VAND INTERFATA DE DIAGNOZA AUTO UNIVERSALA - NOUA ELM327
Mesajde marcy_rody » 25 Dec 2011, 23:37
CITESTE CODURILE DE EROARE, SI LE ANULEAZA, TEST DYNO!
ULTIMA VERSIUNE FIRMWARE!! Versiunea: 1.5A
Firmware: Version 1.5A
Transfer baud rate: Baudrate 9600 / 38400
Input interface: OBDII male 16pin
Output protocol: RS232
Output interface: USB 2.0
Indicator LED: OBD Tx (yellow) /Rx (green), PC RS232 Tx/Rx, Power (red)
Operating Voltage: 12V, including over voltage /shortage protection
Nominal Idle current: 45mA
Net Weight: 0.12KG
Wire Length: 175cm
Power: supplied by car OBD socket
Set the maximum number of responses to obtain
Remove spaces from ECU responses (to speed data transmission)
Store a unique identifier in EEPROM
Set the CAN mask and filter with one command
Easily switch between variable and fixed CAN message lengths
Send CAN remote frames (RTRs)
Suporta urmatoarele protocoale:
OBD, OBDII, EOBD2
ISO 14230-4 (KWP2000)
ISO 9141-2 (5 baud init. 10.4 kbaud, replaced by 14230-4 gradually, stopped in USA in 200
ISO 15765-4 (CAN-B 125Kbps, CAN-C 500Kbs, started since 2003 in USA)
SAE J1850 VPW (10.4 kbaud, replaced by 14230-4 gradually, stopped in USA in 200
SAE J1850 PWM (41.6 kbaud, replaced by 14230-4 gradually, stopped in USA in 200
SAE J1939 the Data link connector standard
ISO KWP (5 baud init, 10.4 kbaud)
ISO KWP (fast init, 10.4 kbaud)
ISO CAN (11 bit ID, 500 kbaud)
ISO CAN (29 bit ID, 500 kbaud)
ISO CAN (11 bit ID, 250 kbaud)
ISO CAN (29 bit ID, 250 kbaud)
Masini suportate:
Alfa Romeo , Audi, Austin, Bedford, Bentley, BMW, Chevrolet, Chrysler, Citroen, Corvette, DACIA, Daewoo, Daihatsu, Daimler, Datsun, Dodge, Ferrari, Fiat, Ford, Hillman, Honda, Hyundai, Isuzu, Jaguar, Jeep, Kia, Lada, Lamborghini, Lancia, Land Rover, Lexus, Lotus, Maserati, Mazda, Mercedes-Benz, MG, Mini, Mitsubishi, Morgan, Morris, Nissan, Peugeot, Porsche, Proton, Renault, Rover, Saab, Seat, Skoda, Smart, Ssangyong, Subaru, Sunbeam, Suzuki, Talbot, Toyota, Triumph, TVR, Vauxhall/ Opel, Volkswagen, Volvo.
Pentru unele dintre masini este necesar cablu adaptor.
Merge pe toate masinile cu OBD2 (dupa anul 1996 ) si la masinile cu EOBD ( Benzina dupa anul 2001 si masini diesel dupa 2003/2004 in Europe).
EOBD:
Europe 2001.01~ Benzina
Europe 2004.01~ Diesel
USA 1996.01~ Benzina
Asia 1996.01~ Benzina, Diesel
Japan 2005~ (Toyota, Nissan, Suzuki)
Aplicatia care insoteste interfata are urmatoarele functionalitati:
• Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
• Clear trouble codes and turn off the MIL ("Check Engine" light)
Display current sensor data, including:
• Engine RPM
• Calculated Load Value
• Coolant Temperature
• Fuel System Status
• Vehicle Speed
• Short Term Fuel Trim
• Long Term Fuel Trim
• Intake Manifold Pressure
• Timing Advance
• Intake Air Temperature
• Air Flow Rate
• Absolute Throttle Position
• Oxygen sensor voltages/associated short term fuel trims
• Fuel System status
• Fuel Pressure
• Data graphing and logging
• Freeze Frame data
• Continuous and Non-Continuous Oxygen Sensor test results
Pachetul contine:
• Interfata ELM327 (Mufa OBD2,Cablu USB)
• CD (Drivere si SOft)
Alte aplicatii functionale cu aceasta interfata:
• Scantool.net
• GM Mode 22 Scan Tool by Terry
• OBD Gauge for PalmOS and Pocket PC by Dana Peters
• OBD Logger by Jonathan Senkerik
• OBD-II ScanMaster by Wladimir Gurskij (ScanMaster 3.52 - local copy)
• obd2crazy.com
• OBD2 Scantool by Ivan Andrewjeski
• OBDII for ELM322 by David Huffman
• pyOBD by Donour Sizemore for MacOSX and Linux
• RDDTC by Pete Calinski
• Real Scan by Brent Harris
• ScanTest for Pocket PC by Ivan Ganev aka a-ser
• wOBD by WDT
Interfata se preda si cu soft de diagnoza:
1. ScanMaster ELM ver. 2.0
2. PCMScan
3. ScanTool. net
PRET 180 RON
0730951503 IN BUCURESTI
marcy_rody
Maşina: Ford Mondeo
VIN: WFO4XXGBB45DOO465
Re: VAND INTERFATA DE DIAGNOZA AUTO UNIVERSALA - NOUA ELM327
Mesajde oli_77 » 28 Dec 2011, 00:29
oli_77
Localitate: giurgiu
Maşina: focus turnier 2000 1.6 16v ghia cutie automata
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 46 vizitatori
În total sunt 46 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 46 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
