Ce semnifica acel 'PFi' la motorul 2.0?
Mesajde mondeo.ro » 10 Ian 2009, 19:06
Am pus intrebarea in aceasta sectiune,fiindca este mai activa decat sectiunea dedicata Mondeo MK4.Daca nu am procedat corect,rog un moderator sa mute subiectul in alta sectiune.
Mondeo MK3 2.0TDCI 116cp HB
16.10.2016 = 366.780km! Turbo original, pompa inalta original. Injectia schimbata la 305.000km(!) si revopsita partial in 2014. In medie 500e/an filtre, ulei,piese si manopera(3 revizii/an). Arata si merge aproape ca in 2008 cand am luat-o.
Consum minim, calculat la pompa=5.8l/100km(urban, extraurban, autostrada) Viteza 80-140km/h pe nationale si 140-210km/h pe autostrada.
Consum mixt in prezent=6.9-7.3l/100km
Consum record:202km cu 8l =>4l/100km!!
mondeo.ro
Localitate: Timisoara(de fapt aproape de)
Maşina: Mazda 6 Sport GT CD140, 2008 / Ford Mondeo 2.0TDCi 116hp Ghia 2004/Ford Ka 1.3i 2006
VIN: wfblabnustiusorry
Re: Ce semnifica acel 'PFi' la motorul 2.0?
Mesajde cristi_k1 » 10 Ian 2009, 19:25
PFI inseamna Port Fuel Injection.
Citez ce am gasit:
"Port Fuel Injection, meaning fuel injector sprays into the port of the intake manifold.
The other type is TBI, throtle body injection. This type uses a central injector (or 2 injectors) that spay onto the throtle body butterfly.
PFI is the better injection of the two
PFI provides a homogeneous mixture due to the longer time which is available for mixture preparation. This ensures a good and stable combustion."
Ford Mondeo 2.0 TDCI Duratorq 136 cp x-trend..........MM-29-CRS
VW Passat B5 1.9 TDI 131 cp....................................MM-29-FLR
cristi_k1
Localitate: Cluj Napoca
Maşina: Ford Mondeo 2.0 tdci 2004 x-trend 136 cp
VIN: WF05XXGBB54E41129
Mesajde mondeo.ro » 10 Ian 2009, 21:11
=D> Multumesc,cred ca am priceput.Daca mai sunt si altii,care stiu si pe romaneste,va ascult si pe voi. :D
mondeo.ro
Mesajde Officer » 11 Ian 2009, 14:51
eu stiam ca vine de la particle filtering...
Officer
Elodia
Localitate: Ilfov
Maşina: Nu mai am ford :(
Mesajde octa » 12 Ian 2009, 12:34
cred ca officer are dreptate!
si eu stiam ca e vorba de prezenta filtrului de particule. doar pe motoarele diesel!
oricum dieselurile au injectoare separate pt. fiecare cilindru.
ce zice cristi este descrierea corecta a diferentei intre injectie monopunct si multipunct la benzinare... nu am vazut ca pe modelele familiale moderne ford (si nici ale altor producatori) sa se mai puna injectie monopunct...
daca e vorba de benzinar, abrevierea poate fi ce zice cristi...
Imagine >>> REGULAMENT FORUM
octa
Mesajde Smiley » 12 Ian 2009, 13:20
ala de la diesel nu e cumva DPF-ul? http://en.wikipedia.org/wiki/Dpf
Focus C-Max Ghia 2.0 TDCI
Smiley
Mesajde mondeo.ro » 12 Ian 2009, 14:48
Cred ca daca ar fi DPF ar scrie DPFi sau PFi DPF,cum scrie si la diesel-TDCi DPF.
Alte pareri?..
mondeo.ro
Mesajde DanielArdelian2 » 12 Ian 2009, 17:23
Studiind documentatia despre acest motor, n-am remarcat nimic special la el.
Deci cred ca PFi vine de la Port Fuel Injection - cunoscuta si sub numele de injectie indirecta multi-punct secventiala. Adica sistem clasic pentru benzinare.
Cred ca este doar o chestie de marketing.
La fel cum acum cativa ani, motoarele de pe Mondeo 3 se numeau Duratec HE SFi, Sequential Fuel Injection = adica exact acelasi lucru - injectie indirecta multi-punct secventiala.
LE: Nu stiu sa existe filtru de particule pe benzinar. Toate au catalizator clasic, nu s-a schimbat mare lucru de la Euro 2 incoace.
Mesajde mondeo.ro » 12 Ian 2009, 17:57
Cred a e vorba de un benzinar clasic fara artificii inutile.N-are filtru de particule.E echivaentul unui mutur mpi cum il gasim si la concurenta,de ex.Renault Laguna 2.0i.
mondeo.ro
