VAND Nikon D100 + Sigma 18-200
Mesajde gabi_fiesta » 07 Iul 2009, 15:39
Vand aparat Foto NIKON D100
http://www.dpreview.com/reviews/nikond100/
Obiectiv Sigma 18-200 /f3.5- 6.3
Grip MB B100, 2 baterii
Un obiectiv nikon 18-55 3.5 5.6 dar merge doar pe mf
incarcator rapid , filtru UV HoYA,gentutza , carduri..
Toate originale date in Japan .
Pret 2100 lei.
gabi_fiesta
Maşina: Ford Fiesta 1.3 70cp
VIN: WF0HXXGAJH4S20298
Re: VAND Nikon D100 + Sigma 18-200
Mesajde gabi_fiesta » 08 Iul 2009, 13:56
UP
gabi_fiesta
Mesajde gabi_fiesta » 08 Iul 2009, 19:23
Nikon D100
Optical Format 1.8" / diagonal 28.4 mm (APS sized)
Aspect Ratio 3:2
Colour filters Primary GRGB (Bayer Mosaic)
Transfer method Interline frame readout (requires mechanical shutter)
Total number of pixels 3110 x 2030 (6.31 million)
Number of effective pixels 3032 x 2016 (6.11 million)
Active pixels 3000 x 2000 (6 million square pixels)
Active imager area 23.4 x 15.6 mm
Unit cell size 7.8µm x 7.8µm
Optical black Horizontal: Front 20 pixels, Rear 50 pixels
Vertical: Front 4 pixels, Rear 2 pixels
Saturation signal 900 mV
Smear -80 dB
Frame rate 3.06 fps (single channel mode)
5.09 fps (dual channel mode)
Sensor CCD, 23.7 x 15.6 mm
Sensor total pixels 3110 x 2030 (6.31 megapixel)
Sensor effective pixels 3026 x 2018 (6.11 megapixel)
Final image size 3008 x 2000 (RAW images are recorded as 3034 x 2024)
Sensor CFA Primary (GRGB)
Pixel pitch 7.8 µm x 7.8 µm
Analog to digital converter 12-bit
Optical filter IR cut & Optical LPF (uses LiNB)
Sensitivity • Auto (200 - 1600) - enabled via custom func.
• ISO 200
• ISO 250
• ISO 320
• ISO 400
• ISO 500
• ISO 640
• ISO 800
• ISO 1000
• ISO 1250
• ISO 1600
• HI-1 (~ISO 3200)
• HI-2 (~ISO 6400)
Image sizes • 3008 x 2000 (L)
• 2240 x 1488 (M)
• 1504 x 1000 (S)
Image formats • JPEG (EXIF 2.2) - Fine, Normal, Basic
• TIFF RGB (EXIF)
• Uncompressed RAW (12-bit per pixel)
• Compressed RAW (12-bit per pixel)
Recorded pixels • JPEG/TIFF - 3008 x 2000
• RAW - 3034 x 2024
Color mode • I (sRGB)
• II (Adobe RGB)
• III (sRGB - stronger greens & blues for colourful landscapes)
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type/G-type AF Nikkor: All functions possible
• D-type Manual-Focus Nikkor: All functions except autofocus possible
• AF Nikkor other than D-type/G-type: All functions possible except 3D Matrix Metering
• AI-P Nikkor: All functions except 3D Matrix Metering and
autofocus possible
• Non-CPU: Usable in [M] mode (camera's built-in exposure meter does not work)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster; IX-Nikkors cannot be used.
Field of view crop 1.5x (also known as focal length multiplier)
Autofocus TTL phase detection, Nikon Multi-CAM900 autofocus module; Detection range: EV -1 to EV 19 (ISO 100 equivalent, at normal temperature: 20°C/68°F)
AF Area mode • Single Area AF
• Dynamic AF (Closest Subject Priority is available)
AF Illuminator Lamp, range 0.5 - 3 m (1.6 - 9.8 ft).
Focus area One of five areas can be selected
Lens servo • Single Servo AF (S)
• Continuous Servo AF (C)
• Manual focus (M)
Focus lock Focus is locked by pressing AE-L/AF-L button or lightly pressing shutter release button in (S) AF
Metering • 3D Matrix Metering with 10-segment SPD
• Center-Weighted Average
• Spot
Metering range • Matrix: 0 - 21 EV
• Center-Weighted Average: 0 - 21 EV
• Spot: 3 - 21 EV
(Normal temperature with F1.4 lens)
Exposure mode • [P] Auto-Multi Program (Flexible Program possible)
• [S] Shutter-Priority Auto
• [A] Aperture-Priority Auto
• [M] Manual; shutter speed/aperture adjustable in 1/2 or 1/3 EV steps
ISO Automatic Control Mode (Custom setting) is available in any exposure mode (P, S, A, M)
Exposure compensation +/-5 EV in 0.3 or 0.5 EV steps
AE Lock Detected exposure value locked by pressing AE-L/AF-L button
AE Bracketing • Number of shots: two or three
• Compensation steps: 1/3, 1/2, 2/3 or 1 step
Shutter type • Electronic controlled vertical slide FP shutter
• Speed: approx. 6.3 m/s (equiv. to 24 mm)
• Curtain direction: bottom to top
• Number of blades: 4 blades each (front & rear)
• Blade material :aluminium
• Blade color: Front: Grey (50% +/-5%), Rear: Black
Shutter speed Bulb, 30 sec - 1/4000 sec (1/3 EV steps)
Depth-of-field preview Button, stops-down lens aperture
X-Sync shutter speed Up to 1/180 sec
Shooting modes • Single frame (S)
• Continuous shooting (C)
• Self-timer mode
Continuous mode • 3008 x 2000 RAW, 3 fps, max ~3 frames
• 3008 x 2000 TIFF, 3 fps, max ~5 frames
• 3008 x 2000 JPEG Fine, 3 fps, max ~6 frames
~ = approximately
Self-timer • 2 sec
• 5 sec
• 10 sec (default)
• 20 sec
White balance • Auto
• Incandescent *
• Fluorescent *
• Sunlight *
• Flash *
• Cloudy *
• Shade *
• Preset
* Can be fine tuned +/-3 levels
White balance bracketing Yes
Sync contact X-contact only
Flash control • D-TTL (Automatic Balanced Fill-Flash controlled by five-segment TTL Multi Sensor ) with built-in Speedlight and external Speedllight such as SB-80DX/28DX/50DX: three modes available
• Non-TTL Auto Flash with an external Speedlight
Flash sync mode • Front-Curtain Sync (normal sync)
• Red-Eye Reduction
• Red-Eye Reduction with Slow Sync
• Slow Sync
• Rear-Curtain Sync
Built-in Speedlight • Manual pop-up type, GN: 11/36 (ISO 100, m/ft.)
• Sensitivity range: ISO 200 - 1600 equivalent
• Sync flash system with external Speedlight: Not available
• Ready light indicator inside viewfinder
Viewfinder Optical-type fixed-eye level pentaprism; built-in diopter adjustment (-2 to +1 m-1)
Viewfinder eyepoint 24 mm (at -1.0 m-1)
Viewfinder frame coverage Approx 95%
Viewfinder magnification Approx. 0.8x with 50mm lens set to infinity and -1.0 m-1
Viewfinder information Focus indicator, Metering mode, AE Lock, Shutter speed, Aperture value, Exposure indicator, Exposure compensation, Flash output level compensation, frame count etc.
Focusing screen B-type Bright View Clear Matte screen II
Focusing screen information • Focus frame
• Grid lines
• Center-weighted metering area
Shooting memory banks • A
• B
Image sharpening • Auto
• Normal
• Low
• High
• None
Tone compensation • Auto
• Normal
• Less contrast
• More contrast
• Custom
Hue adjustment • -3 to +3 in 1 increments
Settings memory banks Two: A & B
Storage CompactFlash Type I/II
Microdrive compatible Yes
LCD monitor 1.8" 118,000 pixel TFT (100% frame coverage)
Compliance • DCF
• DPOF
• ExifPrint (EXIF 2.2)
Playback functions • Single image
• 4 or 9 thumbnails
• Magnified playback
• Slide show
• Histogram indication
• Highlight point display
Custom func. memory banks • A
• B
Custom functions • 24 functions
Image comment Can be input and automatically attached to image
Video output NTSC or PAL selectable
Connectivity USB 1.1
Voice memo Only with optional multi-function battery pack
Remote control Only with optional multi-function battery pack
Power • Lithium-Ion battery pack EN-EL3 (7.4V, 1400 mAh)
• AC Adapter EH-5
• Multi-function battery pack MB-D100
Dimensions 144 x 116 x 81 mm (5.7 x 4.6 x 3.2 in)
Weight (no battery) 700 g (1.5 lb) - approx.
Included Software Nikon View 5
Optional accessories Multi Function Battery Pack MB-D100, Li-ion Battery Pack EN-EL3, Charger, MH-18/19, AC Adapter EH-5, CompactFlash™ Cards, Speedlight SB-80DX/SB-28DX/SB-50DX, Semi-Soft Case CF-D100, Nikon Capture 3
MB-D100 Battery pack Additional function: Sound record/play, 10pin terminal
Operating buttons: Shutter Release button, Lock-lever, Main command dial, Sub command dial, AE/AF-L button & Focus area selection button, Sound record/playback button, Battery chamber cover, Attachment wheel
Display: Sound record/playback display LED
gabi_fiesta
Mesajde gabi_fiesta » 09 Iul 2009, 14:19
Up !
gabi_fiesta
Mesajde ALEKSS » 09 Iul 2009, 14:23
sincer e scump nu te supara e vechi
mai bine il pastrezi decat sa lasi cat trebuie la pret
ALEKSS
Localitate: PLOIESTI
Maşina: FORD FOCUS 2012 - 1.0 125cp
VIN: WF0KXXGCBKCE11148
Mesajde gabi_fiesta » 09 Iul 2009, 16:39
sa zicem ca ai dreptate ...cat costa un grip ? ai idee ? 2 baterii?
cat face un body?
un filtru pe 62 HOYA de sticla UV?
un obiectiv Sigma ?
poate esti mai in masura si stii? si fa tu un pret... si apoi negociem
Oricum totul e nogociabil in Romania ... :D
gabi_fiesta
Mesajde gabi_fiesta » 10 Iul 2009, 12:25
Up
gabi_fiesta
Mesajde gabi_fiesta » 14 Iul 2009, 08:30
1990 lei
UP
mai negociez daca il ia cineva pasionat de fotografie
gabi_fiesta
Mesajde shine » 14 Iul 2009, 11:56
si tu cu ce o sa mai faci poze la gagici pe strada? :D
un fel de up... :)
shine
Membru reincarnat
VIN: EuPreferDemisecul
Mesajde gabi_fiesta » 14 Iul 2009, 12:16
Multumesc !
Probabil ma voi apuca de ceva mai serios...nu sa le fac foto la fete pe strada :D
gabi_fiesta
Mesajde shine » 14 Iul 2009, 12:37
am si eu un prieten care a bagat vreo 90 de milioane intr-un aparat, nikon chiar. si acum s-a apucat de facut poze la nunti.
shine
Membru reincarnat
Mesajde gabi_fiesta » 14 Iul 2009, 12:43
pt nunti mai imi trebuie un obiectiv si un blitzz si gata
dar nu cred ca am rabdare pt asa ceva
si nu risti sai face pozele varza .... mai ales ca plateste... dar pana la urma faci 1200 poze si ies 500 bune :)
gabi_fiesta
Mesajde gabi_fiesta » 15 Iul 2009, 09:12
Up
gabi_fiesta
Mesajde gabi_fiesta » 16 Iul 2009, 11:19
Up !
Negociabil !
gabi_fiesta
Mesajde gabi_fiesta » 14 Oct 2009, 19:45
Up
gabi_fiesta
Mesajde gabi_fiesta » 24 Noi 2009, 19:19
Up 1800 lei
gabi_fiesta
Mesajde gabi_fiesta » 24 Noi 2009, 19:25
Bonus:
Filtru HOYA UV 62 mm
Parasolar 62 mm
Obiectiv Nikon 18-55 , nu mai face Af doar manual
Card 2G + 4 x 256M
Aparatul se vinde cu: 2 acumulatori EN-EL3,incarcator, cablu USB, curea, capac de corp.
Obiectiv Sigma 3.5-6.3 ,husa, parasolar si capace.
gabi_fiesta
Mesajde gabi_fiesta » 25 Noi 2009, 15:05
Up
gabi_fiesta
Mesajde gabi_fiesta » 27 Noi 2009, 18:49
Up
gabi_fiesta
Mesajde gabi_fiesta » 07 Dec 2009, 14:36
gabi_fiesta
Mesajde gabi_fiesta » 09 Dec 2009, 15:32
Up
gabi_fiesta
Mesajde gabi_fiesta » 16 Dec 2009, 12:39
gabi_fiesta
Mesajde gabi_fiesta » 17 Dec 2009, 16:32
1699 lei
gabi_fiesta
Mesajde gabi_fiesta » 04 Ian 2010, 13:15
gabi_fiesta
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 65 vizitatori
În total sunt 65 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 65 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
