Dezmembrez Mondeo MK3, Focus MK2, Transit Connect
Mesajde catalinautocars » 07 Iul 2010, 22:56
Dezmembrez Ford Mondeo 2.0TDCI 2004 si 2.0TDDI GHIA 2001.
Masinile sunt complect functionale!!
motor tdi si tdci, cutie de viteze;
scaune piele;
scaune velur;
bara fata , bara spate, radiatoare, compresoare, capota, aripi, usi, oglinzi, motoare, injectoare, geamuri, parbrize, faruri.
COMPRESOR CLIMA
AIRBAG-uri
AMORTIZOARE HAYON HATCHBACK
AMORTIZOARE SI ARCURI
BANCHETE
BARA SPATE /BARA FATA
BARE STABILIZARE
BIDONAS SERVO DIRECTIE
BLOC COMENZI AUDIO
BLOC LUMINI BORD
BLOC SEMNALIZARE
BLOC STERGATOR
BRATE SUSPENSIE
CALCULATOR MOTOR DIESEL
CARCASA FILTRU AER DIESEL
CENTURI DE SIGURANTA
COMUTATOR AVARII
COMUTATOARE SI MOTORASE GEAMURI ELECTRICE
CONTACT PORNIRE CU CHEIE
CUTIE VITEZA MANUALA 5 TREPTE
DEBITMETRU AER
ESAPAMENT
ETRIERE FATA/SPATE
FARURI CEATA
FARURI STANGA + DREAPTA
FULIE VIBROCHEN
FUZETE
GALERIE EVACUARE
GEAMURI LATERALE
GRILA RADIATOR
HAYON SPATE
INTARITURA BARA SPATE
INJECTOARE
JANTA ROATA ALIAJ (SET) pe 16 INCH
JANTA ALIAJ MONDEO GHIA pe 17
JUG MOTOR
LUNETA
MACARALE GEAM ELECTRICE/MANUALE
MANERE USI
MANER FRANA DE MANA
MANETA SCHIMBATOR
MODUL DECLANSATOR AIRBAG
MOTOR DIESEL 2.0 TDCI 130 CP
MOTOR DIESEL 2.0 TDDI
MOTORASE STERGATOARE
OGLINDA EXTERIOARA ELECTRICA
PLANETARE
POLITA PORTBAGAJ
POMPA ABS
POMPA ALIMENTARE MOTORINA
POMPA AMBREAJ
POMPA DE INALTA PRESIUNE
POMPA DE INJECTIE
POMPA DE VACUM SISTEM FRANARE
POMPA FRANA
PUNTE SPATE
RADIATOR GAZE EVACUARE
RADIATOR INCALZIRE
RADIATOR ULEI (TERMOFLOT)
REZERVOR COMBUSTIBIL
SCAUN FATA MODEL CU AIRBAG
SENZOR IMPULSURI ARBORE COTIT
SENZOR POZITIE AX CU CAME
SENZOR POZITIE VOLAN INEL AIRBAG
SET AMBREAJ
SPIRALA AIRBAG, POZITITE COLAN
STOPURI
SUPAPA EGR
SUPAPA VACUM
SUPORT PAHAR
TABLOU SIGURANTE
TAMPON CUTIE VITEZE DIESEL
TAMPON MOTOR DIESEL
TAPITERIE HAYON
TAPITERIE PAVILION
TELESCOP CAPOTA MOTOR
TIMONERIE
TURBOSUFLANTA
UNITATE CLIMATRONIC
UNITATE MANUALA REGLAJ INCALZIRE-CLIMATI
USI FATA/SPATE STANGA/DREAPTA
USA TORPEDOU
VAS EXPANSIUNE SPALARE PARBRIZ
VENTILATOR INCALZIRE
VOLAN CU AIRBAG
Recent aduse!! trimit prin curierat in orice localitate!!
Am atasat si cateva poze, poate va ajuta!! Succes!
catalinautocars@yahoo.com
0769.525.827
Ultima oară modificat de Mihai R pe 05 Mai 2011, 09:15, modificat de 2 ori în total.
Motiv: Ford nu are motoare de 1900cmc. TDDi-ul e tot de 2.0l - 1998cmc
catalinautocars
Localitate: Corabia
Re: Dezmembrez Ford Mondeo 2.0 TDCI 2004 si Mondeo 1.9 TDI 2001
Mesajde boldish » 07 Iul 2010, 23:36
De la Mondeo 2.0 TDCI ai cumva furtun intercooler?
boldish
Maşina: Ford Mondeo 2.0 TDCI 130 CP 2003
Re: Dezmembrez Mondeo 2.0 TDCI 2004 si 2.0 TDDI 2001
Mesajde DGAlexandru » 08 Iul 2010, 00:27
Va rog sa va completati profilul in campul "Locatie".
Comform Regulamentului C.F. preturile pt. produsele comercializate trebuie sa fie specificate. Intdeleg ca e vorba de dezmembrare - f. multe piese, deci oferit preturile macar pt. lista de mai sus.
TDCi-ul ala, conform pozelor, nu e de 130cp ci e de 115cp sau chiar 90cp - are turbina fara geometrie variabila si e si fara MAF (debimatru aer).
Ma intereseaza bara spate de Turnier si AirBag-ul volan cu butoane de pilot de pe modelul 2004.
Mesajde dieselbee » 08 Iul 2010, 11:59
m-ar interesa cateva piese. furtunul in S de la intercooler, jentile de pe turnier daca nu sunt lovite, cu piulite cu tot, planetara dreapta , completa, de la motor pana la roata, cu rulment (stabilizator) cu tot. Da-mi un pret pe PM. De unde esti?
Imagine De vanzare la pret bun! Multe extra, carte de service
vand interior complet, textil negru motive albastre, pentru mk3 combi la 150 ron
dieselbee
Maşina: mondeo 2001 2.0 tddi 66kw
VIN: demidulce0000rece
Mesajde Mr.H » 08 Iul 2010, 21:05
ma ntereseaza si pe mine piesa din poza
Mr.H
Maşina: Mondeo 3 Break
VIN: WF0WXXGBBW4Y73780
Mesajde lperisoara » 08 Iul 2010, 22:28
Plafoniera cu suport ochelari si lumini de citit este valabila? La ce pret?
lperisoara
Maşina: Focus 2, sedan, 2006, Duratec 1.6, 100CP
Mesajde catalinautocars » 09 Iul 2010, 12:53
$1 scrie:$2a ntereseaza si pe mine piesa din poza
Da, este! da-mi add pe YM: catalinautocars si vorbim
catalinautocars
Localitate: Corabia
Mesajde tavi_cio » 09 Iul 2010, 18:32
salut ma intereseaza radio-cd-ul de la 2004
tavi_cio
Maşina: Ford Mondeo 2.0 TDCi 131cp
Mesajde Mr.H » 09 Iul 2010, 21:37
trimitemi pretul pin pm sau un nr de telefon ca la calc intru seara la ore tirzii
Mr.H
Mesajde bogdan1+9 » 10 Iul 2010, 12:27
bogdan1+9
Maşina: Ford Mondeo MK3.
Mesajde Marinescu_Aurel » 10 Iul 2010, 20:56
asta este poza de la una dintre masinile mele........
Marinescu_Aurel
Maşina: Ford Mondeo, 2005, 2.0 ST TDCI, 115 CP
VIN: WF04XXGBB45J23713
Mesajde GAB_STI » 11 Iul 2010, 22:32
daca nu ai dezmembrat nimic de pe ea fa-mi un pretz la aia de 2004 completa ! daca pretul e ok vin sa o vad - sant din craiova
GAB_STI
Maşina: MONDEO ST - MONDEO TITANIUM X
Mesajde catalinautocars » 12 Iul 2010, 10:33
Da-mi add pe YM si discutam.
Stima
Ultima oară modificat de DGAlexandru pe 12 Iul 2010, 11:41, modificat 1 dată în total.
catalinautocars
Localitate: Corabia
Mesajde kocsis » 12 Iul 2010, 11:51
sal
mar interesa la combi
amortizor fata stg + drp - ce marca si daca se stie ce % au la test
arcuri fata stg + drp
ms
Kocsis ladislau
0741 56 22 11
kocsis
Maşina: ford mondeo 3, 2001, 1999, 107KW
Mesajde boldish » 12 Iul 2010, 18:58
Baieti cumparati cu incredere.Eu mi-am cumparat ceva de la intercooler,super arata piesa,preturi frumoase.Deci fara frica:P.
boldish
Mesajde IOONNUT » 14 Iul 2010, 17:15
salut am si eu nevoie de :
-geam oglinda stanga
-buton avarii(modelul ala mai mare)
-far stanga
-bandou bara spate
Eventual bara fata,da-mi te rog un pret sau tel 0724209261
Ionut.
IOONNUT
Localitate: PITESTI
Maşina: mondeo mk3.
Mesajde IOONNUT » 14 Iul 2010, 17:16
sal si un rulment spate te rog
IOONNUT
Localitate: PITESTI
Maşina: mondeo mk3.
Mesajde szbeluka » 15 Iul 2010, 02:13
Salut
Mar interesa grila radiator,fata CROMAT.
Ford Mondeo 2001 TDDi, 4 usi ,.115Cp
szbeluka
Localitate: Baraolt
Maşina: Ford Mondeo 2001 TDDI, 4 usi ,.115Cp, Nr.Inmatriculare :CV-04JOB
Mesajde szbeluka » 15 Iul 2010, 02:27
si un releu,care regleaza,viteza de rotatie a ventilatorului,de racire,a radiatorului.
szbeluka
Localitate: Baraolt
Mesajde rentiu87 » 17 Iul 2010, 15:20
Salut,m-ar interesa un electromotor pentru un ford mondeo TDDi motor de 2000, an fabricatie 2001 ,115 cp un pret se poate???
٠•●★♫ ♪ ♫ ♫™★♪♫•*¨*•.¸¸♪♫•*¨*•.¸¸♪♫•*¨*•.¸¸♪♫•*¨*•.¸¸♫™
rentiu87
Localitate: targoviste
Maşina: ford TDDI 115cp Nantucket Grey
VIN: WF05XXGBB51C21983
Mesajde laurstef » 21 Iul 2010, 14:31
Ziua bună!
Aş vrea şi eu pentru un Mondeo Tournier TDDI din 2001, senzorul de airbag (cel de sub încuietoarea capotei), bandoul exterior de la geamul şoferului, chederul de la uşa şoferului şi plasticul (caiciucul) de pe partea stângă (tot a şoferului) de sub cheder, cel care porneşte din faţa maşinii (din spatele aripii) şi continuă până după uşa pasagerului.
Şi aş mai vrea şi scutul pentru motor - cel din metal
Mulţumesc anticipat!
Laurenţiu
NIHIL SINE DEO!
laurstef
Maşina: Mondeo Tournier, 2001, 2.0 TDDI, 66kw
VIN: WF0WXXGBBW1C37925
Mesajde catalinautocars » 21 Iul 2010, 20:34
$1 scrie:$2alut,m-ar interesa un electromotor pentru un ford mondeo TDDi motor de 2000, an fabricatie 2001 ,115 cp un pret se poate???
@rentiu87 Da, il am, suna-ma si iti fac pret frumos
catalinautocars
Localitate: Corabia
Mesajde catalinautocars » 21 Iul 2010, 20:42
$1 scrie:$2alut
Salut, ti-am atasat o poza cu grila fata, astept tel.
catalinautocars
Localitate: Corabia
Mesajde catalinautocars » 21 Iul 2010, 20:45
$1 scrie:$2url=http://img824.imageshack.us/i/bararigidizare.jpg/]Imagine[/url]
Il am si pe asta, astept telefonul tau
catalinautocars
Localitate: Corabia
Mesajde catalinautocars » 21 Iul 2010, 20:51
@Mr.H . am acel plastic 100RON
catalinautocars
Localitate: Corabia
Mesajde catalinautocars » 21 Iul 2010, 20:54
@laurstef Am tot ce te intereseaza, da-mi add pe mess si vorbim sau suna-ma oricand!!
catalinautocars
Localitate: Corabia
Mesajde RAZWAN » 21 Iul 2010, 20:59
Salutare! Jantele de 17'.. m-ar interesa! un pret, te rog, daca sunt si cauciucurile in stare buna etc.. Astept PM
Ford MONDEO Ghia,2.0 TDCI, gearbox 6+1, 131-CP, nov.2003, euro-4, bestiala masina...
si un"Focos"combi, TDDI, 2005, euro-3, albastru met.
RAZWAN
Localitate: BACAU
VIN: Wxxxxxxxxxxxxxxxx
Mesajde s_laur » 21 Iul 2010, 21:00
Salut da-mi si mie un pret pentru volan ford mondeo an 2001 complet cu airbag si pe bucati te rog.
s_laur
Maşina: ford mondeo 2001
VIN: WF05XXGBB51R89372
Mesajde rentiu87 » 21 Iul 2010, 21:52
Salut
Mar interesa jantele si cele pe 17 si cele pe 16 astept pm
electromotor am gasit multumesc oricum!
rentiu87
Mesajde catalinautocars » 21 Iul 2010, 23:16
Am pus cateva poze cu Jante + gume
Jante tabla pe 16 + gume
Rezerva Mondeo
Jante 17 + gume
catalinautocars
Localitate: Corabia
