Vand Radio-CD 6000cd + amplificatoare
Mesajde ema_power » 21 Oct 2011, 23:02
Vand radio-cd Ford 6000cd scos de pe masina personala Focus 2 2006, nu are nici o zgarietura, merge impecabil, se vinde impreuna cu cablul pentru auxiliar!
Pret 300ron, transport inclus!
Fişierul ataşat DSC01321.jpg nu mai este disponibil
1.Aplificator Legacy LA1020
Features
Dual MOSFET Power Supply
2 Ohm Stereo Stable
RCA Line Outputs
Soft Turn On/Off Circuit
Discrete Wire Connections
Gold Plated RCA connectors
Variable Gain Control
Heavy-Duty Aluminum Alloy Heat Sink
4-Channel
Power per Channel: 250W x 4
Output Bridged: 500W x 2
Total Maximum Output: 1000 Watt
Minimum Impedance: 2 Ohms
2-Way Built-In Crossover (Front)
2-Way Built-In Crossover (Rear)
Bass/Treble Boost
RCA Inputs
S/N Ratio: 95 dB
Frequency Response: 15-30kHz
Dimensions(WxHxL): 7.9" x 2" x 16"
Pret 180 ron transport gratuit
2.Aplificator auto Renegate REN100S
4 x 250W max (4 ohms)
2 x 500W max (4 ohms) or 2 x 250W + 500W for sub.
MOSFET PWM switching supply with softstart
Variable low-pass crossover from 50-250Hz
High Pass crossover, 120hz - 3kHz
Bass Boost 0, 6, 12db switchable
high level & RCA inputs
dimensions: 250mm x 50mm x 200mm
Pret 180ron transport gratuit
ema_power
Localitate: Mangalia
Maşina: ford focus 2006
VIN: WF05XXWPD56T35090
Re: Vand Radio-CD 6000cd + amplificatoare
Mesajde ema_power » 24 Oct 2011, 16:34
Pretul la amplificatoare devine 170 ron per bucata, transportul gratuit!
ema_power
Mesajde ema_power » 27 Oct 2011, 12:20
Inca valabil!
ema_power
Mesajde ema_power » 30 Oct 2011, 10:17
^^ ^^ :D ^^ ^^
ema_power
Mesajde ema_power » 02 Noi 2011, 13:44
Se adauga USA AMP HMR560-4 PowerAcoustik
Pret 150ron transport inclus!
4 x 65W @ 4 ohm (0.04% THD)
4 x 80W @ 2 ohm
2 x 160W @ 4 ohm bridged
Freq. Response: 20Hz ~ 30kHz
S/N Ratio: 95 dB
Fuse: 2 x 20A
Dimensions: 13" x 10" x 2.3" (33cm x 25.4cm x 5.8cm)
HAMMER Series
ema_power
Mesajde popa_cristian » 02 Noi 2011, 13:49
In ce stare sunt?! Sunt noi sau second?! Ce imi recomanzi la masina din profil? am 6 boxe de 4 ohmi si 25w fiecare,daca iau amplificator mai adaug 2 boxe pe haion 200w una,deci 150w pe cele de pe masina+400w adaugate! Multumesc!
popa_cristian
Localitate: Caransebes
VIN: wfouxxgaju7l70403
Mesajde ema_power » 02 Noi 2011, 20:29
Amplificatoarele nu sunt noi, dar sunt perfect functionale.
Da, poti pune inca doua difuzoare bass in portbagaj sau numai un tub.
Acuma nu stiu ca player ai pe fusion. Daca e cel standar de fabrica si nu are iesire dedicata pentru amplificator iti recomand ultimul amplificator( USA AMP HMR560-4 PowerAcoustik), deoarece are si intrarare High-imput(adica iei semnal de la boxe).
Daca ai orice alt player care are iesire pentru amp, atunci iti recomand "Legacy LA1020"!
Eu personal am pe masina(FF2), pe langa boxele din fabrica inca un tub de bass + amplificator.
$1 scrie:$2n ce stare sunt?! Sunt noi sau second?! Ce imi recomanzi la masina din profil? am 6 boxe de 4 ohmi si 25w fiecare,daca iau amplificator mai adaug 2 boxe pe haion 200w una,deci 150w pe cele de pe masina+400w adaugate! Multumesc!
ema_power
Mesajde popa_cristian » 03 Noi 2011, 11:12
E CD original 6000.Nu prea ma pricep la statii si vreau sa stiu ce mi s-ar potrivi la ce am scris!
popa_cristian
Mesajde ema_power » 03 Noi 2011, 11:49
In cazul tau, cel mai usor de integrat in sistemul audio al masini este "USA AMP HMR560-4 PowerAcoustik"(ultimul amplificator adaugat)!
ema_power
Mesajde popa_cristian » 03 Noi 2011, 11:54
Multumesc pt. raspuns,tinem legatura!
popa_cristian
Mesajde ema_power » 08 Noi 2011, 12:19
uppp .
ema_power
Mesajde ema_power » 08 Noi 2011, 13:06
uppp .
ema_power
Mesajde ema_power » 12 Noi 2011, 19:22
up .
ema_power
Mesajde ema_power » 17 Noi 2011, 18:20
valabil .
ema_power
Mesajde XRRtm » 18 Noi 2011, 08:35
6000CD se potriveste pe un Mondeo din 2002?
XRRtm
Localitate: Feldkirch
Maşina: Mondeo MK3 2.0i
Mesajde ema_power » 19 Noi 2011, 07:45
Doar daca ai 2din. Iti pot da dimensiunile sau imi poti face tu o poza la bord!
ema_power
Mesajde ema_power » 24 Noi 2011, 18:10
up !
ema_power
Mesajde ema_power » 30 Noi 2011, 17:56
^^ ^^ :D ^^ ^^
ema_power
Mesajde alex77xax » 01 Dec 2011, 08:38
Radio cd-ul se potriveste pe un Fusion din 2003 ?
alex77xax
Maşina: BMW E46
Mesajde ema_power » 01 Dec 2011, 14:47
Da se potriveste!
ema_power
Mesajde ema_power » 11 Dec 2011, 11:22
Cd playerul 6000cd 250ron insotit de mufa intrare aux!
ema_power
Mesajde ema_power » 14 Dec 2011, 18:33
valabil !
ema_power
Mesajde ema_power » 16 Dec 2011, 14:51
upp !
ema_power
Mesajde ema_power » 29 Dec 2011, 11:35
Amplificatoarele scad la 120 ron + transport!
ema_power
Mesajde ema_power » 03 Ian 2012, 10:01
Se adauga subwoofer Blaupunkt GTt1200SC nou nout nefolosit niciodata, primit cadou dar nu imi este de folosinta!
Caracteristici principale:
Putere: 200 W
Diametru: 30 cm
Specificatii:
Putere Maxima: 200 W
Raspuns in frecventa: 35 - 500 Hz
Impedanta la iesire: 4 Ohm
Sensitivitate: 91 dB
Alte caracteristici:
Culoare: negru
Dimensiuni: 484 x 328 mm
Pret 180ron!
ema_power
Mesajde ema_power » 09 Ian 2012, 10:19
Aplificatorul 1.Aplificator Legacy LA1020 vandut!
ema_power
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 75 vizitatori
În total sunt 75 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 75 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
