Vand Statie Radio CB Intek M 790 Plus + Antena Intek MAG 134
Mesajde xmmd2003 » 16 Sep 2010, 15:56
INTEK M-790 + Antena CB Intek MAG 1345 + Calibrare antena
Pret: 250 RON
Contact: PM sau ymsg: xmmd2003
A new series of state-of-the-art CB (27 MHz) mobile transceivers, with advanced software and hardware design, specifically conceived for Citizen Band operators and for car & truck drivers. 10 bands programmable multi standard circuit design, matching the frequency & operating mode requirements of various countries. A number of unique features makes this radio one of the most advanced and sofisticated mobile CB transceiver in the market. One radio only, ready for use in all the European countries !
• MULTI STANDARD CIRCUIT
• 10 BANDS PROGRAMMABLE
• ESP "COMPANDER" RX/TX MODULATION PROCESSOR (COMPRESSOR-EXPANDER)
• AUTO SCAN
• DUAL WATCH
• HIGH QUALITY DYNAMIC MICROPHONE WITH UP/DOWN AND LOCK KEYS
• QUICK UP KEY
• QUICK DOWN KEY
• EMG
• LCR
• DIGITAL 10 BAR S/RF METER
• RUBBER SOFT TOUCH KEYPAD
• BACKLIGHTED LCD DISPLAY
General
Channels Refer to programmed band
Modes (AM, FM) Refer to programmed band
Operating Temp. -10°/+55°C
DC Input Voltage 13.2Vdc ±15%
Size 140(L) x 37(H) x 190(D) mm
Weight 800 gr.
TRANSMITTER
System CPU Controlled PLL
Synthesizer
Max Output Power 4W at 13.2Vdc
Modulation AM (from 85% to 95%)
FM (1.8 KHz ±0.2 KHz)
Output Impedanced 50 Ohm unbalanced
Current Drain 1100 mA (at no modulation)
RECEIVER
System CPU Controlled Double
Conversion Super
Heterodyne
IF 1° 10.695 MHz / 2° 455 KHz
Sensitivity 0.5µV for 20dB SINAD (FM)
0.5µV for 20dB SINAD (AM)
Audio Output Power @10% THD 2.5W at 8 Ohm
Audio Distorsion <8% at 1 KHz
Image Rejection 65dB
Adjacent Ch. Rejec. 65dB
Signal/Noise Ratio 45dB
Current Drain 250mA (stand-by)
This new INTEK CB (27 MHz) mobile two way radio includes the new ESP "COMPANDER". The meaning of "COMPANDER" is Compressor-Expander. This microprocessor controlled audio Speech Processor works as a modulation Compressor in transmission and as a modulation Expander in reception. ESP provides a stronger and more clear and readable audio signal. It is a great help in noisy areas and in case of long distance communication and weak signals. The efficiency of ESP is even higher when communicating with another radio having the same ESP system.
xmmd2003
