vind schimb sau dezmembrez ford mondeo 1996 benzina 1.6 16v
Mesajde lucianbenu » 19 Apr 2012, 01:21
vind schimb sau dezmembrez ford mondeo 1996 benzina 1.6 16v pret per total 600e neg 0726684038 id lucianbenu
lucianbenu
Localitate: cluj
Re: vind schimb sau dezmembrez ford mondeo 1996 benzina 1.6
Mesajde domitian » 24 Apr 2012, 13:13
m-ar interesa toba finala, daca este in stare buna
poza si pret , te rog
domitian
Mesajde lucianbenu » 09 Mai 2012, 16:09
1. Motor 1600 cmc 115cp……….1000ron
2. C.V. 1600cmc cp ----------500 ron
3. Planetare 1.6---------------150 ron
4. Caseta directie- servo -----200 ron
5. Electromotor 1.8; -------- 250 ron
6. Alternator 1.6; ------------200 ron
7. Compresor AC ----------------400 ron
8. Conducte AC -----------------300 ron
9. Radiator AC -----------------200 ron
10. Aeroterma -------------------100 ron
11. Instalatie AC complecta -----900 ron
12. Pompa servodirectie 1.6;----250 ron
13. Pompa servofrana ------------50 ron
14. Pompa benzina ---------------200 ron
15. Debitmetru aer ---------------200 ron
16. Bobina inductie -------------200 ron
17. Delcou + sensor hall ---------150 ron
18. ABS ( pompa + sensori + electrica)-400 ron
19. Calculator ABS ---------------150 ron
20. Calculator motor -------------200 ron
21. Airbag volan +pasager+centralina -400 ron
22. Senzori motor ----------------50 ron
23. Senzori ABS-------------------60 ron/buc
24. Injectie completa ------------400 ron
25. Motoras stergator fata sau spate--100
26. Parbriz ----------------------250 ron
27. Geamuri laterale --------------50 ron
28. Capota -----------------------250 ron
29. Saltea izolator fonic capota---50 ron
30. Haion + luneta ---------------300 ron
31. Eleron -----------------------100 ron
32. Aripa fata -------------------150 ron
33. Aripa spate ------------------150 ron
34. Trager -----------------------200 ron
35. Radiator apa -----------------200 ron
36. Termocuple racier ------------100 ron
37. Faruri ------------------------250 ron/set
38. Semnalizari simple ---------50 ron/buc
39. Lampi spate -----------------200 ron/set
40. Bara fata flexibila -------300 ron
41. Bara spate flexibila ------200 ron
42. Intaritura bara fata--------100 ron
43. Grila fata ------------------100 ron
44. Usi originale --------------150 ron/buc
45. Maner usa -------------------20 ron
46. Fete usi interior -----------50 ron/buc
47. Bandou usa ------------------25 ron/buc
48. Scaune + banchete normale ---150 ron
49. Mocheta fata + spate ---------50 ron
50. Capitonaj plafon ------------100 ron
51. Bord cu tuburi ventilatie --- 100 ron
52. Sistem ventilare complet, --100 ron
53. Torbedou ---------------------100 ron
54. Volan cu airbag---------------1500 ron
55. Ansamblu volan ----------------60 ron
56. Contact ----------------------100 ron
57. Ceasuri bord cu turometru -200 ron
58. Brat semnalizor ---------------50 ron
59. Brat modul stergatoare --------50 ron
60. Brat modul stergatoare cu MFA--80 ron
61. Bloc lumini--------------------50 ron
62. Catalizator pentru 1.6; ------150 ron
63. Toba evacuare detenta -------50 ron
64. Telescop fata sau spate ----70 ron
65. Arc fata sau spate ----------70 ron
66. Punte + discuri completa--450 ron
67. Repartitor frana -----------------80 ron
68. Fuzeta in 4 prezoane ------80 ron
69. Etrier fata ----------------- 60 ron
70. Etrier spate ------------------80 ron
71. Disc fata sau spate -----------50 ron
72. Tambur frana complet ----------50 ron
73. Cadru motor -----------------150 ron
74. Suport motor -----------------150 ron
75. Cheder usi --------------------15 ron
76. Cheder geam -------------------15 ron
77. Vas: lichid antigel; spalare --30 ron
78. Cabluri: frana; capota; ; etc-40 ron
79. Lonjeron inferor -------------150 ron
80. Lonjeron superior ------------100 ron
81. Prag tabla -------------------100 ron
82. Plafon -----------------------150 ron
83. Diverse plastice interior -----20 ron
84. Instalatie electrica ----------100 ron
85. Macara + motoras geam ----200ron
86. Oglinda manuala ---------------60 ron
87. Oglinda electrica --------------100ron
88. Arcade plastic roti -----------100 ron
asta ii lista preturile sunt negociabile daca se cumpara mai multe piese 0757366793 0726684038
lucianbenu
Localitate: cluj
Mesajde lucianbenu » 09 Mai 2012, 16:10
$1 scrie:$2ind schimb sau dezmembrez ford mondeo 1996 benzina 1.6 16v pret per total 600e neg 0726684038 id lucianbenu
preturi neg daca se cumpara mai multe piese
lucianbenu
Localitate: cluj
Mesajde lucianbenu » 10 Mai 2012, 16:10
noua lista de preturi
1.Elemente de caroserie:
- aripi s+d 100Ron
- usi(geam+macara+ormanemt+tabla+inchizatori):
- stgF 200Ron
- drF 150Ron
- stgS 100Ron
- drS 100Ron
- capota fatza 200Ron cu sprituitoare, mantie si inchizatoare
- bara fatza 200Ron cu suportii de prindere
- bara spate 100Ron cu suportii de prindere
- faruri s+d 300Ron
- treger 100Ron cu inchizatoarele de capota
- masca fatza superioara (tabla) 150Ron
- partea din spate(aripi+fund) 150Ron
- lampi stopuri: 100Ron s+d
- semnalizatoare fatza 50Ron s+d
- parbriz 100Ron
- haion 200Ron
- interior(scaune+banchete+tavan+panouri) 200Ron
- restul de caroserie la remat 200Ron
2.Elemente de mecanica:
- caseta directie: 200Ron cu capetele de bara
- suspensie fatza: 300Ron (amortizoarele+arcurile+flansele)
- suspensia spate: 200Ron (amortizoarele+flansele+arcurile)
- bratele fatza + spate 6: 150Ron
- punte spate cu bucsele: 50Ron
- bara torsiune+bielete antiruliu: 50Ron f+s
- discuri de frana: 150Ron toate 4
- fuzete cu rulmenti, etrieri frana si placute si furtune: 200Ron
- instalatia de frana de mana: 100Ron
- pompa principala de frana+abs cu calculator si senzori: 300Ron
- volan+coloana+airbag+contact: 200Ron
3.Elemente de motor si transmisie:
- motor complet(cu toti suportii, alternator, demaror, pompa servo, galerii A si E, sonda L, debitmetru si calculator, comanda acc, instal de racire apa, ulei si radiatoare + pompa benz): 1000Ron cu tot cu puntea fta
- cutie de viteze automata: 300Ron
- planetare: 200Ron ambele
- toba integrala: 200Ron cu prinderile elastice aferente
4.Elemente de bord:
- afisajbord 100Ron
- intrerupatoare de bord 200Ron
- panou clima: 200Ron
- sistemul audio: 100Ron
- maciuca schimbator+husa+timonerie 100Ron
lucianbenu
Localitate: cluj
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 34 vizitatori
În total sunt 34 utilizatori conectaţi :: 0 înregistraţi, 0 invizibili şi 34 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
