CPU Intel - doar pt cunoscatori - si alte componente!
Mesajde BRZ » 11 Feb 2009, 11:39
Vand:
Procesor - 700 LEI
Intel Core 2 Duo E6700, 2666 MHz (10 x 267)
Alias procesor Conroe
CPU stepping B1
Setul de instructiuni x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Frecventa 2667 MHz
Multiplicator CPU Min / Max 6x / 10x
Engineering Sample Da
Cache L1 32 KB per core
Date cache L1 32 KB per core
Cache L2 4 MB (On-Die, ECC, ASC, Full-Speed)
Viteza ceasului extern 266 MHz
Viteza maxima a ceasului 3800 MHz
Viteza curenta a ceasului 2660 MHz
(INCLUS IN PRET COOLER ASUS TRITON 85 http://www.asus.com/products.aspx?l1=16 ... odelmenu=2)
Placa de baza - 200 LEI
P5B PREMIUM VISTA EDITION
Slot/socket procesor 1 LGA775
Sloturi extinse 3 PCI, 1 PCI-E x1, 2 PCI-E x16
Sloturi RAM 4 DDR2 DIMM
Dispozitive integrate Audio, Dual Gigabit LAN, IEEE-1394
Form Factor ATX
Dimensiunea placii de baza 240 mm x 300 mm
Chipsetul placii de baza P965
Caracteristici suplimentare Asus Intelligence, JumperFree, Q-Fan 2, ScreenDuo, Stepless Freq Selection, SATA-II, RAID
HDD - 150 LEI
SEAGATE ST3320620AS ATA Device (320 GB, 7200 RPM, SATA-II)
RAM - 150 LEI
2 * 1024MB DDR2-800 DDR2 SDRAM KINGMAX
PLACA VIDEO - 500 LEI
ASUS EN8800GTS-Top/HTDP/512M
Nume de cod GPU G92GTS
Tip bus PCI Express 2.0 x16 @ x16
Capacitatea memoriei 512 MB
Ceas GPU (Geometric Domain) 738 MHz (original: 740 MHz)
Ceas GPU (Shader Domain) 1782 MHz (original: 1800 MHz)
Ceas RAMDAC 400 MHz
Pixel pipeline 16
TMU per pipeline 1
Unified Shaders 128 (v4.0)
SET BOXE 5.1 - 200 LEI
GENIUS SW-HF 5.1 5000, 5000W PMPO, (SUBWOOFER 75W + 5 SATELITI 15W), WOODEN SUBWOOFER, RC, 40Hz-20KHz, WOOD COLOR, DARK BROWN
SE POT OFERI BONUSURI PENTRU COMBINATII DE GEN "MB+CPU" SAU "MB+VGA"
PENTRU MAI MULTE DETALII VA STAU LA DISPOZITIE!
viewtopic.php?f=108&t=32938
FIESTA 1.4 TDCI 12.2007 GHIA PANTHER BLACK
WF0HXXGAJH7P44402
BRZ
Maşina: FIESTA 1.4 TDCI 12.2007 GHIA PANTHER BLACK
VIN: WF0HXXGAJH7P44402
Re: CPU Intel - doar pt cunoscatori - si alte componente!
Mesajde nairpic20 » 11 Feb 2009, 13:33
salut! m-ar interesa pe mine(fara boxe), dar mai umbla la preturi(la unele ai preturile de magazin)
 Ford Mondeo 2.2 TDCI 200CP VIN: WF0EXXGBBEBE03739 
 Ford Mondeo Tournier 2.0 TDCI 115CP, 07/2005 VIN:WF0WXXGBBW5A37593 
nairpic20
Localitate: Cluj Napoca
Maşina: Ford Mondeo 2.2 TDCI 200CP :)
Mesajde xdocx » 11 Feb 2009, 13:41
poate ma bagam si eu, dar nu sunt cunoscator.
sunt profan in ale PC-ului
asa ca..............
xdocx
Mesajde BRZ » 11 Feb 2009, 13:49
Am uitat sa mentionez locatia BUCURESTI.
Pretul memoriilor este intr-adevar gresit. Pret nou 100 Lei pt amandoua.
WF0HXXGAJH7P44402
BRZ
Mesajde nairpic20 » 11 Feb 2009, 14:00
ce iti ofer eu:
---procesor + cooler (5mil)
---placa de baza(150ron)
---hdd(120ron)
---ram(nu, nici macar 50ron nu merita)
---video(daca mai ai garantie pe ea iti dau 500)
---boxe(nu)
componentele le-ai avut pe sistemul tau???
nairpic20
Mesajde BRZ » 11 Feb 2009, 14:15
$1 scrie:$2e iti ofer eu:
---procesor + cooler (5mil) - ok
---placa de baza(150ron) - ok
---hdd(120ron) - ok
---video(daca mai ai garantie pe ea iti dau 500) nu are garantie
---boxe(nu)
toate componentele sunt intr-un sistem functional - al meu - care ocupa mult spatiu...
esti in bucuresti?
WF0HXXGAJH7P44402
BRZ
Mesajde nairpic20 » 11 Feb 2009, 14:21
nu, asta e partea nasoala. ai cumparat componentele separat sau sistemu intreg? eu sunt din iasi, dar s-ar putea sa trec prin bucuresti sapt asta(cred)
nairpic20
Mesajde BRZ » 11 Feb 2009, 14:27
Anunta-ma daca te hotarasti si daca ajungi in Bucuresti.
Sansele ca eu sa ajung in Iasi sunt neglijabile.
WF0HXXGAJH7P44402
BRZ
Mesajde nairpic20 » 11 Feb 2009, 14:51
o sa iti zic maine. bafta la vanzare pana atunci :D
nairpic20
Mesajde BogdanFSB » 11 Feb 2009, 15:10
salut...te intereseaza un schimb cu lap-ul meu? viewtopic.php?f=111&t=27312 ...nu ma intereseaza boxele tale
BogdanFSB
Moderator
Mesajde BRZ » 11 Feb 2009, 15:19
sorry, am deja laptop.
WF0HXXGAJH7P44402
BRZ
Mesajde BRZ » 13 Feb 2009, 23:34
salutare tuturor,
mai este disponibil doar procesorul si e la oferta (restul s-au vandut)
Procesor - 700 LEI
CPU stepping B1
Frecventa 2667 MHz
WF0HXXGAJH7P44402
BRZ
Mesajde chiar_el » 14 Feb 2009, 23:10
Cam foarte scump procesorul tau....
http://www.price.ro/index.php?action=pr ... 3648&asc=1 il gasesti de la 443 lei, tva inclus
chiar_el
Maşina: Ford Kuga
VIN: WF0FXXWPMFNR59554
Mesajde BRZ » 14 Feb 2009, 23:46
De acord... nu te obliga nimeni sa cumperi un produs daca nu intelegi exact natura acelui produs.
Daca "Engineering Sample" nu-ti spune nimic - ok e scump.
Ca sa nu mai vorbim de cooler care costa cam 200 lei...
WF0HXXGAJH7P44402
BRZ
Mesajde chiar_el » 15 Feb 2009, 00:23
Coolerul e doar 127 lei (http://www.myhardware.ro/index.php?targ ... ct_id=1040), iar faptul ca procesorul nu mai are coolerul original inseamna adio garantie. Si mai tine cont ca la preturile specificate se emite factura si contin tva (19%). Iar "Engineering Sample" imi spune ca e un produs beta, un produs de test, ce poate avea probleme ascunse, rezolvate in produsul de serie
chiar_el
Maşina: Ford Kuga
Mesajde BRZ » 15 Feb 2009, 10:55
am inteles, nu te intereseaza.
WF0HXXGAJH7P44402
BRZ
Mesajde adicristea » 15 Feb 2009, 11:20
Ca sa fim corecti, nu cel postat de chiar_el este procesorul, ACESTA. Insa pretul e tot pe acolo (713 ron cel mai ieftin, in varianta BOX).
Are garantie?
adicristea
Localitate: Reading, UK
VIN: 00000000000000000
Mesajde BRZ » 15 Feb 2009, 11:28
nu are garantie
in 1-2 ore anunt daca mai e valabil. e aproape vandut.
WF0HXXGAJH7P44402
BRZ
Mesajde leut27 » 15 Feb 2009, 13:31
$1 scrie:$2oolerul e doar 127 lei (http://www.myhardware.ro/index.php?targ ... ct_id=1040), iar faptul ca procesorul nu mai are coolerul original inseamna adio garantie. Si mai tine cont ca la preturile specificate se emite factura si contin tva (19%). Iar "Engineering Sample" imi spune ca e un produs beta, un produs de test, ce poate avea probleme ascunse, rezolvate in produsul de serie
cum adica adio garantie daca procesorul numai are colerul box? de unde ai venit cu traznaia asta
fals
sunt doua produse care se vand separat dar , daca procesorul se strica nu ti se cere la garantie si coolerul
Engineering Sample" imi spune ca e un produs beta, un produs de test, ce poate avea probleme ascunse, rezolvate in produsul de serie[/quote] de obicei asta inseamna ca aceste procesoare nu sunt de serie deci au probleme
leut27
Mesajde BRZ » 15 Feb 2009, 14:57
Engineering Sample inseamna produs facut special pt teste (un produs in baza caruia se scriu review-uri) cu mare atentie si testat la sange inainte sa iasa din fabrica. in plus Engineering Sample insemna ca procul are multiplicatorul deblocat by default si poti face cam ce vrei cu el...
Nu mai conteaza insa - toate produsele postate aici au fost vandute, le doresc celor care le-au cumparat sa le foloseasca sanatosi!
Rog un moderator sa inchida acest topic.
WF0HXXGAJH7P44402
BRZ
