Amplificator Kenwood clasa D mono 900 RMS in 2ohm
Mesajde KnupZ » 27 Noi 2009, 19:51
e adusa personal din state anul trecut,functioneaza fara nici o problema,are si remote.
Modelul este Kac-9152D
pret 700 lei usor negociabil
accept unele schimburi +dif cu o statie bunicica pe 4 canale.
bucuresti
0769 775 148
KAC-9152D main features:
1,800 Watts max power
500 Watts x 1 max (4 ohms) RMS
900 Watts x 1 (2 ohms) RMS
900 Watts x 1 (1 ohms) RMS
Wired remote control to adjust boost level and frequency included
'Dual mono drive' configuration option (requires two KAC-9152D amplifiers & specialist knowledge!)
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct) to cut unwanted ultra-low frequencies
'Kenwood logo triangle' design power indicator LED
1 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Power MOSFET switching power supply
'D' class amplification circuits throughout, using switching techniques instead of the linear methods used in Class 'A' or 'B' type amplifiers. Class 'D' is a significantly more efficient than Class 'A' or 'B', resulting in greater power with less heat generation, higher stability and improved reliability
2 x 30 amp power supply fuses
Dimensions (WxHxD) : 380 x 61 x 286 mm
Complete with full fitting and operating guide
KnupZ
owned
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 72 vizitatori
În total sunt 72 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 72 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
