The 17-way connector Focus
Mesajde Muttley » 30 Noi 2005, 05:49
Salut! am tot cautat despre adaptoare pt 5000 rds-ul meu si din "greseala" am gasit pe net schema asta. Am vazut intrebari legate de acest conector la noi pe forum si m-am gandit ca ar putea fi de folos, daca va iese ceva dati si voi un semn
Pin 6 : AVC (Auto Volume Control) a speed signal for volume adjustment - White-with-green-stripe wire
Pins 11 and 12 : remote connections - White-with-black-stripe and brown-with-yellow-stripe wires - these are the 2 you want.
Pins 15 and 17 on mine are also connected. Pin 15 is an output signal from some radios used to provide an enable line to other modules. That wire on my Focus actually lights the reverse light if you power it - how handy! Pin 17 is an airbag sense I believe but I do not know the logic.
For pins 11 and 12 the resistance values are :
Volume down : 53.0 to 55.2 ohm
Volume up : 145.2 - 149.2 ohm
Seek up : 297.6 - 304.8 ohm
Seek down : 556.0 - 568.4 ohm
Mode (end button) : 1026.3 - 1048.1 ohm
Open circuit : 5006.1 - 5107.3 ohm
For completeness sake, and it may save you a few minutes wiring testing, here are the other 2 connectors.
Speaker 8 way (should be sorted by the ISO adaptor)
1 LF+
2 LF-
3 LR+
4 LR-
5 RF+
6 RF-
7 RR+
8 RR-
Power (7 way socket but harness may have 8 or 7-way shells)
1 Battery
2 Lamp return
3 Ignition
4 Illumination
5 Ground
6 Power ground
7 Switched A+ output from radio
Si ca mi-am amintit... din ce am mai citit pe ici colo pe focusuri se pot pune boxe 6x9 daca vreti calitate va recomand
1. Difuzoare Hertz HCX 690 (nu necesita modificari suplimentare la montatul in usi)
2. Subwoofer Hertz HBX 250 DS
3. Amplificator Audison SRX 5 (de mare exceptie)
4. Capacitor BSF 13 (Audison)
5. Matzaraia daca se poate sa fie de cea mai buna calitate de preferat sa cumparati kitul tot de la Audison
Am dat configuratia de mai sus deoarece am vazut pe forum tot felul de "shure cu semafoare" scuze dar aceasta este parerea mea referitor la acele statii cu luminite si tot felul de porcarii (stiti nu sufar manelele si tot timpul asociez acele statii cu dublucasetofoanele acelea tiganesti cu luminite in boxe din piata din care se aud tot felul de grobieni) COnsider exemplul de mai sus super discret, se monteaza in locul difuzoarelor stock ale masinii fara alte blabla-uri suplimentare iar calitatea este exceptionala am avut ocazia sa aud o asemnea configuratie.
Ar fi interesant daca ar incerca cineva sa recomande la o asemenea configuratie un HU (atentie am comanda la volan si nu prea sunt incantat de ideea de a renunta la ea)
Ford Focus 2001 1,8 TDDI 90CP Ghia Hatchback (tot cu numere de suceava :D)
Muttley
Mesajde Zanga » 30 Noi 2005, 13:06
Interesant, eu cautam ceva de genul asta, dar ma interesa si mufa pentru cd-changer in evetualitatea montarii unui mp3 player. Sau si mai direct, cum pacalesti head unitul sa creada ca are magazia conectata (intre ce pini trebuie sa faci scurt) si pe urma e foarte simplu sa te legi la cele 3 fire de semnal audio
PS: Am auzit ca si prin "Tel Mute"- car kit sau ceva de genul potzi sa te legi la un alt device. Dar il lipsa unei scheme .......
Zanga
Gas Guzzler
Mesajde lbanias » 30 Noi 2005, 17:01
Am io o schema in germana, numai ca re sa asteptati o sapt ca mi-e laptopul la service si la desktop ajung numa in weekend...
2001 Focus Turnier Futura TDDI 90 CP
lbanias
Mesajde Zanga » 30 Noi 2005, 23:26
asteptam asteptam :icon_eek: :icon_eek: :icon_eek: ........
Zanga
Gas Guzzler
Mesajde lbanias » 01 Dec 2005, 15:13
Loatz d-acia...
Unde-i contul ala de mail ca sa bag si io documentatii ce am ? De fapt imi trebe parola de la cineva de aici parca...
lbanias
Mesajde Zanga » 01 Dec 2005, 16:07
$1 scrie:$2oatz d-acia...
Trimite-mi un mesaj privat cu mailul pe yahoo sa te includ in grup si acolo gasesti si contul de gmail unde facem upload la documentatzii :icon_cool:
Zanga
Gas Guzzler
Mesajde Zanga » 02 Dec 2005, 13:42
Te pricepi la germana ??????? :icon_eek:
Zanga
Gas Guzzler
Mesajde lbanias » 03 Dec 2005, 04:42
ein bisschen... banuiesc de ce ma intrebi, o sa incerc sa-l traduc...
lbanias
Mesajde Zanga » 03 Dec 2005, 15:19
Danke schon :icon_mrgreen: . Mai departe nu mai stiu :icon_mrgreen:
Zanga
Gas Guzzler
Re: The 17-way connector Focus
Mesajde vane » 02 Ian 2006, 02:55
$1 scrie:$2i ca mi-am amintit... din ce am mai citit pe ici colo pe focusuri se pot pune boxe 6x9 daca vreti calitate va recomand
Alpine are adaptorul care te-ar putea interesa, iar Clarion o sa scoata unul prin februarie.
Ce zici de ideea de a pune un JL in loc de Hertz numai pentru bass ?
Oops ! Inca una: Vrei sa pui coaxiale pe fata ? :icon_eek:
vane
