Răspunde
Re: Motociclism si Motociclisti
09 Sep 2008, 14:48
Multam. Nu stiu de unde ai luat chestiile de mai sus dar sunt multe data eronate pe acolo. Am gasit eu ieri pe net o super comparatie intre motociclete impartite pe clase. Pana gasesc site-ul delectaati-va cu asta care face comparatii bazate pe teste dyno
http://www.deeknow.com/dyno/index.php?b ... on=Dyno+It
09 Sep 2008, 14:53
General information
Model: Suzuki SV 650
Year: 2000
Category: Naked bike
Rating: 77.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 654.00 ccm (39.91 cubic inches)
Engine type: V2
Stroke: 4
Power: 70.00 HP (51.1 kW)) @ 9000 RPM
Torque: 62.00 Nm (6.3 kgf-m or 45.7 ft.lbs) @ 7500 RPM
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
More details Consult a Suzuki repair manual.
Physical measures
Dry weight: 169.0 kg (372.6 pounds)
Seat height: 805 mm (31.7 inches) If adjustable, lowest setting.
Wheelbase: 1,420 mm (55.9 inches)
Chassis and dimensions
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 200.0 km/h (124.3 mph)
Power/weight ratio: 0.4142 HP/kg
Other specifications
Fuel capacity: 16.00 litres (4.23 gallons)
Color options: Yellow, blue
General information
Model: Suzuki GSF 600 Bandit
Year: 2000
Category: Allround
Rating: 70.9 out of 100. Show full rating and compare with other bikes
Displacement: 599.00 ccm (36.55 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 78.00 HP (56.9 kW)) @ 10500 RPM
Torque: 54.00 Nm (5.5 kgf-m or 39.8 ft.lbs) @ 9500 RPM
Starter: Electric
Cooling system: Air
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 208.0 kg (458.6 pounds)
Seat height: 800 mm (31.5 inches) If adjustable, lowest setting.
Wheelbase: 1,430 mm (56.3 inches)
Front brakes: Dual disc
Power/weight ratio: 0.3750 HP/kg
Fuel capacity: 19.00 litres (5.02 gallons)
Color options: Red, blue
Comments: As opposed to the GSF 600 S Bandit, the GSF 600 Bandit has no windshield.
13 Sep 2008, 13:00
Azi am inteles ca este o manifestare in Bucuresti legata de "aniversarea" unui an de la tragicul eveniment de pe calea Plevnei, cand vei 2 copii au murit striviti de o basculanta de 20 tone care a virat fara sa se asigure peste linia dubla continua!
Sper sa am poze ceva mai tarziu....si sper sa nu mai avem astfel de evenimente ...
Subiectul se discuta si aici... http://www.motociclism.ro/forum/index.p ... pic=264088
13 Sep 2008, 14:52
Brrrrrrrrrrrrrrr...
PS. Dupa ce cititi inceputul, cum a avut loc accidentul si ce se mai scrie pe acolo, cititi si ASTA. Este un mesaj (scris de pe nickul baiatului) al mamei fetei. Mie mi-au dat lacrimile!
PPS. Sunt vreo 60 de pagini, eu am ajuns pana la 13 si apoi am cautat un mesaj de la familie.
13 Sep 2008, 18:51
"Copiii nostri s-au inaltat la cer in plina iubire, dragoste si fericire, iar voi toti i-ati facut fericiti pentru ca nu i-ati uitat, chiar daca o parte dintre voi nu i-ati cunoscut, si le-ati fost alaturi.
Multumim tuturor pentru prezenta la inaltarea lor la 40 de zile. Ca parinti, noi am avut locul nostru in viata lor, dar lumea motoarelor era mai presus de orice pentru ei. Voi cei din lumea motoarelor, lumea tinerilor din ziua de astazi, sunteti lumea in care copiii nostri au trait cele mai minunate clipe. Multe va doriti in viata, sunt foarte greu de realizat, dar motorul il puteti avea prin munca voastra. Acest motor ramane un simbol al tineretii, Traian spunand deseori mamei lui ca motocicleta este viata lui, fiind ascultat si inteles de catre ea" - citat de pe forumul de motoare mentionat anterior, in care o mama indurerata isi plinge copila moarta in accident moto impreuna cu prietenul ei, calcati de o basculanta din vina soferului; cum poti spune tu ca parinte responsabil care ti-ai ingropat copilul ca lumea motoarelor era totul ptr ei cind chiar motorul baiatului le-a adus moartea?? Daca la majorat in loc sa-i dea bani de moto le lua o amarita de "conserva" poate ca mai pilpiia ceva viata in ei chiar si sub o basculanta! E o atitudine demna de mila dar se poate spune ca parintii copiilor i-au impins la moarte prin atitudinea incurajatoare fata de folosirea motocicletei; Romania nu e, oameni buni, o tara normala din nici un pct de vedere, cu atit mai putin al traficului - oamenii mor ff usor in acc de circulatie cu masini deci a sustine ca mersul cu motorul e o placere sau necesitate echivaleaza cu inconstienta si jocul cu schilodirea sau moartea! DUMNEZEU sa-i odihneasca pe copiii aia dar in acelasi timp sa-i odihneasca pe toti care mor in acc de circulatie ptr ca dpdv uman nu e nici o diferenta intre ei si, sa zicem, TEO PETER sau LAURA STOICA sau atitia anonimi ptr care nu mai face nimeni marsuri cu motoare turate prezentate la jurnalele de stiri. O viata pierduta e irecuperabila indiferent de mijlocul de transport care a curmat-o! Va rog sa intelegeti exact ce am vrut sa zic si va asigur ca nu vreau sa ofensez pe nimeni.
13 Sep 2008, 20:19
No comment...
http://www.realitatea.net/video_470581_ ... 47031.html
13 Sep 2008, 20:49
$1 scrie:$2aca la majorat in loc sa-i dea bani de moto le lua o amarita de "conserva" poate ca mai pilpiia ceva viata in ei chiar si sub o basculanta! E o atitudine demna de mila dar se poate spune ca parintii copiilor i-au impins la moarte prin atitudinea incurajatoare fata de folosirea motocicletei;
Mircea, nu ai citit toate posturile mamei. Mai are unul. Acolo ne spunea cum Traian nu a acceptat bani pentru moto, la fel nici Ela. Au muncit impreuna, chiar daca erau la scoala, sa stranga bani de motocicleta. Mie mi se pare admirabil modul in care mama fetei a inteles ca viata pe motocicleta era viata celor doi. NICAIERI, si subliniez asta, NICAIERI nu il acuza pe Traian de moartea fetei sale, chiar daca putea sa spuna ca din cauza lui, a hobby-ului si pasiunii lui pentru motor, fata ei e in ceruri azi. Tot ce spune este ca se iubeau si ca sunt impreuna acum. Ai citit si partea in care el ii daruise un inel de logodna? Probabil ca au facut nunta in ceruri. Inca o data spun, pe mine m-a impresionat pana la lacrimi.
13 Sep 2008, 20:53
$1 scrie:$2o comment...
Exista un singur lucru cu care nu-s de acord, cip: intrarea cu motocicletele in cimitir. Este lipsa de respect pentru familiile celorlalti morti. Motocicletele trebuiau sa ramana afara!
13 Sep 2008, 21:11
E adevarat ca nu am citit tot - nu ma tine moralul - dar fapt este fara a fi contrazis de nimeni ca tinerii au murit pe (din cauza) motor; daca tinea la educatia si viata copiilor le interzicea acest hobby pina cind ar fi putut deveni cit de cit apti sa mearga pe motor; eu acuz parintii de iresponsabilitate, lucru ptr care au platit si acest lucru le va insoti fiecare minut din viata pina cind vor muri - e un pret prea scump pe care un om il plateste - pacat...
14 Sep 2008, 00:23
deci este vina motociclistului ca un onanist a intors in loc nepermis???? asa o fi domne cum spui tu ,,parintii sunt vinovati ,ei sunt vinovati din lipsa de experienta ......dar de fapt problema este cu totul alta ..un taran nenorocit putind a ceapa care a sfidat total semnificatia dungii ...hai ca o labarim aiurea ...
RIP pt cei ce nu mai sunt printre noi ...
15 Sep 2008, 11:19
Si crezi ca daca parintii le interziceau motociclismul, nu se mai suiau pe motor? Esti cel putin naiv. Daca citesti pe acolo, si scrie ca cei doi nu au vrut sa primeasca bani de la parinti, au vrut sa il cumpere prin munca lor. Si amandoi erau pasionati, au pus bani impreuna.
Foarte emotionanta povestea intradevar, dar astea se intampla in numar asa de mare pentru ca suntem niste idioti.
15 Sep 2008, 11:35
Domnilor...prima poza cu Banditul .... sper sa ma pot sui pe el legal in cateva zile, dupa ce iau numerele rosii...
15 Sep 2008, 12:48
1. foarte ochioasa, s-o stapanesti sanatos si fara incidente neplacute =D>
2. cum ai adus-o pana la urma ? in Focus ?
3. ce mosmondeai p'acolo ? :D
15 Sep 2008, 13:03
Merci mult, asa sa fie!!
da, in focus, bagata in 2 :)) + o fata (prietena tipului din Italia). A stat ok, am avut niste "poliestirene" mai bune... pun poze deseara :)
Acolo puneam capacele la ulei, urma sa punem uleiul si sa o pornim. ca eram 2 ...mecanicul si cu mine :)
15 Sep 2008, 13:56
s-o stapanesti sanatos coane ,,pacat ca nu iti mai permite vremea sa vezi ce poate ...super jucaria =D>
15 Sep 2008, 18:36
Frumoasa foc, sa-ti traiasca! Dar, totusi, nu e cam rosie? :P Iar in privinta vremii, sa nu-ti faci probleme, am primit asigurari ca luna Octombrie va tine cu noi!
15 Sep 2008, 21:00
Iata si cateva de la demontare si impachetare :))
16 Sep 2008, 08:04
hai ca ai avut ceva de montat la ea ...sa-ti cumperi stander ,,vad ca are buloane pt stander si sta super pe el .mai ales iarna pt protectia cauciucurilor ...
16 Sep 2008, 08:58
Pai...licitez pe ebay ...astept niste preturi de transport. Ca vreau sa fie exact pentru buloane si nu din acela pentru sustinut bascula....
Nu am montat eu, eu doar am stricat la ea :)) .. am rugat un prieten care se pricepe un pic la Suzuki sa monteze...se pare ca a iesit super. Nu prea au ramas piese dupa montaj =))
mai vreau sa iau un crash bar (nu pads) si un paravant :D
PS: si alarma!!
16 Sep 2008, 09:06
crash bar ?? omu dar arata urat cu crash bar ..iti pui mai bine crash paduri lungi ..codita nu iti este ferita nici cu crash bar .... motorul fiind ferit in ambele cazuri ..dar este alegerea ta pana la urma ..oricum asteptam pozne ... ;) (facute cu aparatul foto ) :D
iar pt stander ,vezi ca pe SBZ vindea un tip standere fata+spate cu 100 eur. prindere tip V ,exact ce iti este tie recomandat .alea pt bascula se uzeaza destul de repede iar distanta dintre bare este mai mica ..risti sa o culegi de pe jos :-S
16 Sep 2008, 09:13
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=021 asta nu e bun!?!? :D
16 Sep 2008, 11:15
asta este sefu ...super meserias iar de pret NO COMMENT
16 Sep 2008, 13:22
Cip sa o stapanesti sanatos si fara evenimente nasoale!
Azi am avut prima ora la scoala. Deja pot sa ma urc pe una de-o mie :D
16 Sep 2008, 14:00
$1 scrie:$2ip sa o stapanesti sanatos si fara evenimente nasoale!
Deci...eu vreau sa ajung sa ne vedem la un suc....:)) :))
Merci de urare...hai..spor la scoala, baga tare ca sa ne vedem la intalniri...
16 Sep 2008, 14:18
chiar 1300 ,,o busa te prinde de minune .. :))
16 Sep 2008, 14:31
O ... fisa de 1000??? :D
In ritmul asta nu stiu daca mai ai ce conduce daca faci 5 ore. Ajunge! =)) =)) =))
16 Sep 2008, 18:13
Serios acum... mie aia de 125 mi s-a parut ca trage tare. Nu vreau sa ma gandesc ce faci cu o miara sau o busa. Cre' ca iti trebuie niste oo foarte mari... nu stiu... ma gandesc.
16 Sep 2008, 19:01
Orice motocicletă trage mult mai tare ca o mașină, d`oh, d-aia la una care are 180Kg și 100CP îți iese raportul "thrust" to weight similar unei mașini de 600-700CP. Dar unii preferă 600cc și 4 cilindri și 4 timpi pentru silențiozitate + lipsă de pâr-pâr-pâr-pâr-poc și lipsă de vibrații prea mari, nu înseamnă că ăia or să decoleze cu motorul. 1000cc poate este exagerat, depinde și ce vrea fiecare de la moto.
Acu` zi că te-ai speriat când i-ai dat gaz, nu o mai da în diverse :D
16 Sep 2008, 19:21
125 trage tare?? :)) ce? din benzina trage poate =))
Daca e Minsk ceva...atunci are 8-11 cai ... e un fel de bicicleta cu 2-3 oameni putere :))
Lasand gluma la o parte, eu cand m-am suit pe 400 am avut o revelatie, privitor la motoare in general. Cand cel mai bun prieten al meu si-a luat VN800 ... am dat in "benganeala" :)). Cum sunt si eu pe aproape...600 cu vreo 77 cai.
Sunetul de 4 in linie difera si te inspaimainta in acelasi timp, eu venind de pe un twin. V-ul ...ala e altceva ...
Asa ca Officer....abia astept sa te vad calare pe SV-u ....
17 Sep 2008, 10:21
Hahaha asta de scoala e o yamaha destul de noua. Nu stiu cati cai are dar oricum sunt limitate de instructor.
PS Instructorul mi-a recomandat un enduro pt bucale.
Răspunde
