VAND BLITZ NOU, NEFOLOSIT!! -- METZ MECABLITZ 32 MZ-3 --
Mesajde mondenicus » 13 Mar 2010, 14:42
Vand blitz Metz Mecablitz 32MZ-3 (made in Germany) , rabatabil 90grade in plan vertical si 270grade in plan orizontal, cap zoom electric automat sau manual de la 28mm pana la 85mm, mod de lucru: TTL, Manual, Winder, raza de actiune pana la 30m pt ISO 800, f2, 8, alimentare 4 baterii tip AA.
Pret: 370lei
mondenicus
Re: VAND BLITZ NOU, NEFOLOSIT!! -- METZ MECABLITZ 32 MZ-3 --
Mesajde mondenicus » 14 Mar 2010, 13:10
Up! Blitzul este nou! si nu a fost folosit niciodata!
mondenicus
Mesajde mondenicus » 19 Mar 2010, 21:14
up!!!
mondenicus
Mesajde mondenicus » 20 Mar 2010, 19:54
upppppp........
mondenicus
Mesajde mondenicus » 24 Mar 2010, 22:48
UP! Negociabil!
mondenicus
Mesajde mondenicus » 29 Mar 2010, 00:15
UP!
mondenicus
Mesajde mondenicus » 29 Mar 2010, 18:42
Up! 350 RON!
mondenicus
Mesajde mondenicus » 01 Apr 2010, 17:24
Up! Un blitz ffff bun si performant la pret de criza ca vine iepurasul!!! 320 RON!
mondenicus
Mesajde mondenicus » 12 Apr 2010, 21:34
Pana pe 15.04.2010 280 ron! Ultimul pret, dupa care se revine la 320 ron!
mondenicus
Mesajde Lupan » 19 Apr 2010, 13:42
Poti sa pui te rog o poza cu el? M-ar interesa pt o camera video sony.
VAND orice accesorii/baterii/carcase/piese telefon pt orice model la preturi mici.
Livrare in toata tara prin curierat rapid sau posta romana.
Lupan
Maşina: Ford, Focus, 2006, 1598, Tournir
VIN: WF0WXXGCDW6L80955
Mesajde Paulp » 19 Apr 2010, 13:56
E pentru aparate foto, nu e lumina continuua.
Ce compatibilitate are? Nikon, Canon, Pentax?
Paulp
Petrol Head
Mesajde mondenicus » 19 Apr 2010, 21:41
Se roteste "lampa" cu oglinda in trepte pana la 90 grade, si cu tot corpul stanga/dreapta
Blitz rotativ, patina e detasabila (System SCA 300) se poate monta aproape pe orice aparat !
Are functia TTL, MAN,W,A,A,A , zoom, stare f buna, nou, avand si cutia originala.Blitz fabricat in Germania. Sofisticat, practica a dovedit ca sistemul adaptor Metz SCA asigura faptul ca una si aceeasi unitate flash este potrivit pentru aproape orice aparat de fotografiat doar cu ajutorul adaptorului corespunzator.
System SCA 300Metz Adaptoare SCA
The sophisticated, practice-proven Metz SCA adapter system ensures that one and the same flash unit is suitable for virtually any camera merely by using the corresponding adapter.
SCA 3002 for AF and Digital Cameras SCA 3002
SCA 3102 Canon SCA 3102 Canon
For Canon EOS and DIGITAL cameras
76 MZ, 70 MZ, 54 MZ, 50 MZ-5, 44 MZ-2, 40 MZ, 32 MZ-3, 32 Z-2 76 MZ, 70 MZ, 54 MZ, 50 MZ-5, 44 MZ-2, 40 MZ, 32 MZ-3, 32 Z-2
60 CT 4(SCA 3000C), 45 CL/CT 4,3(SCA 3000C), 45 CL 4 Digital (SCA 3045) 60 CT 4 (SCA 3000C), 45 CL / CT 4,3 (SCA 3000C), 45 CL 4 digitale (SCA 3045),
SCA 3202 Olympus / Panasonic / Leica SCA 3202 Olympus / Panasonic / Leica
For Olympus DIGITAL cameras
SCA 3302 Minolta / Sony Alpha SCA 3302 Minolta / Sony Alpha
For Minolta Dynax / Maxxum / DIGITAL cameras
SCA 3402 Nikon / Fuji SCA 3402 Nikon / Fuji
For Nikon AF and DIGITAL cameras
SCA 3502 Leica SCA 3502 Leica
For Leica cameras R8, R9 and M6 TTL, M8 Pentru Leica R8 camere, R9 ??i M6 TTL, M8
SCA 3602 Sony SCA 3602 Sony
For Sony DIGITAL cameras
SCA 3702 Pentax / Samsung SCA 3702 Pentax / Samsung
For Pentax AF cameras
SCA 300 For Manual Cameras SCA 300 pentru camerele Manual de
SCA 301 Standard foot SCA 301 picior Standard
Usable with all SCA flash units; incl.
SCA 351 Leica SCA 351 Leica
For Leica cameras R4, R4s, R5, RE, R6, R6.2 and R7 Pentru Leica R4 camere, R4s, R5, RE, R6, R6.2 ??i R7
SCA 300 compatible shoe mount flash units and handle mount flash units (+SCA 300A)
SCA Connecting Cords SCA
SCA 300 A Connecting cable SCA 300 A
Connection between adapters SCA 300 and handle mount flash units or Power Grips G 15 / G 16
SCA 307 A Connecting cable SCA 307 Un cablu de conectare,
Connection between adapter SCA 300 on top of the hot shoe and Metz shoe mount flash on the bracket
SCA 3000 C Connection SCA 3000 Connection C
Connection between adapters SCA 3000 / 3002 with 60 CT 4, 45 CL/CT 3/4 or Power Grip G 15
SCA 3008 A Connecting cable SCA 3008 Un cablu de conectare,
Connection between adapter SCA 3000 / 3002 on top of the hot shoe and Metz shoe mount flash on the bracket
SCA 3045 digital for 45 CL 4 digital timp de 45 de CL 4 digitale
Connection between adapters SCA 3002 and 45 CL 4 digital,
Autofocus measuring beam.
Miscellaneous Connectors & Batteries Connectors
SCA 305 A Multi-Connector SCA 305 un multi-Connector
Connector for wired TTL with max. Conector pentru TTL cu fir cu max. 3 flashes (System SCA 300); 3 flash-uri (Sistem SCA 300);
Connection of the flashes on top of the Multi-Connector or on two sockets at the side
SCA 305 S Cable for hand hold flashguns SCA 305 S prin cablu pentru flashguns
Connection of TTL capable handle mount flashes (System Conexiunea de TTL capabile
SCA 300) to SCA 305 A Multi-Connector; 1m SCA 300)
SCA 305 K Cable f. SCA 305 K prin cablu f. shoe-mount flash units pantof-mount unit????i de bli??
Connection of TTL capable shoe mount flashes to SCA 305 A Multi-Connector; 1m SCA 300) la 305 SCA un multi-Connector; 1m
SCA 305 V5 Extension cable 5m
5m extension cord for cables SCA 305 S or SCA 305 K
SCA 300 Accessories SCA 300 Accesorii
SCA 300 D Spacer SCA 300 D Spacer
Permits the use of 32 CT-7, 32 MZ-3, 40 MZ .., 50 MZ-5 and
70 MZ-.. 70 MZ-.. with adapters SCA 300 AF and SCA 386
SCA 300 E Adapter S
Connection between adapters SCA 344, SCA 386 and SCA Conexiunea între adaptoare SCA 344, SCA 386
396 to Metz shoe mount flashes, 50 MZ-5 and 70 MZ-5, -4
mondenicus
Mesajde mondenicus » 19 Apr 2010, 21:42
Salut! Pentru detalii pun aici link-ul http://www.metz.de/fileadmin/fm-dam/Dow ... 3_D_GB.pdf
Sistemul SCA de blitz-uri se remarca prin capacitatea de a lucra cu orice camera la fel de bine ca si blitz-urile dedicate.
Blitz-ul meu are un adaptor, cel original cu care este din fabrica, dar nu stiu, sincer, cu ce aparat este compatibil sau pentru ce camera foto este??! Scrie pe cutie system SCA -3000 / SCA -300.
mondenicus
Mesajde toxicristi » 20 Apr 2010, 08:27
$1 scrie:$2an my mecablitz be used with a Canon digital camera?
All current Canon digital cameras with a hot shoe feature so-called E-TTL flash control in place of the standard TTL flash control. Fully automatic operation with these cameras requires flash units that feature this particular flash mode. Suitable flash units see flash light recommendation.
The SCA 3000 flash units, for example mecablitz 32 MZ-3, 40 MZ-.. or 50 MZ-5, aren’t loaded with this special E-TTL flash control. Therefore this flash units only can be used at automatic flash mode or manual flash mode with the Canon digital cameras . Normally we recommend using also the adaptor SCA 3102 for connection. Thereby the particular aperture is also manually adjustable at mode "AV" or "M" at the camera.
toxicristi
Mesajde mondenicus » 22 Apr 2010, 22:39
Up! 320 ron!
mondenicus
Mesajde mondenicus » 28 Apr 2010, 18:38
Up. 320 ron sau schimb cu 4 jante de tabla 5x108 pentru Mondeo MK3!
mondenicus
Mesajde mondenicus » 10 Mai 2010, 21:10
UP!!!
mondenicus
Mesajde mondenicus » 18 Mai 2010, 21:59
UP!!!
mondenicus
Mesajde mondenicus » 05 Iun 2010, 18:25
Up. Inca valabil, pret de criza!
mondenicus
Mesajde Lazar Cornel » 17 Iun 2010, 23:13
Buna. Mai este de actualitate anuntul ?Scuze ,dar n-am inteles data publicarii.Stima
Lazar Cornel
Maşina: Wv Sharan
Mesajde mondenicus » 21 Iun 2010, 18:18
Salut! Inca valabil!
mondenicus
Mesajde corpsearella » 25 Iun 2010, 19:14
Interesat.Ai pm. URGENT!
corpsearella
Maşina: VW
Mesajde mondenicus » 11 Iul 2010, 10:32
UP!!!
mondenicus
Mesajde mondenicus » 17 Iul 2010, 18:44
UP! Nimeni interesat de o afacere buna?
mondenicus
Mesajde mondenicus » 24 Iul 2010, 14:23
UP! UP! UP!
mondenicus
Mesajde mondenicus » 31 Iul 2010, 10:33
UP! un blitz nou ???.........nimeni interesat?............ieftin, pret de criza!
mondenicus
Mesajde mondenicus » 01 Aug 2010, 12:14
UP!
Pret: 370lei
Ultima oară modificat de Mihai L pe 01 Aug 2010, 13:41, modificat 1 dată în total.
Motiv: Avertisment pentru nerespectarea regulilor forumului (UP).
mondenicus
Mesajde mondenicus » 04 Aug 2010, 17:56
up!!
mondenicus
Mesajde mondenicus » 10 Aug 2010, 11:05
up!
mondenicus
Mesajde mondenicus » 12 Aug 2010, 18:55
up!
mondenicus
