Vand amplificator auto Kenwood KAC-719
Mesajde stx-ford » 04 Dec 2011, 16:22
Pret 200 ron sau 300 de ron cu subwoofer de 200 W clarion incinta imbracata in mocheta + toate cablurile (alimentare,masa,rca,siguranta pe fir etc.)
Audio section
Rated Power Output
(4 ohm,20-200Hz) ................................. 150W(0.08%THD)
(DIN45324,+B=14.4V) .......................... 150W
(2 ohm,100Hz) ...................................... 230W(0.8%THD)
Max Power Output(4 ohm) ........................ 300W
Low-Pass Filter(18dB/oct) ......................... 50-200Hz
Infrasonic Filter(18dB/oct) ......................... 15/25Hz(18dB/oct)
Bass Boost Circuit ..................................... 0dB,6dB,12dB(90Hz)
Frequency Response(+0,-3dB) ................. 5-200Hz
S/N Ratio ................................................... 100dB
Sensitivity(Max) ......................................... 0.2V(Rated Output)
Sensitivity(Min) .......................................... 5V(Rated Output)
Input Impedance ....................................... 10k
Damping Factor......................................... over 2000(at Sigma Connect)
General
Operating Voltage ..................................... 14.4V(11V~16V allowable)
Current Consumption ................................ 21A at rated power
Installation Size
(W) ........................................................ 290(mm) 11-7/16(in)
(H) ......................................................... 56(mm) 2-3/16(in)
(D) ......................................................... 200(mm) 7-7/8(in)
Weight ....................................................... 3.04kg
telefon 0720.605.879
SW
amp
stx-ford
Maşina: Ford Fiesta 1.3 TDCi ,2006
Re: Vand amplificator auto Kenwood KAC-719
Mesajde stx-ford » 07 Dec 2011, 09:41
250 de ron , accept schimburi
stx-ford
Mesajde stx-ford » 12 Dec 2011, 12:32
150 de ron statia + cablurile aferente
stx-ford
