vand statie,sub,condensator si procesor de sunet auto
Mesajde KnupZ » 06 Oct 2009, 13:12
Amplificator monobloc clasa D kenwood kac-9152D
Statia a fost adusa personal din state si folosita pe masina mea
KAC-9152D main features:
1,800 Watts max power
500 Watts x 1 max (4 ohms) RMS
900 Watts x 1 (2 ohms) RMS
900 Watts x 1 (1 ohms) RMS
Wired remote control to adjust boost level and frequency included
'Dual mono drive' configuration option (requires two KAC-9152D amplifiers & specialist knowledge!)
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct) to cut unwanted ultra-low frequencies
'Kenwood logo triangle' design power indicator LED
1 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Power MOSFET switching power supply
'D' class amplification circuits throughout, using switching techniques instead of the linear methods used in Class 'A' or 'B' type amplifiers. Class 'D' is a significantly more efficient than Class 'A' or 'B', resulting in greater power with less heat generation, higher stability and improved reliability
2 x 30 amp power supply fuses
Dimensions (WxHxD) : 380 x 61 x 286 mm
Complete with full fitting and operating guide
pret 1000 lei
Condensator Power Acoustik galben de 1.5 F cu afisaj electronic,la fel adus personal din state.
pret 180 lei
Subwoofer Alpine TypeR 12' 2x4ohm 350 RMS in cutie din MDF inchisa.Subu nu este zgariat,nu este rupt etc.
pret 380 lei
se mai adauga un procesor de sunet MTX Re-Q 3,excelent pentru cei care au subwoofer+statie legate la sistemul stock al masini.
Typically all factory stereos, even premium systems, protect original equipment speakers by reducing bass output when the volume is turned up. That's acceptable in a factory system, but it hurts low-frequency performance if you want to upgrade your factory stereo by adding amplifiers and subs.
The MTX reQ bass restoration module senses the input level from the factory stereo, adding more bass at high volume levels, while keeping bass response balanced when the volume is low. Now you can truly improve your sound while keeping your factory stereo and your steering wheel controls in tact.
The MTX re-Q connects to the speaker outputs of your factory stereo. Additionally, its stereo and subwoofer preamp outputs connect to your amplifiers. Included are individual gain controls for the right, left, and sub outputs, plus low-pass and subsonic filters to maximize your sub's performance. A bass enhancement switch lets you add some additional bump in your ride when needed.
signal processor restores bass when adding amps to a factory system
perfect when adding amplifiers and subwoofers to an OEM (original equipment manufacturer) factory sound system
right, left, and subwoofer preamp outputs
Bass Enhance switch
4-3/4"W x 1-1/4"H x 3-3/4"D
pret 300 lei
Bucuresti,trimit si in provincie doar cu un curier iar taxele sunt suportate de cumparator.
0769775148 sau 0722640539
KnupZ
owned
Re: vand statie,sub,condensator si procesor de sunet auto
Mesajde KnupZ » 15 Oct 2009, 17:30
mai adaug un filtru pentu sunetele nedorite din sistemul dvs,se pune pe rca-uriile statiei,are contacte aurite, 45 lei
preturiile sunt usor negociabile,pentru cine doreste am si poze reale
KnupZ
owned
Mesajde KnupZ » 19 Oct 2009, 15:03
scadem putin preturiile,statia 800 lei pret fix,condensatorul 170 lei,subu 350 lei,procesorul de sunet 250 lei.
KnupZ
owned
Mesajde Maddogul » 01 Noi 2009, 15:19
Ma inscriu la condensator cum facem?
Cu Stima
Mondeo MK2 '98 2.0 130Cp '97
Maddog Garage
Maddogul
Maşina: Fiesta Mk5 1.7 VCT
VIN: WF0FXXGAGFRA56025
Mesajde KnupZ » 01 Noi 2009, 15:54
condensatorul se duce la maddogul,pt restu up, pentru cine nu stie ce face procesorul de sunet il rog sa ma intrebe :)
KnupZ
owned
Mesajde KnupZ » 18 Dec 2009, 02:16
s-au vandut toate demult.Topic inchis.
KnupZ
owned
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 76 vizitatori
În total sunt 76 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 76 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
