Vand laptop Toshiba Tecra S3 - 900 ron
Mesajde kristy_brasov » 27 Dec 2009, 21:20
Vand laptop Toshiba Tecra S3 - clasa bussines foarte rezistente
specificatii sumare:
Pentium M 2.0 ghz, 1,5 gb ram, hdd 80 gb, placa video separata 128 mb, wireless, bluetooth, infrarosu, tv-out, amprenta digitala etc.
Toshiba New Tecra(R) S3 Notebook Specification:
Processor
Mobile Intel® Pentium® M 2.0 GHz processor, 533MHz FSB
L1 Cache 32KB/32KB (instruction/data), L2 Cache 2MB
Operating System
Genuine Windows® XP Pro sp2
Memory 1.5 gb ram
Standard Memory: 1x512MB + 1x1024 DDR2
Maximum Memory: 2GB DDR
Expansion Modules: 256MB, 512MB, or 1024MB
Hard Disk Drive
80.0 billion bytes (5,400 rpm). 9.5mm height, 2.5” (S-ATA),
Optical Drive
Ultra Slim DVD MULTI RECORDER (CD-RW/DVD-RW)
ATAPI Interface
Software Decoder: InterVideo WinDVD
Display System
Type: TFT Active Matrix colour LCD display
Size (diagonal): 15”TFT
Graphics Controller
NVIDIA GeForce Go 6600
Video Memory: 128 MB DDR memory
16x PCI Express
2D and 3D Graphics
Sound System
Software Sound 24bit stereo
STAC9200
Built-in stereo speakers and microfone, Direct 3D sound,full duplex support,
Sound volume control dial, external MIC port (monaural),
stereo headphone port.
Communication
ModemV.92 Data/56K Fax Modem, Ring wake up resume.
10/100/1000 Integrated Ethernet LAN, network boot.
Built-in Wireless LAN (802.11a/b/g)
Built-in Bluetooth Antenna
Expansion
2 memory slots (one filled with 512MB, can be replaced by 256MB, 512MB or 1 GB) other slot empty.
1 PC Card slot supports one Type II PC Card; supports Cardbus
1 Express Card Slot
Ports: SD card slot, 1 Parallel, 1 RGB, 1 Serial, 1 Docking Interface (for opt. Advanced Port Replicator III), 1 FIR, 3 USB (2.0), 1 Modem (RJ-11), 1 LAN (RJ-45), 1 IEEE 1394, 1 TV Out (S-Video), External Mic, Stereo Headphone.
Supported via Advanced Port Replicator III: 1 Parallel, 1 Serial, 1 PS/2 Keyboard, 1 PS/2 Mouse, 4 USB (2.0), 1 Modem (RJ-11), 1 LAN (RJ-45 with LED), 1 Line-in, 1 Line-out, 1 RGB, 1 IEEE, 1 DVI
Keyboard
Full sized 85 keys with 12 function keys
2.7mm keystroke, 6mm height
Dedicated Windows Keys
Spill Resistant keyboard
Pointing Device
Dual Pointing device – Touchpad + Accupoint
Additional
Physical Dimensions
Dimensions: 338mm (W) x 280mm (D)x 29.7mm/37.8 (H)
Weight: 6.3lbs/2.85kg
AC Adapter
75W external Universal AC adaptor input voltage (100 –240V
50/60Hz frequency), (15Vx5A)
Battery
Battery Type: Removable, Rechargeable 6-cell Lithium Ion (Li-ion) 4700mAh
Battery Life: 3.2 hours mai tine maxim 1 ora.
BIOS
ACPI v1.0b, DDC, PnP v1.0a,VESA v2.0, DPMS,
SM BIOS v2.3.4, PCI BIOS Support V2.2.
Security
Toshiba Anti-Theft Protection Timer
TPM – Trusted Platform Module
Built-in Fingerprint Sensor
Cable lock slot, power on password, supervisor password
Environmental Specifications
Temperature: Operating 5° 35°C (41° 95°F);
Non Operating –20° 65°C (-4°149°F)
Thermal Gradient: Operating 15 C per hr. max;
Non Operating 20 C per hr. max
Relative Humidity: Operating 20% to 80% non-condensing; Non-Operating: 10% to 90% non-condensing
Altitude (relative to sea level): Operating: -60 to 3,000m.;
Non-Operating: -60 to 10,000m.
Shock: Operating: 10G; Non-Operating 60G
Vibration: Operating 0.5G; Non-Operating: 1G
Este laptop-ul sotiei mele. Mi-am luat acum 2 spatamani un laptop mini de 10 inch si acum sotia vrea si ea unul deci tre sa-i vand laptop-ul actual ca sa-i iau altul.
Pozele sunt reale facute de craciun, merge totul in standarde normale, nu prezinta nici un defect.
Ca si un review personal:
Puncte bune:
boxe puternice si foarte clare
o groaza de intrari, mufe, conexiuni inclusiv pentru docking station. practic nu ii lipseste decat webcam integrat in rest le cam are pe toate.
potentiometru volum sunet pe carcasa foarte practic.
taste suplimentare si mouse dublu
Puncte slabe
coolerul cam zgomotos noaptea
dimensiune mare si greutate 3 kg parca
unele mufe metalice curenteaza ...cica e normal asa pt ca sunt alimentate.
Restul componentelor functioneaza bine - ca la orice laptop.
pachetul contine laptop + baterie + incarcator original + carti si cd-uri.
Pret 9 mil negociabil - transport 23 ron ( achitat de mine ) .
kristy_brasov
Re: Vand laptop Toshiba Tecra S3 - 900 ron
Mesajde kristy_brasov » 01 Ian 2010, 20:24
kristy_brasov
Mesajde kristy_brasov » 05 Ian 2010, 23:42
kristy_brasov
Mesajde kristy_brasov » 12 Ian 2010, 13:51
800 PRET FIX ...........cu livrare personala in Bucuresti si va las sa-mi admirati si scorpia :))
dar e urgent ca am gasit sa-mi iau altul mini si nu pot tine omul blocat prea mult timp.
kristy_brasov
Mesajde kristy_brasov » 15 Ian 2010, 22:33
S-a vandut :-" ............tot aici in club.....
clubford este mai bun si fata de okazii.ro :))
kristy_brasov
