 Feb 2010, 12:52
acceptabil si la viraje, la cat de mare e (5.15 lungime, 2.17 latime,1.54 inaltime)
addrian
Mesajde Cornel001 » 03 Feb 2010, 13:20
lateralul si spatele imi spun ce au scos din prototipul interceptor.
pornind de la video de sus
http://www.insideline.com/ford/taurus/2 ... -test.html
$1 scrie:$2The 3.5-liter V6 in the 2010 Ford Taurus seems like an afterthought here. Its output of 263 horsepower at 6,250 rpm and 249 pound-feet of torque at 4,500 rpm hardly rates with the competition and peaks a little far up the rpm scale to promise comfortable motoring. Fortunately the six-speed automatic transmission picks up the slack, and the Taurus never feels breathless or sluggish in the way the Five Hundred did with its continuously variable transmission (CVT).
At the same time, the Taurus is not quick. It gets to 60 mph from a standstill in 7.8 seconds (7.5 seconds with 1 foot of rollout like on a drag strip), and does the quarter-mile in 15.7 seconds at 88.9 mph. If you had four passengers with you, a calendar would be the requisite measurement tool.
It's easy to feel a twinge of embarrassment while slinging this 4,042-pound car through a corner, but there's no need, since a BMW 7 Series weighs 500 pounds more and no one is ever embarrassed by it. The stability control always stays engaged, probably what you expect from a passenger sedan, so cornering grip on the skid pad is limited to 0.79g (not so bad) and speed through the slalom peaks at 60.3 mph (pathetic). It comes to a halt from 60 mph in 131 feet, which is what you expect.
Yet from behind the wheel, there's no maneuver that you won't attempt. While the Five Hundred always proved well-balanced at the limit, it used to sink submissively to the bump stops of the suspension when you got serious, making it seem wimpy even when it wasn't. Now the suspension feels far better managed in the European style, and the Taurus uses all of its travel with well-damped precision until you finally peel the tires off the rims. None of this car's front-wheel-drive or all-wheel-drive competition corners as adeptly, and the guys at GM might consider a quick fact-finding trip to the Dearborn proving ground to discover how the Ford guys have been able to suspend the laws of physics in such a heavy car.
The Taurus is just big, that's all.
Cornel001
Membru Belit
VIN: dealadecotnarisec
Mesajde Mondy man » 03 Feb 2010, 14:46
Gata, m-ati convins.
Se misca chiar bine tinand cont ca e cat vaca. Desi ofera foarte multe pt banii aia, nu cred ca va avea succes in Europa tocmai din cauza dimensiunilor. Nu o vad prin Italia sau Franta.
In rest e chiar misto masina, e chiar o realizare pt Ford USA, tinand cont de ce au scos in ultimii 20 ani.
Sincer, BRAVO!
Mondy man
Mesajde parintele_2771 » 14 Feb 2010, 22:24
http://www.fordvehicles.com/cars/taurus/
eu cred ca ar multumi pe oricine. e superb!!!
ca si focusul asta: http://www.fordvehicles.com/cars/focus/2012/ hm! 2012 poate il fac mai repede
oare nu trimit "minunile" astea si prin posta rapida? :-)
Înscrie-te în grupul ClubFord HUNEDOARA
"Niciodata nu te certa cu un idiot.
Te aduce la nivelul lui si te bate cu experienta!"
parintele_2771
Localitate: Deva
Maşina: Ford Fiesta 1.6 TDCi,90CP,2009,Titanium
VIN: WF0JXXGAJJ9U45120
noul TAURUS` ........
Mesajde sandu_daniel » 29 Mar 2010, 23:36
sandu_daniel
Localitate: Udine
VIN: WF0WXXGBBW2P13626
Re: noul TAURUS` ........
Mesajde PH3N0M3N » 30 Mar 2010, 00:22
design-ul e ...wwwoooOOOWWWW!
partea buna: arata f bine, dotari bune
partea mai putin buna: piata de desfacere, pretul si, evident, consumul...
PH3N0M3N
Mesajde Cornel001 » 30 Mar 2010, 15:27
http://wardsauto.com/reports/2010/tenbe ... 5L_091221/
Uitati-va la graficul de jos.
474 Nm 1500-5250 rpm. :|
si curba de putere ce perfect constant urca.
Cornel001
Membru Belit
Anterior
Înapoi la Noutăţi auto
