piese ford scorpio
piese ford scorpio
Mesajde sorin_cojones » 29 Mar 2011, 11:20
PIESE FORD SCORPIO
Chenar bord ceas-50 ron
Motor trapa-100 ron
Comanda trapa+lumina-75 ron
Brate cu piot si bucsa-150 ron ambele
Ansamblu stergatoare-120 ron
Plastice masca stopuri in portbagaj-75 ron ambele
Stopuri spate-75 ron buc
Releu inchidere portbagaj-50 ron
Grila bord cu 3 aerisiri-50 ron
Grila cu cauciuc cu gaura bric-35 ron
4 calculatoare-
Bricheta spate-25 ron
Masca volan-50 ron
Volan -50 ron
Incuietoare capota-50 ron
Aerisire bord-25 ron
Scrumiera-15 ron
Contact-75 ron
Bloc lumini-75 ron
Comanda caldura-75 ron
Bloc stergator-75 ron
Bloc semnal+avarii-100 ron
Raglaj faruri rotita-35 ron
Butoane rotunde de botd-15 ron/buc
Faruri-100 ron
Aeroterma-100 ron
Tablouri 7 sigurante-150 ron(relee)
Bobina inductie-100 ron
System abs-150 ron
Alternator-175 ron
Pompa servo cu support-120 ron
Pompa apa-75 ron
Pompa benzina-75 ron
Bidon apa(as expansiune)-50 ron
Electromotor-170 ron
etrieri fata-75 ron buc
Spate-50 ron buc
Acuum+2 relee-
Tablou 8 sigurante-100 ron
Support filtru aer-70 ron
Buson rezervor-15 ron
Caseta directie -150 ron
Amortizor+arc fata-120 ron ambele-balamale capota-75 ron ambele
Support capac cu debimetru-120 ron
Semnal dr-25 ron
Support 2 termocuple-120 ron
Cot rezeror-100 ron
Toba mijloc-100 ron
Capota fata-150 ron
Spate-100 ron
Brate stergator+comele-50 ron ambele
usi spate-100 ron/buc
fata-150 ron/buc
toba mijloc-100 ron
2 lampi spate 5 usi-50 ron/buc
2 carcase volan-35 ron/buc
Contact-75 ron
2 parasolare-30 ron ambele
Calculatoare 2.0 ac-100 euro
2 tampon motor-50 ron/buc
Compressor ac-250 ron
Semnal dr-20 ron
Bobina ind-50 ron
2 electromotor-200 ron/buc
Pompa apa -100 ron
Aeroterma-100 ron
Olan lemn-25 ron
Disc ambreiaj nou-80 ron
0764537753/0720795880
sorin_cojones
Maşina: ford sierra,scorpio,1988,2000 cmc,100 cp
Re: piese ford scorpio
Mesajde DON GYOVANY » 31 Mar 2011, 04:25
Scump domne,scump :D ...la Silviu sunt mai ieftine ;;) :D ...parerea mea,care oricum nu conteaza :-"
DON GYOVANY
Localitate: CRAIOVA
VIN: WF0AXXGAGAGU01536
Mesajde plesanu » 02 Mai 2011, 12:22
caut si eu geamu de la semnalu de langa far,partea de la sofer.Este model 92-94 alb.
plesanu
Localitate: Vartoape-Teleorman
Maşina: Ford Scorpio GHIA 1992,Motor 2.0i DOHC 88 kw hatckback
VIN: WFOAXXGAGANA76989
Mesajde sorin_cojones » 02 Mai 2011, 14:17
$1 scrie:$2aut si eu geamu de la semnalu de langa far,partea de la sofer.Este model 92-94 alb.
e model americaN?
sorin_cojones
Mesajde luncasu ion » 02 Mai 2011, 15:15
Nu s-a facut Scorpio model american(cel denumit Merkur) intre 92-94.Scorpio Merkur s-a fabricat numai intre 87-89.
Lampa de semnalizare este dintr-o bucata.
luncasu ion
Maşina: ford granada 2,5d 1982 2498c51kw l
VIN: wfofxxgagfcg34041
Mesajde plesanu » 02 Mai 2011, 16:09
exact. Aveti careva? :| .Zilele astea trebuie sa fac ITP-ul si chiar acum s-a dezlipit de l-am pierdut
plesanu
Mesajde sorin_cojones » 02 Mai 2011, 17:30
$1 scrie:$2u s-a facut Scorpio model american(cel denumit Merkur) intre 92-94.Scorpio Merkur s-a fabricat numai intre 87-89.
nu il am
sorin_cojones
Mesajde tesoro » 02 Mai 2011, 23:45
Nu cred ca nou este mai scump de 35 de lei
Vand jante aliaj originale ford si cauciucuri
tesoro
Localitate: sibiu
VIN: wfoaxxgbbapp43674
Mesajde plesanu » 03 Mai 2011, 00:00
pai atunci l-as lua nou,da da-mi o idee de unde :D
plesanu
Mesajde BT21SAN » 03 Mai 2011, 07:14
[b]...[/b]
BT21SAN
Maşina: Ford DOHC
Mesajde roxyunicul » 11 Iun 2011, 20:55
salut
nu stiu daca o sa intereseze pe cineva...
ford scorpio, 1994 cmc, 77 kw, an 1988, inmatriculata, pompa servo schimbata in decembrie 2010 cu una second, pompa de benzina schimbata in ianuarie 2011 cu una noua, cutie de viteze automata, merge doar in 1 si 2, motorul pornit ultima data in februarie, nu stiu daca o sa mai porneasca
verificarea expira in 12.06.2011
pt cei interesati, are si pret. mic mic mic
alte detalii, tot pentru ei
daca nu e nimeni interesat, o sa devina oficial rabla
roxyunicul
Localitate: Zalau
Maşina: Scorpio, 1988, 2 litri, carburator, 77 kW, CV automata merge doar 1&2 si asa va ramane
VIN: WFOAXXGAGAJL00430
Mesajde sorin_cojones » 11 Iun 2011, 21:47
poti sa lasi un tel sau un id?
sorin_cojones
Mesajde Mr666alin » 29 Iun 2011, 09:12
stiti careva unde gasesc un cablu de acceleratie si cat costa?
Mr666alin
Maşina: ford scorpio din 1985,1954 cm3
Mesajde roxyunicul » 30 Iun 2011, 18:59
cablu de acceleratie gasesti foarte ieftin: cumperi un cablu de frana de bicicleta si il folosesti in loc de cablu de acceleratie
am mers cu un astfel de cablu timp de 3 ani, apoi l-am schimbat cu alt cablu de acceleratie facut tot din cablu de frana de bicicleta. l-am schimbat ca nu cumva sa se rupa
ca sa il prinzi la pedala, folosesti o saiba, ca sa stea cum trebuie, sa nu existe pericolul sa se smulga cablul si sa ramai fara acceleratie
iar la motor faci tot o improvizatie
cumperi niste conectori electrici (cred ca asa le zice) pe care ii folosesc electricienii ca sa faca legaturile in doze intr-un apartament. treci cablul prin conector si il prinzi cu cele 2 suruburi de la conector. faci o bucla pe dupa "cuiul" care actioneaza acceleratia (sau ce o fi) si apoi il bagi prin alt conector si il prinzi cu cele 2 suruburi ale conectorului
merge garantat
ieftin si de durata
e bine sa ai un alt cablu "de acceleratie" prin torpedou, in caz ca pe drum se rupe cablul
cand o sa ajungi "la fata locului" o sa iti dai seama de improvizatiile pe care trebuie sa le faci
inca o chestie: consuela mea, acum 2 zile, a devenit oficial RABLA, iar azi 30 iunie 2011, am vandut voucherul cu 1.350 lei. DAU DE BAUT!
roxyunicul
Localitate: Zalau
Mesajde taurus_dacicus » 30 Iun 2011, 20:59
s-astepte ei sa le dau eu masina mea pe 1350.00 lei .
never .
tot Borbely , cel cu taxa de poluare a stabilit pretul asta ?
ford scorpio inseamna istorie de acum si noi sa le dam pt 2-3 pungi de chipsuri ? nu , asta nu .....
:D
[color=#FF00FF]Don't worry , be happy !!! [/color]
[color=#4000FF]It will be just Scorpio .....always !And Mondeo ,why not !?! [/color]
[color=#4040FF] But , I would prefer to have a Ford Mustang Roush Stage 3 ......
it's amazing to drive one of those cars !!! [/color]
taurus_dacicus
Localitate: Focsani-Vrancea
Maşina: Ford Mondeo mk4 2.0i 145 PS Trend 2007 & former owner of ford scorpio ghia 1988 , 2.0i , 120 PS
Mesajde Mr666alin » 01 Iul 2011, 13:25
si mie mi se pare o treaba aberanta sa dai un scorpio pe banii astia.....:(
mai sunt care tin la scorpiile lor si nu le ar da nici in ruptu capului iar consuela ta ar fi putut s ajute cateva scorpii cu piesele ei!
Mr666alin
Mesajde roxyunicul » 01 Iul 2011, 18:47
pai is sigur ca o sa ajute alte scorpii cu piesele ei
doar ca piesele trebuie cumparate de la patronul de la mivas corporation (o firma de dezmembrari din zalau) pt ca asta nu lasa mai nimic pe masinile pe care le preia prin programul RABLA
roxyunicul
Localitate: Zalau
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 157 vizitatori
În total sunt 157 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 157 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
