Placa audio
Placa audio
Mesajde Grasu » 08 Mar 2008, 11:54
Vand placa audio Terratec DMX 6 FIRE 24/96 ...in stare perfecta de functionare
placa este compusa din 2 bucati...1- PCI , 2 -Front Bay....
multiple iesiri si intrari printre care si optic si rca
claritate impecabila....
Pret 250 RON
mai multe detalii la 0763.10.72.24
Grasu
Re: Placa audio
Mesajde Grasu » 11 Mai 2008, 15:30
s-a ieftinit placa...e 150 ron...vreau sa o dau ca mi-am luat altceva si nu am ce sa fac cu asta...decat sa "sterg praful de pe ea "....
Grasu
Re: Placa audio
Mesajde 2fast4you » 22 Sep 2008, 23:05
salut... placa este inca de vanzare...tot la 150 RON...nu ma mai pot loga cu acel user asa ca....daca sunteti interesati...0730.44.88.87....
2fast4you
Maşina: vw bora
Re: Placa audio
Mesajde 2fast4you » 28 Sep 2008, 10:30
Cam asa ceva stie sa faca placa asta de sunet....e super buna...oferta inca valabila....
150 ron...
Technical Details:
• PCI-board
• 3 analog stereo outputs (3,5 mm jack) 24 bit/96 kHz
• 1 analog stereo input (3,5 mm jack) 24 bit/96 kHz
• 2 analog CD-Audio outputs (Molex, On-Board) 24 bit/96 kHz
• 1 analog AUX input (Molex, On-Board) 24 bit/96 kHz
• 1 digital CD-Audio TTL input (Molex, On-Board)
• 1 analog stereo input (Cinch) on front module - 24 bit/96 kHz
• 1 analog stereo output (Cinch) on front module - 24 bit/96 kHz
• 1 analog stereo phono (MM, 6 mV ) input (Cinch) on front module- 24 bit/96 kHz
• 1 analog mono microphone input (6,3 mm jack) on front module – 24 bit/96 kHz
• 1 analog stereo headphone output (6,3 mm jack) on front module – 24 bit/96 kHz
• 1 digital stereo in- and output (TOS-Link, optical) on front module – 24 bit/96 kHz
• 1 digital stereo in- and output (Cinch, coaxial) on front module – 24 bit/96 kHz
• 1 MIDI in- and output (5-pin DIN) on front module
• Control range of : 9 mV – 500 mV
• Output power of headphone output : 60 mW
• Bus master transfer supports ‚24 bit 4 byte mode‘ (32bit)
• Simultaneous recording and playback of all channels with up to 24 bit/96 kHz
• 24 bit/96 kHz AD converters with 100 dB dynamical range (S/NR)*
• 24 bit/96 kHz DA converters with 110 dB dynamical range (S/NR)*
• 24 bit/96 kHz stereo digital input (S/PDIF with up to 24 bit/96 kHz)
• 24 bit/96 kHz stereo digital output (S/PDIF with up to 24 bit/96 kHz)
• Digital input may also be used for digital audio output of an internal CD-Rom drive (TTL)
• Input control of AD converters with +18 dB increment in 0,5 dB steps
• Hardware with internal resolution of 36 bit
• VU-meter in control panel (hardware based)
• „None-Audio“ mode for transmission of AC3 and DTS streams via digital interface
Software
• WDM driver for Windows 98SE/ ME/2000 and Windows XP supports ASIO 2.0
• WDM Kernel Streaming (e.g. for Sonar ™)
• MME- and DirectSound
• DirectSound 3D, Sensaura 3D, A3D 1.0/2.0 and EAX 1.0/2.0 as well as Macro FX**
• ControlPanel for Windows 98SE/ME/2000 and Windows XP
2fast4you
Maşina: vw bora
Re: Placa audio
Mesajde rocorobert » 28 Sep 2008, 11:51
nici nu stim de unde esti......
Ford Focus 2001; 1,8 TDCI
rocorobert
Maşina: Ford Focus Tdci
VIN: WF0AXXGCDA1D18331
Re: Placa audio
Mesajde VIPER » 28 Sep 2008, 12:27
Pai pana la urma Grasu si 2fast4you sunt unul si acelasi user?
VIPER
Localitate: Bucuresti, RO
