VAND LAPTOP SONY VAIO
25 Mai 2010, 09:09
SONY VAYO VGN-NS11M
Cover Colour: Silver
CPU Section
Microprocessor Full Name: Intel Core™2 Duo Processor T5800 with Enhanced Intel SpeedStep Technology
Microprocessor Manufacturer: Intel
Microprocessor Speed (GHz): 2
Number of Cores: 2
L2 Cache (KB): 2048
Frontside Bus (MHz): 800
Memory
Memory Speed (MHz): 800
Memory Type: DDR2 SDRAM (1x2048MB, 1x1024MB)
Max. Memory (MB): 4096
Max Memory Comment: In the case of 4GB, a portion of the system memory over 3GB might not be available to the operating system
Memory Size (MB): 3072
Hard Disk Drive
Hard Drive Capacity (GB): 250
Hard Drive Type: Serial ATA
Hard Drive speed (rpm): 5400rpm
Optical Drive
Optical Drive Type: DVD+-RW/+-R DL/RAM
Optical Drive Fitting: Built-in
Optical Drive Speed Read: CD x24, CD-R x24, CD-RW x24, DVD x8, DVD-R DL x6, DVD-R x8, DVD-RW x6, DVD+R DL x6, DVD+R x8, DVD+RW x8, DVD-RAM x5
Optical Drive Speed Write: CD-R x24, CD-RW x24, DVD-R DL x6, DVD-R x8, DVD-RW x6, DVD+R DL x6, DVD+R x8, DVD+RW x8, DVD-RAM x5
Display
Display Type: X-black LCD
Diagonal Size (in): 15.4
Resolution Format: 1280 x 800
Resolution Type: WXGA
Graphics
Graphic Card Full Name: Mobile Intel Graphics Media Accelerator 4500MHD
Producer: Intel
Graphics memory: Total avalilable graphics memory of Approx. 820MB*
Comments: Total Available Graphics Memory refers to the Windows Vista classification of graphics memory, which varies depending on the operating condition, version of device driver and system memory size.
Interfaces
4 Pin i.LINK™ (IEEE1394), 400 Mbps: 1
DC in: 1
Memory Stick™ Slot: 1
Memory Stick Slot Type: Memory Stick™ Std / Duo, Memory Stick™ PRO Std / Duo, high speed data transfer
SD Card Slot: 1
Audio out: 1
Audio out Type: Stereo Headphones/Speakers Jack
Microphone Jack (Stereo): 1
RJ-11 Direct Port (Modem): 1
RJ-45 Direct Port (Network): 1
USB Speed: High/Full/Low
USB Port (quantity): 4
USB Version: 2
USB Connector Type: A
VGA Connector for Monitor: 1
Express Card Slot: 1
Express Card Type: 34mm
Keyboard Section
Touch Pad: 1
Battery
Battery Type: Lithium-Ion battery (VGP-BPS13x)
Battery life time
Battery charging time
Battery life disclaimer: Actual battery life will vary depending on your specific hardware and software configurations. Benchmark: MobileMark 2007
Connectivity
Built-in Modem: V92/V.90
Integrated Wireless LAN: YES
Wireless LAN Max. Date Rate (Mbps): 300 (RX)/ 150 (TX)
Wireless LAN Range (m): max. 100
Wireless LAN Type: 802.11a/b/g Draft n
Ethernet network: 10Base-T/100Base-TX/1000Base-T
Built-in Camera
Built-in 'Motion Eye' Digital Camera: YES
Frames per Second: Max. 30
Image Sensor (Mega Pixels): 1.3
Motion Picture Function: YES
Motion Pictures max. Resolution (pixels): 1280x1024 (SXGA)
este folosit[aproape 1 an]
pret 350e
0730667541 DAN
Re: VAND LAPTOP SONY VAIO
28 Mai 2010, 13:38
pret nou 325e
04 Iun 2010, 06:59
pret nou 300e
07 Iun 2010, 15:19
sa vandut
