Diverse audio
Diverse audio
Mesajde ema_power » 09 Ian 2012, 10:35
Subwoofer Blaupunkt GTt1200SC nou nout nefolosit niciodata, primit cadou dar nu imi este de folosinta!
Caracteristici principale:
Putere: 200 W
Diametru: 30 cm
Specificatii:
Putere Maxima: 200 W
Raspuns in frecventa: 35 - 500 Hz
Impedanta la iesire: 4 Ohm
Sensitivitate: 91 dB
Alte caracteristici:
Culoare: negru
Dimensiuni: 484 x 328 mm
Pret 180ron!
2.Aplificator auto Renegate REN100S
4 x 250W max (4 ohms)
2 x 500W max (4 ohms) or 2 x 250W + 500W for sub.
MOSFET PWM switching supply with softstart
Variable low-pass crossover from 50-250Hz
High Pass crossover, 120hz - 3kHz
Bass Boost 0, 6, 12db switchable
high level & RCA inputs
dimensions: 250mm x 50mm x 200mm
Pret 120ron
3.USA AMP HMR560-4 PowerAcoustik
Pret 120ron inclus!
4 x 65W @ 4 ohm (0.04% THD)
4 x 80W @ 2 ohm
2 x 160W @ 4 ohm bridged
Freq. Response: 20Hz ~ 30kHz
S/N Ratio: 95 dB
Fuse: 2 x 20A
Dimensions: 13" x 10" x 2.3" (33cm x 25.4cm x 5.8cm)
HAMMER Series
Ceas nixie cu lampi Z573M, se livreaza impreuna cu alimentator.
Pret 180ron. Lampile sunt luate de pe forum si sunt noi!
ema_power
Localitate: Mangalia
Maşina: ford focus 2006
VIN: WF05XXWPD56T35090
Re: Diverse audio
Mesajde ema_power » 21 Ian 2012, 18:47
ema_power
Re: Diverse audio
Mesajde ema_power » 24 Ian 2012, 22:28
valabil .
ema_power
Re: Diverse audio
Mesajde ema_power » 11 Mar 2012, 22:34
:geek: :ugeek: :oops: :lol: 8-) :idea: :twisted: :o :mrgreen:
ema_power
