VAND Boxe OMNITRONIC, laser disco si ventilo-convector
Mesajde andrein » 10 Feb 2012, 15:33
BOXE Omnitornic Control 5 + suporti perete.
* 2-way speaker-system
* For a wide frequency range
* Wide dynamic-range with almost linear frequency range
* High-quality bass-system
* Also perfect for decentral sound-surroundings
* Wall-mounting also available
Rated power: 75 W RMS
Program power: 100 W
Components: 8" woofer, 1" tweeter
Connections: terminal
Max. SPL (1 m): 90 dB
Impedance: 8 ohms
Frequency range: 40 Hz - 20 kHz
Dimensions (H x W x D): 255 x 230 x 400 mm
Weight: 6 kg
Suportul de perete:
* Wall/ceiling mounting for Control 5
* Very stable version
* Inclination angle adjustable within approx. 45°
* Fixation screw with tooth gear for absolutely tight grip
* With eyelet for attaching the safety rope for norm approved installation
Material: white steel
Maximum load: 10 kg
Dimensions (WxDxH): 110 x 200 x 260 mm
Pret pereche boxe + suporti: 350 lei - negociabil !
Laser Disco SHINP TP-2028:
Laser verde cu efect precum o matrice. Produce multe puncte laser care se rotesc si produc si flashuri. Efect de artificii.
Laser: 50mW@532nm, 100mW@650nm, Green and Red DPSS laser
Dimensiuni: 300x200x100 mm
Greutate: 2,9 kg
Alimentare: 220V, 50Hz
Control: SOUND, DMX512 (9 canale), Master/Slave
Sound control, peste 100 modele (in funtie de sunet)
Pret 700 lei negociabil.
VentiloConvector Marca Ferroli TOP FAN VM-F 30:
Ferroli VM-F 40 este un ventiloconvector cu 2 tevi, carcasat, cu aspiratie frontala pentru incalzire si racire.
Aparatul se poate instala pe perete, pe pardoseala sau vertical pe plafon.
Unitatea este formata din: schimbator de caldura din tevi de cupru si aripioare din aluminiu, ventilator din aluminiu si motor , filtru de aer, structura portanta din otel galvanizat si carcasa din elemente de plastic si tabla galvanizata, acoperita cu pulberi epoxi polimerizate la cald.
Optional vetiloconvectorul poate fi dotat cu un schimbator de caldura suplimentar.
Putere frigorifica: 2100 W
Putere termica: 5500 W
Dezumidificare: 500 g/h
Debit aer: 220/310/410 m3/h
Putere sonora: 39/45/52 dB(A)
Racorduri baterie principala: 3/4"
Greutate: 21 Kg
Pret de nou: 1400 lei
Pret 740 lei
Contact pe mesaj privat aici pe forum sau n e c h i f o r a n d r e i @ y a h o o . c o m (fara spatii intre litere)
tel: 0723143858
Multumesc,
andrein
Re: VAND Boxe OMNITRONIC, laser disco si ventilo-convector
Mesajde andrein » 16 Feb 2012, 15:25
Boxe: Pret pereche boxe + suporti: 350 lei - negociabil !
Laser Disco SHINP TP-2028: Pret 700 lei negociabil.
VentiloConvector Marca Ferroli TOP FAN VM-F 30: Pret 740 lei- negociabil !
andrein
Mesajde andrein » 20 Feb 2012, 08:32
andrein
Mesajde andrein » 21 Feb 2012, 08:12
andrein
Mesajde andrein » 24 Feb 2012, 08:11
andrein
Mesajde andrein » 27 Feb 2012, 08:28
andrein
Mesajde andrein » 01 Mar 2012, 08:06
andrein
Mesajde andrein » 06 Mar 2012, 08:02
VentiloConvector Marca Ferroli TOP FAN VM-F 30: Pret 700 lei- negociabil !
andrein
Mesajde andrein » 09 Mar 2012, 08:04
andrein
Mesajde andrein » 12 Mar 2012, 08:29
andrein
Mesajde andrein » 14 Mar 2012, 08:07
andrein
Mesajde andrein » 15 Mar 2012, 08:01
andrein
Mesajde andrein » 19 Mar 2012, 07:54
Boxe: Pret pereche boxe + suporti: 300 lei - negociabil !
Laser Disco SHINP TP-2028: Pret 500 lei negociabil.
VentiloConvector Marca Ferroli TOP FAN VM-F 30: Pret 550 lei - negociabil !
andrein
Mesajde andrein » 22 Mar 2012, 08:05
andrein
Mesajde andrein » 26 Mar 2012, 07:15
andrein
Mesajde andrein » 29 Mar 2012, 07:10
andrein
Mesajde andrein » 02 Apr 2012, 14:44
andrein
Mesajde andrein » 05 Apr 2012, 07:03
andrein
Mesajde andrein » 09 Apr 2012, 10:31
andrein
Mesajde andrein » 12 Apr 2012, 07:05
andrein
Mesajde andrein » 17 Apr 2012, 06:55
andrein
Mesajde andrein » 23 Apr 2012, 12:33
andrein
Mesajde andrein » 25 Iun 2012, 09:44
andrein
Mesajde andrein » 29 Iun 2012, 08:08
Laser Disco SHINP TP-2028: Pret 400 lei negociabil.
andrein
Mesajde andrein » 02 Iul 2012, 07:02
andrein
Mesajde andrein » 05 Iul 2012, 07:05
andrein
Mesajde andrein » 09 Iul 2012, 06:48
andrein
Mesajde andrein » 12 Iul 2012, 07:06
andrein
Mesajde andrein » 16 Iul 2012, 06:57
andrein
Mesajde andrein » 24 Aug 2012, 10:27
andrein
