Vand set motor V4
Vand set motor V4
Mesajde Zodrak » 06 Iun 2010, 15:21
Vand set motor cota 1 reparatie, NOU, care are urmatoarele componente:
pistoane - 90,990 mm - 4buc,
bolti - 24x70mm - 4 buc,
segmenti ptr fiecare piston(2,3 si 5 mm),
garnituri de chiuloasa - set(2buc)
garnituri de capace - set(2buc)
Se potriveste la urmatoarele modele de masini:
The 1.7 L (1699 cc) V4 had a 90.0 mm bore and 66.8 mm stroke. It produced 65 hp (48 kW) and 129 N·m (95 lb·ft), 70 hp (52 kW) and 137 N·m (101 lb·ft) or 75 hp (55 kW) and 130 N·m (96 lb·ft).
1966-1970 Ford Taunus 12M P6
1966-1970 Ford Taunus 15M P6
1964-1967 Ford Taunus 17M P5
1967-1971 Ford Taunus 17M P7
1965-1972 Ford Transit Mark I
1967-1972 Matra 530
1969-1972 Ford Capri
1972-1975 Ford Consul (German version)
1975-1981 Ford Granada (German version)
1971-1974 Saab 95, Saab 96 and Saab Sonett, low compression version with 55 hp (41 kW) (same as its contemporary 1500 cc 95/96) for USA market
The 1962 "Mustang I" Concept car (tuned to 90 hp (67 kW)
The 1.5 L (1498 cc) V4 had a 90.0 mm bore and 58.86 mm (2.3 in) stroke. It produced 55 hp (40 kW) and 107 N·m (79 lb·ft), 60 hp (44 kW) and 114 N·m (84 lb·ft) or 65 hp (48 kW) and 117 N·m (86 lb·ft)
1962-1966 Ford Taunus 12M P4
1967-1980 Saab 95 and Saab 96 (European market)
1967-1974 Saab 95, Saab 96 and Saab Sonett (USA market)
Documentatie
http://en.wikipedia.org/wiki/Ford_Taunus_V4_engine
Zodrak
Maşina: Ford Cortina 1500GT, 1965
scuze, am uitat de pret
Mesajde Zodrak » 06 Iun 2010, 15:23
Pretul este de 200 euro.
Zodrak
