VAND:AMPLITUNERE,BOXE,CD-URI,EPSON TM-U220A +ALTE ELECTR.
1.amplituner SONY STR-DE 135 pret 300 ron.
SPECIFICATIONS
Photo: US model
Audio power specifications (US model)
POWER OUTPUT AND TOTAL HARMONIC DISTORTION
With 8-ohm load, both channels driven, from 20 – 20,000 Hz,
rated 100 watts per channel minimum RMS power, with no
more than 0.09 % total harmonic distortion from 250 milliwatts
to rated output.
Amplifier section
Stereo mode (8 ohms at 20 Hz – 20 kHz less than
0.09 % total harmonic distortion)
100 W + 100 W (US model)
(DIN 1 kHz, 4 ohms)
60 W + 60 W (AEP, UK models)
Frequency response TV/SAT, CD, MD/TAPE, VIDEO
(US model)
2.CD DENON DCD 485
stare foarte buna,aspect ok,fata de rca are si iesire digitala optica.
pret 240 ron usor disc.
3.BOXE ONKYO SC-360 pret 300 ron
110W/6ohm
stare foarte buna,se aud foarte frumos,clar,bass bun.
4.MINIPRINTER EPSON TM-U220A PRET 110 EURO BUC.
Metoda de tiparire Imprimanta matriciala cu 9 ace
Caracteristici tiparire Fonturi : 7x9/9x9; Numar coloane : la 76 mm : 42/40/35/33, la 69,5 mm:40/36/32/30 cpl, la 57,5 mm: 33/30/27/25 cpl; Marime caractere : 1.2/1.6/1.7/1.9/2.0(h)x3.1(H); Caractere per Inch : 17.8/16/14.5/13.3
Interfete RS-232
Buffer/Memorie Buffer : 1 KB sau 40 bytes; memorie logo 128 kB, 8 kB
Viteza de tiparire 6 linii pe secunda la 30 cpl
Hartia Dimensiuni : 76 mm +/-0.5;Diametru maxim : 83 mm
Culoarea ribonului mov, negru, rosu-negru
Auto cutter Integrat (tip A si B), "un punct stanga netaiat"
Puterea consumata 31 W
Sursa de alimentare Adaptor AC este continut in pachet
Mentenanta MTBF: 180.000 ore; MCBF : 18 milioane linii; Auto cutter : 800.000 taieri
Dimensiuni Tip A: 160 mm (l) x 286 mm (L) x 158 mm (H); Tip B: 160 mm (l) x 248 mm (L) x 139 mm (H); Tip D: 160 mm (l) x 248 mm (L) x 139 mm (H);
Culoarea gri inchis
Dotare Standard Functie Jurnal (tip A); Autocutter (tip A si B); Incarcare hartie "Drop-in"; Integrat functia 'Auto-Status-Back' (ASB); Senzor terminare hartie; AC-Adapter C
nu se vinde cu cablu de date.am 2bucati
TEL. 0764735494
BUCURESTI
- Fişiere ataşate
- img11.jpg (6.88 KiB) Vizualizat de 6620 ori
catalin34 - Member
- Localitate: bucuresti
- Maşina: ford sierra berlina cu kit rs 2000 ohc
