Vand Statie Amplificator Crunch 1x450w sau 2x160W Rms
Mesajde killer666 » 30 Aug 2009, 11:11
Designed to deliver big power on demand, V-Drive offers incredible performance in a sweet visual design including illuminated VU's monitoring power output, a mesh grille ventilation system to keep your system running cool, and killer chrome finishing to top it off. Performance is earth shaking. These fully bridgeable class A/B amplifiers come in a variety of power configurations including two, four, and even mono channel designs.
V-Drive Blue Anodized Inverted Heat Sink Design
Dual VU Metering System with
Acrylic Lens
Mesh Grille Ventilation Design
Chrome Heat Sink Cover
PWM Mosfet Power Supply
Fully Bridgeable Design
Blue High Quality PCB Design
Ultra—Drive High Speed Mosfet Output Devices
Class AB Operation
On Board Tru-Spec Capacitors
Premium Hand Wound Torroid
Separate Bass and Treble Controls
Bass/Treble On/Off Switch
HP (High Pass) from 10 Hz to 30 KHz Adjustable Crossover Network with Subsonic Filter
HP/LP/Flat Select Switch
LP (Low Pass) from 40 Hz to 4 KHz Adjustable Crossover Network
Gold Plated RCA Line Input
Gold Plated RCA Line Output for Amplifier Daisy Chaining
Internal Protection—Thermal, Short Circuit, Overload Circuitry
Red Protection LED
Green "On"LED
Maxeffekt: 1x450 watt 4 ohm
Effekt RMS 4Ohm: 2x110 wrms 4 ohm/ 2x160 wrms 2 ohm. 2x150 WMAX 4 ohm/ 2x225 WMAX 2 ohm.
Equalizer: bassboost 12dB vid 45 Hz
Delningsfilter: högpass 10Hz-2,5kHZ, lågpass 40Hz-4kHz.
Frekvensomfång: 10Hz-30kHz
Signalbrus: >90dB
Ingångskänslighet: 0,2-6 volt
Pret 300RON Nediscutabil
Yahoo ID: Robert69299
TEL:0721.204.915 Robert
statia nu are urme sau zgarieturi si functioneaza perfect(nu sa umblat in ea)
killer666
Re: Vand Statie Amplificator Crunch 1x450w sau 2x160W Rms
Mesajde killer666 » 15 Sep 2009, 08:43
SOLD , se poate inchide!
killer666
