PIESE FORD TRANSIT si nu numai(ORIGINALE SI AFTERMARKET)
Mesajde reall_boy » 01 Ian 2013, 16:14
PIESE NOI ORIGINALE,preturile se pot schimba in functie de stoc
Ford Transit 2000-2006
-disc frana fata
-disc frana spate
-placute frana fata
-rulment fata
-electromotor
-rola intinzatoare
-pompa ambreiaj( plastic sau metal)
-volanta
-Rulment + simering roata spate
-Flansa + rulment amortizor
-saboti frana
-fuzeta
-fulie motor
-set yale
-tampon cutie(tractiune fata)
-culisante etrier fata spate
-faruri
-COROANA CU PINION DIFERENTIAL
-butuc roata fata
-furtun radiator (tractiune fata)
-arc fata
-volanta
-kit ambreiaj
FORD TRANSIT dupa 2006
-kit ambreiaj
-volanta
-planetara(tractiune fata)
-placute fata
-placute spate
-fulie motor
-valva EGR
-pompa servo
-electromotor
-disc frana fata
-disc frana spate
-rulment fata
-lampa stop
-rola intinzatoare
-intinzator
-bieleta antiruliu fata
-pompa ambreiaj
-set filtre(aer,ulei,motorina)
-flansa amortizor
-pompa vacum
-POMPA FRANA+VAS
-intercooler
-fulie alternator
-alternator
-flaps bara fata
-tren fix (cutie viteze)
-faruri
-aripa(stanga,dreapta)
-capac filtru ulei
-piston motor
-senzor ABS
-bieleta motor
-piese schimb electromotor(diverse)
-capota
-bara fata
-bara spate
-usa fata
-usa culisanta
-set yale
-arc spate cu o foaie
-culisante etrier spate
-cabluri timonerie cutie viteze
-tampon cutie viteze
-pivot
-sonda rezervor(litrometrica)
-segmenti piston
-cuzineti palier
-amortizor fata
-amortizor spate
-curea agregate (tractiune fata)
-rampa culbutori
-punte spate
-valva pompa injectie
-injector
-furca ambreiaj
-cutie viteze
-proiector ceata
-conducata retur injectoare
-butuc roata fata
FORD CONNECT
-furtun intercooler
-tampon cutie
-rulment planetara
-planetara
-lampa stop
-furtun radiator
-set filtre(aer,motorina,ulei)
-conducta caseta servo la pompa servo
-tampon motor
-kit distributie
-vas spalator parbriz
-kit ambreiaj
-pompa ambreiaj
-placute frana fata
-saboti frana spate
-faruri
-alternator
-set yale
-claxon
-cablu alimentare bujii
-suport baterie
-intinzator
-grila fata intre faruri
-flaps bara spate
-rulment roata fata
-bucsi bara stabilizatoare
-bileta antiruliu fata
-bielta antiruluiu spate
-pompa apa
-pompa servo directie
-airbag volan
-centura fata
-butuc roata fata
-fuzeta
-oglinda completa
-rola de ghidaj
-bascula fata
-furtun frana
-burduf planetara
FORD FOCUS 1999-2004
-furtun intercooler
-placute fata
-placute spate
-saboti spate
-cablu frana de mana
-kit distributie
-pompa ambreiaj
-suport motor stanga
-intinzator curea
-kit distrubutie focus 1.6 tdci
-planetara stanga
-pompa apa
-rulment ambreiaj
-kit ambreiaj
-tampon cutie
-tampon motor
-rulment roata fata
-amortizor fata
FORD FOCUS C-MAX
-planetara fata
-planetara spate
-kit ambreiaj
-rument ambreiaj
FORD MONDEO
-rulment ambreiaj hidraulic
-volanta
-fulie motor
-compresor A/C
si multe alte piese chiar si pentru alte marci...nu ezitati sa intrebati .Pentru cei din judetul constanta se poate asigura si montajul pieselor (contra cost - mecanici autorizati - preturi f bune)
reall_boy
Localitate: constanta
Maşina: ford focus.2003,
VIN: WFONXXBEIM6550120
