NEW! Vand casetofon JVC KW-838 (MP3,Caseta digitala, Radio)
Mesajde nightmoon » 26 Mar 2006, 21:41
Contact: Adrian 0722509456, andro_x@yahoo.com
http://shop.ryda.com.au/main_itemdetail ... lutePage=1
Nou, la cutie+documentatie, doar 650 RON
[b]JVC KW-838 ( este cat 2 casetofoane normale, adica se potriveste pe anumite masini care au 2 sloturi libere)
Product Detail:[/b]
· Power Output: 180W (45W x 4)
· 1-Bit DAC (24-bit Resolution)
· CD/CD-R/CD-RW Compatible
· MP3 Compatible
· 3-Band Parametric iEQ
· Line Output Terminals (x 2 pairs)
· Front AUX IN
· Dot-Matrix Multi-Colour Display with Contrast Control
· Full Logic Deck Mechanism
· Dolby B NR
· Station Name Registration
· CD Stacker Control
· Oval-Shaped Wireless Remote Control
CD Section
· CD Text
· Disc Name Registration
· Direct Track Access (1-12)
· Random/Repeat Play
· Intro Scan
· +/-10 Key
Changer Control Section
· CD Text*
· Direct Disc Select (1-12)
· Random/Repeat Play (2 modes)
· Intro Scan (2 modes)
· Skip/Search
* In Conjunction with CH-X1500
Cassette Section
· Auto-Reverse
· Grooved EHP Head
· Multi Music Scan (1-9)
· Repeat Play
· Blank Skip
· Key-Off Release/Key-On Play
Tuner Section
· HS-II Tuner
· 18 FM and 6 AM Presets
· SSM (for FM)
· Seek (Up/Down)/Scan (Up)
· AFNS/PNC
· Stereo/Mono Switch (for FM)
· Auto Antenna
· EX Switch
Amplifier Section
· Balance/Fader Control
· Bass Boost
· Electronic Volume Control
· Volume Attenuator
Display Section
· White LED Backlight
· Switchable Dimmer
· Level Meter
· Power Switch Standby Illumination
General Section
· COMPU PLAY
· Power-Off Mode Eject
· Preferred Setting Mode
nightmoon
Mesajde DVD » 27 Mar 2006, 01:12
Ce siguranta are? Cod, ceva, ca presupun ca nu se scoata fatza....
Ex-Scorpio 2.3I 16V Ghia 1996
Peugeot 407 1.8E, 2008
DVD
