VIN - Date despre masina - eTis
Re: VIN - Date despre masina - eTis
Mesajde bogdan_croitoru79 » 08 Dec 2017, 15:57
Buna ziua
Vreau sa cumpar un Focus 3 din germania si vreau sa aflu , daca se poate, cat mai multe informatii (km reali si dotari) pt acest VIN:
WF0LXXGCBLBM87814
Va multumesc
bogdan_croitoru79
Mesajde adrian.apreotesei » 08 Dec 2017, 16:17
$1 scrie:$2una ziua
WF0LXXGCBLBM87814
Va multumesc
Cu detalii va ajut eu, dar cu km nici nu stiu daca merita cautat. convingerea mea este ca voi cumpara masina si nu km ei. Merge bine, uzura e minima, nu a fost lovita serios si mai ales daca se "lipeste" la inimioara si la portofel atunci aia e.
SUCCES
Focus 2011-2015, 1.6L Duratorq CR TC (115PS) - DV6, Panther Black (Metallic)
VIN Number: WF0LXXGCBLBM87814
Type Approval Number (TAN): E13*2007/46*1138
Primary Features
Build Date: 22.11.2011
Vehicle Line: Focus 2011-2015
Body Style: 4 Door Estate
Version: Series 32
Engine: 1.6L Duratorq CR TC (115PS) - DV6
Transmission: 6 Speed Manual Trans - B6
Drive: LHD FWD
Axle Ratio: 3.61
Emission: Stage V Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"D"
Paint: Panther Black (Metallic)
Interior Fabric: Rack/Gecko Charcoal Black (B-C)
Minor Features
Less Roof Reinforcement
Less Roof Line Conversion
Less Rear Mudflaps
Less Front Door Sill Protection
Accessory Media Hub 1XUSB
Less Interior Pack
Less Front Mudflaps
Less Hill Launch Assist
Rear Passenger Door
With Manual Liftgate
Saarlouis Plant Built
Less Security Lock Group
Less Special Equipment Package
Ford Corporate Badge
Marketing Flex Prep Pack 6
Less Sales Badge
Less Special Order Paint
Less SVO Application/Label
Marketing Level 1
Less Dress Up RSO
(-) SVP
Less SIP
Exterior Paint - Solid
For Normal Temperature Zones
Less VP Application Label
Econetic Tailgate Badge
Less Mass Customization Package
Less Fire Extinguisher Fixings
Less Tyre Repair Service Kit
With Auto Closing Windows
Power Front Windows One Touch Up/Do
Power Rear Window One Shot Up/Down
With Privacy Glass
Grille - Upper Chrome Bar/Surround
Less Windshield Heat Shielding
With Heated Windscreen
Less Console Ashtray
Less Temp Controlled Glove Box
With Padded Dash
With Mini Overhead Console
With Small Floor Console
Less Rear Floor Console
Int Environment Clr-Charcoal Black
Int Feat Colour - Charcoal Black
Less Front Floor Mats
Less Rear Floor Mats
With General Stowage Box
Less Sun Blinds
With Conventional Headlining
Sunvisor-Driver Vinyl W/Mirr Insert
Sunvisor-Pass Vinyl W/Mirr Insert
With Aluminum Interior Door Handles
With LH Front Door Armrest
With RH Front Door Armrest
Less Stowage Bins
Less Rear Coat Hook
Less Luggage Compartment Net Kit
Less Load Area Cover
With Load Space Tie Down Loop
Less Load Retention Net
Less Decklid Liner
With Load Floor Carpet
Less First Aid Retain Straps
Less W.Triangle Retaining Straps
Less Interior Partition
Less Driver Roof Storage
Less Front Grille
Grille-Lower Surround - Dk Slf Clr
Roof Rack Without Crossbars
Less Exterior Body Mouldings
Rocker Panel Moulding -Cladding C/K
Less Exterior Door Frame Mouldings
Less Door Edge Guards
Less Auxiliary Roof Rack Crossbars
Less Spoiler
With Dipping Rear View Mirror
Dual Pwr/Heat/Fold/Pud Lamp/Signal
With Body Coloured Exterior Mirror
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
With Front 2 Way Headrest
With Driver Seat Recliner - Rotary
With Passenger Seat Recliner-Rotary
Less Seat Track Covers
Less Special Seat Covers
Less Special Front Seat Covers
Less Special Rear Seat Covers
With Two Piece Rear Seat Cushion
With 60:40 Split - Folding Rr Seat
With Integrated Rear Headrest
Less Rear Seat Centre Armrest
With Rear Center Head Restraint
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With Drvr/Passngr Seat Belt Minder
With Driver 4 Way Mnl.Seat Adjuster
With Pass 2 Way Manual Seat Adjust
Less Trailer Coupling
Less Towing Pre-Pack
With Front Towing Hook
With Rear Towing Hooks
Less Trailer Sway Control (TSC)
Engine Cover - Under Hood
Body Coloured Exterior Door Handle
Body Coloured Tailgate Handle
Ignition Flip Key With Remote Unit
With Moulded Gearshift Knob
Less Door Lock Shields
With Child Proof Safety Lock
With Remote Controlled Tailgate Release
With Second Remote Ign Flip Key
Less Door Auto Relocking
With Central Locking System
Less Door Unlock System
With Door Entry Remote Control Unit
Less Keyless Entry System
Capless Fuel Filler Without Lock
With Int. Rear Window Wiper/Washer
With Variable Intermittent Windscreen Wiper
With Heated Washer Jet
Less Headlamp Washer/Wiper
Less Sun Roof
With Tonneau Cover
Less Front Bumper Sensor Device
Front Bumper - Painted Body Colour
Less Front Bumper Extension
Rear Bumper Body Coloured Plastic
Less Rear Bumper Skirt
Less Thermoplastic Kneebolster Sys
Air Curtain Restraint LH
Air Curtain Restraint RH
Less Rear Side Air Bag Restraint
3 Part Seat Belt- European Regultn
Retractable Rear Seat Belt-3Point
With Driver Air Bag
With Passenger Air Bag
With Side Air Bag - Drivers Side
With Side Air Bag - Passenger Side
Less Passenger Air Bag Deactivation
With Isofix Hard Point Attachment
With Manual Adjust Frt.S.Belt Mount
Style 1 Tether Anchorage Restraint
Spare Wheel - Mini Steel
Less Tyre Pressure Sensors
With Standard Rear Shock Absorbers
7 X 16" Alloy Wheels
Limited Service Mini Spare Tyre
With Goodyear "All Weather" Front
With Goodyear "All Weather" Rear
Less Wheel Covers
Non Locking Lug Nuts
With Kysor Radiator Shutter
Less Engine Block Heater
Less Frame Mounted Fuel Filter
Cold Start -29 Deg C
Less Immersion Heater
Starter - Stop/Start System
With Standard Suspension
Front Spring Load Class-J
Rear Spring Load Class-W
Single Exhaust
Less Exhaust Pipe Extension
Less Handbrake Grip
With Mechanical Parking Brake
Standard Duty Fr/Rr Calp And Pads
With Rear Disc Brakes
Less Collision Mitigation System
Low Speed Safety System
With IVD/Traction Control/ABS
Less Rear Bumper Protector
3.72/2.04/1.25/.919/.738/0.622
Standard Front Seat
Less Rear Comp Duct
Less Air Purifier Sensor
With Recirculating Heater
Non Locking Capless Fuel Fill
With Diesel Fuel Capability
Less Gaseous Prep Pack
With Fixed Foot Pedals
Standard Foot Pedal Pad Design
With Electric Power Steering
With Manual Tilt/Slide Stg Column
Basic Type Steering Wheel
Less Speed Control
With Supplemental Air Heater
Less Park Heating
With Message Center Cluster I/P
With Instrument Cluster - Rheostat
With KMH Speedometer
With Trip Computer
Less Instrument Gauges
Dual Note Electric Horn
Less Tyre Inflation Monitor
Less Compass Display
Matrix Multi Function Display
Mobile Device Prep Pack
With Message Centre
Less Navigation Disk
Less Navigation Data
Less Emergency Call Button
Less Emergency Assistance
Less Driver Impairment Monitor
Less Blind Spot Information System
Less Lane Keeping Aid
Less Anti-Theft Alarm
With Safeguard Anti-Theft Sys(Pats)
With Rear Parking Aid
With Front Parking Aid
Less Side Parking Aid
With Automated Parking System
Standard Duty Battery
Less A/V Jack
BT/VC Phone Interface + USB Connect
ICE- Mid Audio (1C) W/Connectivity
Ice Feature Pack 3
Midline ICE ICP
Less Upgraded Sound System
With 6 Speakers
Less Radio Subwoofer
Less Telephone Preparation Pack
Less Mobile Office Pack
Less Family Entertainment System
Less Cell Phone Interface System
Less Sync
Voice Activated Module - German
With Steering Wheel Radio Controls
Less Column Stalk Radio Controls
Electrical Outlet
With Smokers Package
Less Power Point Plug
Less Power Point Plug - Rear
Less Camera
Less Cool Box
Less Style Pack
Less Comfort Pack
Less Auto Headlamps
With Bright Fog Lamp Bezel
With Halogen Headlamp
Less Daytime Running Lamps
With Front Fog Lamps
With Aluminium Headlamp Bezels
Less Interior Light Group
Less Footwell Lights
Less Header Mounted Map Light
With Front And Rear Lamp Bulb
Less Rear Overhead Reading Lamps
With Glove Box Illumination
With Load Compartment Lamp
Less Aux Interior Lights
Tail lamps - Level 1
With High Mounted Stop Lamp
With Single Rear Fog Lamp
With Front Headlamp Levelling
Less Headlamp Control
Less Accessory - Packages
Outside Air Temperature Present
adrian.apreotesei
Maşina: Ford KUGA ST Line
Mesajde andreikt » 12 Dec 2017, 10:38
Salut . Spuneti mi va rog daca masina asta are ESP. La test uk de led uri se aprinde ESP dar n am buton de activare sau dezactivare.
WF05XXGCD55K79217
andreikt
Localitate: iasi
Maşina: Ford Focus 2
Mesajde jeffe » 12 Dec 2017, 11:15
Salut, nu are ESP: Less Electronic Stability Control
2016 Mondeo Titanium 2.0TDCi 180CP, Powershift, Deep Impact Blue
2008 Focus Cabriolet Titanium 2.0 Duratec-HE 145CP, MT, Acqua Blue
2014 Ford Mondeo Titanium 2.0 Ecoboost 240CP, MT, Blazer Blue
2012 Ford Mondeo Trend 2.0 TDCi 163CP, MT, Lunar Sky
2005 Ford Escape Hybrid 2.3 AT, AWD, Light Tundra
2011 Ford Focus Trend 1.6 TDCi 115CP, MT, Moondust Silver
Mondeo Mk3 2007, Mondeo Mk4 2010, Mondeo Mk3 2001, Mondeo Mk4 2011, Kuga Mk1 2011, Kuga Mk2 2015, Kuga Mk2 2017, Galaxy Mk2 2011, Mondeo Mk5 2015,Focus Mk2 2006, Mondeo Mk4 2009, Kuga Mk1 2012, Mustang 2015, Edge 2016
jeffe
Maşina: Mondeo Mk5 2016, 2.0 TDCi 150CP, Titanium
VIN: WF0EXXWPCEFTXXXXX
Mesajde MadSailor » 12 Dec 2017, 11:50
WF0DXXGAKDDM78423 = vreau sa stiu daca am CB ca mie imi arata doar nr de km si trip.Multumesc
MadSailor
Maşina: Ford Fiesta Trend 1.5 Tdci 75 ponei
Mesajde dobregabriela » 12 Dec 2017, 11:53
Buna ziua . Va rog mult sa ma ajutati si pe mine cu verificarea serie VIN WF0WXXGCDW5C36692. Vreau sa cumpar aceasta masina . VA multumesc mult !!
dobregabriela
VIN: WF0WXXGCDW5C36692
Mesajde adrian.apreotesei » 12 Dec 2017, 12:16
$1 scrie:$2F0DXXGAKDDM78423 = vreau sa stiu daca am CB ca mie imi arata doar nr de km si trip.Multumesc
Fiesta 2012-, 1.5L SOHC DI TC I4 Diesel DV5, Frozen White
VIN Number: WF0DXXGAKDDM78423
Registration Number: B-49-UWI
First Registration Date: 10.04.2013
Registration Country: RO
Type Approval Number (TAN): E9*2001/116*0069 / E9*2007/46*0002
Primary Features
Build Date: 14.03.2013
Vehicle Line: Fiesta 2012-
Body Style: 5 Door Saloon
Version: Series 30
Engine: 1.5L SOHC DI TC I4 Diesel DV5
Transmission: 5 Speed Manual Transaxle - B5/IB5
Drive: LHD FWD
Axle Ratio: 3.37
Territory: (+)"RO"
Paint: Frozen White
Interior Fabric: Match Point/View Charcoal Black
Minor Features
Less Rear Mudflaps
Less Interior Pack
Less Front Mudflaps
With Hill Launch Assist
Brake System - Regenerative
Less Bulkhead
Niehl Plant Built
Less Sales Badge
Marketing Level 1
Less Dress Up RSO
(-) SVP
Less SIP
Less Paint Package
Less Cooling Pack
With Rear Package Tray
Less Global/Auto Closing
With Manual Rear Windows
With Tinted Glass All Round
Standard Green Glass Windscreen
Less Heated Windscreen
Low Line Cubby Box
With Velour Front Floor Mats
With Velour Rear Floor Mats
With Full Headlining - Moulded
Drivers Visor Mir/Flap/Tick Pocket
With Cloth Door Trim Panel Insert
Less Rear Seat Ash Tray
Less Load Rest
With W/Triangle. Retainer Straps
Less Exterior Rocker Panel Moulding
Less Rear Window Protector
With Rear Spoiler
Dual Power Htd Signal Mirrors
With Fixed Rear Seat Cushion
With Split Fold-Down Rear Seat
With 2 Way Adjustable Rear Headrest
Seat Back Material-Carpeted
Less Driver Seat Lumbar Support
With 2nd Row Folding Seat
Leather/Aluminium Gearshift Knob
Soft Feel Gear Shift Boot
Door Entry R/Cont Flip/Fixed Key
With Trans Linked Rr Washer/Wiper
V/Intermittent With Anti-Drip Wipe
Front Bumper - Chrome Insert
Rear Bumper-Body Colour/Lwr Accent
Rear Bumper Beam
Belt D & P Fr 1 & 2 Row/D Kne Bag
Inflatable Knee Bolsters - Driver
With Driver Air Bag
With Passenger Air Bag Deactivation
Seat Belt Pretensioners Drv/Pass
With Steel Spare Wheel
6J x 15 Steel Wheel
195/50HR x 15 Tyres
With Standard Tyre Tread - Front
With Standard Tyre Tread - Rear
Any Brand Tyre Vendor
With Styled Wheel Cover
Less Hub Covers
Components Unique For Steel Wheels
Cold Start -25 Deg C
Standard Electric Starter Motor
With Front Stabilizer Bar
With Plastic Moulded H/Brake Grip
With Front Disc-Brake/Rr Drum Brake
With Non Painted Brake Calipers
Less Low Speed Safety System
Brakes-HLA/ESP/TC/ABS
3.58/1.92/1.20/.87/.68/3.61
Standard Front Seat
With Pollen Filter
Fuel Tank Fill Neck-With Inhibiter
With Polyurethane (Hard) Wheel
Less Speed Control
Less Auxiliary Heater
High Series Analog Cluster
Less Tripminder Assy
Single Note Electric Horn
Less Outside Temp Thermometer
Less Navigation System
Less Speed Audible Warning Device
With Engine Immobilizer - Integral
Less Rear Parking Aid
Less Front Parking Aid
With A/V Jack
Less Bluetooth
ICE- Low Audio (0C)
With ICE Feature Pack 11
Midline ICE ICP
4 Speakers Front / 2 Speakers Rear
With Media Gateway Module
LM4 German/UK Eng/EU French/Italian
Less Smokers Package
Less Cigar Lighter
With Power Point Plug
Less Camera
Less Pwrpoint Plug-Load Compartment
With Complx Refect Headlamp Design
With Daytime Running Lamps
Less Cornering Lamp
With Header Courtesy Light
With Courtesy Light Delay
With Rear Overhead Courtesy Lamp
Tail lamps - LED Rear
Less Puddle Lamps
With Conventional Headlamp Control
adrian.apreotesei
Mesajde adrian.apreotesei » 12 Dec 2017, 12:17
$1 scrie:$2una ziua . Va rog mult sa ma ajutati si pe mine cu verificarea serie VIN WF0WXXGCDW5C36692. Vreau sa cumpar aceasta masina . VA multumesc mult !!
Focus 04-08/Focus C-MAX 03-07, 1.6L Duratorq TDCi (90PS) - DV6, Tonic (Metallic)
VIN Number: WF0WXXGCDW5C36692
Registration Number: 18RZLD
First Registration Date: 24.10.2005
Registration Country: NL
Primary Features
Build Date: 23.09.2005
Vehicle Line: Focus 04-08/Focus C-MAX 03-07
Version: Series 20
Engine: 1.6L Duratorq TDCi (90PS) - DV6
Transmission: 5-Speed Manual Trans - MTX75
Drive: LHD FWD
Emission: Stage IV Emissions
Territory: (+)"NL"
Paint: Tonic (Metallic)
Interior Fabric: Stripy/Generic Blue / Dark Flint
Minor Features
With Convenience Group
Less Marketing Flex Prep Pack
Less Functional Upgrade Pack
Marketing Level 1
Power Front Windows One Touch Down
Less Overhead Console
Less Cargo Stowage Rack/Rail
Less Roof Rack
Drivers Remote Convex Mirror
Passenger Remote Convex Mirror
Less Rear Centre Headrest
With Non Illuminated Key
Less Sun Roof
With Driver Air Bag
Less Isofix Hard Point Attach
6J x 15 Steel Wheel
195/65VR x 15 Tyres
With Full Wheel Cover
Less Brake Emergency Assist
4 Wheel Anti-Lock Braking System
Less Skid Plates
Standard Front Seat
4 Spoke Leather Steering Wheel
With Speed Control
Less Radio Pre-Equipment Pack
(+)RDS
Less A/V Jack
With Centre Antenna
ICE-Low Level CD + AM/FM Radio
ICE Feature Pack 20
With 6 Speakers
With Column Stalk Radio Controls
With Auto Headlamps
adrian.apreotesei
Mesajde adrian.apreotesei » 12 Dec 2017, 12:20
$1 scrie:$2alut . Spuneti mi va rog daca masina asta are ESP. La test uk de led uri se aprinde ESP dar n am buton de activare sau dezactivare.
WF05XXGCD55K79217
Focus 04-08/Focus C-MAX 03-07, 1.8L Duratorq-DI HPCR (115PS) Lynx, Sea Grey (Metallic)
VIN Number: WF05XXGCD55K79217
Primary Features
Build Date: 26.10.2005
Version: Series 35
Engine: 1.8L Duratorq-DI HPCR (115PS) Lynx
Drive: LHD FWD
Air Conditioning: Dual Zone Auto Temp Control A/C
Territory: (+)"F"
Paint: Sea Grey (Metallic)
Interior Fabric: Cubical / Dark Flint
Minor Features
Security Lock Group No.1
Convenience Group No.3
Marketing Level 1
With Cooled Glove Box
With Short Floor Console
Front Floor Carpet Mats
With Electrochromic R/View Mirror
Drivers Power Heated Convex Mirror
With Pass Convex Elec/Heated Mirror
With Leather Gear Shift Knob
With Automatic Windscreen Wiper
With Driver Air Bag
6.5 x 16" Wheel Style L
205/55VR-16 BSW Tyre
Less Skid Plates
Standard Front Seat
With Speed Control
Conventional Instruments - Level 2
(+)RDS
Less A/V Jack
With Centre Antenna
ICE Feature Pack 20
With 6 Speakers
With Auto Headlamps
With Footwell Lights
With Automatic Headlamp Control
adrian.apreotesei
Mesajde andreikt » 12 Dec 2017, 16:33
Multumesc frumos
andreikt
Localitate: iasi
Mesajde kretzu80 » 14 Dec 2017, 10:04
Salut... vreau si eu detalii despre vin Wf05xxgbb53t53154.... ce dotare exista pentru incalzirea auxiliara... multumesc anticipat!
kretzu80
Localitate: Motru
VIN: Wf05xxgbb53t53154
Mesajde adrian.apreotesei » 15 Dec 2017, 09:01
$1 scrie:$2alut... vreau si eu detalii despre vin Wf05xxgbb53t53154.... ce dotare exista pentru incalzirea auxiliara... multumesc anticipat!
Mondeo 2001-2007, 2.0L Duratorq DI HPCR (125PS), Panther Black (Metallic)
VIN Number: WF05XXGBB53T53154
Primary Features
Build Date: 27.08.2003
Vehicle Line: Mondeo 2001-2007
Version: Series 56
Engine: 2.0L Duratorq DI HPCR (125PS)
Transmission: 6 Speed Manual Transaxle - MMT6
Axle Ratio: 4.071/2.850
Air Conditioning: Automatic Air Conditioning
Territory: (+)"D"
Interior Colour: Ebony Interior
Interior Fabric: Verona Grain Leather
Minor Features
Genk Plant Build
Marketing Level 1
(-) SVP
With Electronic Stability Control
Spare Wheel Warning Sticker
With Privacy Glass
With Monotone Instrument Panel
Rear Floor Carpet Mats
Electric Operated Rear View Mirror
Dual Power/Htd/Fold/Pud Lamp Mirror
Rear Centre Armrest With Stowage
With Drivers Heated And Cooled Seat
With Pass Heated And Cooled Seat
With Passenger Seat Belt Minder
With Driver 8 Way Pwr.Seat Adjuster
With Pass 8 Way Power Seat Adjuster
With Wooden Gear Shift Knob
With Rear Window Wiper/Washer
With Headlamp Washer/Wiper
Power Tilt/Slide Sun Roof
Deployable Anti-W'Lash Restr
With Smart Drivers Airbag Restraint
With Smart Passngr Airbag Restraint
17" X 6.5 7 Spoke Alloy Wheel
With Conventional Spare Tyre
Locking Wheel Nuts
With Anti-Spin Traction System
Filter Cowl Intake - Odour
With Electrically Enhanced Heater
With Full Walnut Steering Wheel
With Speed Control
With Symbol Fuel Computer
Navgtn Sys With Colour Touch Screen
With Reverse Proximity Sensor
Perimeter / Volume Theft System
External Auxiliary 6 CD Changer
With Tri Band Antenna
ICE-Nav High CD+AM/FM Radio
Ice Feature Pack 3
Ice Feature Pack 5
Ice Feature Pack 59
Less Diversity Antenna
4 High Series Speaker Co-Axial
With Family Entertainment System V2
High Intensity Discharge Headlamp
With Automatic Headlamp Levelling
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
adrian.apreotesei
Mesajde gabi03 » 20 Dec 2017, 17:29
Va salut!
As vrea si eu cat mai multe detalii despre VIN WF0HXXGAJH7P34008.
Am incercat in etis si nu am reusit sa gasesc mai nimic, posibil sa nu stiu eu sa caut...
Multumesc mult de ajutor.
gabi03
Maşina: Ford Fiesta mk7 / 1.0 ecoboost / 2015
VIN: WF0DXXGAKDFM76084
Mesajde adrian.apreotesei » 20 Dec 2017, 17:35
$1 scrie:$2a salut!
Fiesta/Fusion 2002, 1.25 Zetec-S/Duratec DOHC EFI(75PS), Tango (Metallic)
VIN Number: WF0HXXGAJH7P34008
Primary Features
Build Date: 08.12.2007
Vehicle Line: Fiesta/Fusion 2002
Version: Series 20
Engine: 1.25 Zetec-S/Duratec DOHC EFI(75PS)
Drive: LHD FWD
Axle Ratio: 4.25
Territory: (+)"RO"
Paint: Tango (Metallic)
Interior Fabric: Kyoto / Pewter/Ebony
Minor Features
Less Front Mudflaps
Less Bulkhead
Niehl Plant Built
Less Exterior Dress Up Package
Less Cold Weather Group
Exterior Appearance - Level 1
Less Electronic Group
Less Visibility Package
Exterior Paint - Metallic
Less Decal
Less Luxury Package
Less Saloon/Sedan Conversion Pack
With Power Front Windows
With Fixed Rear Vent Quarter Window
With Console Ashtray
Interior Environment Colour-Ebony
Interior Feature Colour-Dark Pewter
Front Floor Mats - Rapid Spec/MSS-C
Rear Floor Mats - Rapid Spec/MSS-CS
Less Special Inter Appliques
Less Spoiler
With Dual Remote Exterior Mirrors
With Black Exterior Mirror
Less Drivers Seat Armrest
Less Second Remote Ignition Key
Less Door Entry Remote Control Unit
Less Sun Roof
Less Bodyside Accent Stripe
Dual Colour Front Bumper
With Plastic Rr.Bumper-Dual Colour
Less Air Curtain Restraint
With Driver Air Bag
Less Side Air Bag - Drivers Side
5 1/2J x 14 Semi-Styled Steel Wheel
175/65 TR14 LW Roll Resistance
14" Family Wheel Cover - Style B
Less Hub Covers
MK70 - 4 Wheel Anti-Lock Brakes
Gear 3.58/1.93/1.28/0.95/0.76
Less Aux SVO/DSO Heater
Low Series Analog Cluster
Less Reverse Proximity Sensor
With A/V Jack
Roof Mounted Radio Antenna
Ice Feature Pack 8
With 4 Speakers
Less Telephone
Less Voice Activated Modules
With Cigar Lighter
Less Front Fog Lamps
With Header Mounted Map Light
Less Courtesy Light Delay
adrian.apreotesei
Mesajde gabi03 » 20 Dec 2017, 21:03
Multumesc foarte mult pt raspuns si mai ales pt rapiditate, adrian.apreotesei.
O seara buna!
gabi03
Mesajde geosan11111 » 22 Dec 2017, 13:55
Detalii despre masina mea cu VIN WF0HXXWPBHBU71238
Am incercat in ford etis dar nu imi apare
FORD GRAND C-MAX 2011 2.0 TDCI 140(170) CP
geosan11111
Localitate: SLOBOZIA
VIN: WF0HXXWPBHBU71238
Mesajde adrian.apreotesei » 22 Dec 2017, 15:06
$1 scrie:$2etalii despre masina mea cu VIN WF0HXXWPBHBU71238
C-Max 2010-2015, 2.0L Duratorq CR TC (140PS) - DW10C, Dark Micastone
VIN Number: WF0HXXWPBHBU71238
Type Approval Number (TAN): E13*2007/46*1103
Primary Features
Build Date: 13.10.2011
Vehicle Line: C-Max 2010-2015
Body Style: 5 Door MAV
Version: Series 55
Engine: 2.0L Duratorq CR TC (140PS) - DW10C
Drive: LHD FWD
Axle Ratio: 3.81/2.77
Territory: (+)"RO"
Paint: Dark Micastone
Interior Fabric: Pur/Lux / Syracus
Minor Features
Less Rear Mudflaps
Less Cargo Stowage Device
Less Interior Pack
Less Front Mudflaps
Rear Sliding Passenger Door
Less Brake System-Regenerative
With Under Floor Stowage
Valencia Plant Built
Less Convenience Group
Less Sales Badge
Marketing Level 1
Less Dress Up RSO
(-) SVP
(-)'Sport'
Less Program Controls
Less Police Equip Pack
Less Premier Package
(-) Taxi Prep Pack
With Privacy Glass
Grille - Upper Blk Msh/Chrome Surnd
With Heated Rear Window
Less Run Flat System
With Padded Dash
With High Series Overhead Console
Full Floor Console With Armrest
Int Environment Colour - Fairland
Interior Feature Colour - Syracus
With Standard 3rd Row Floor Mats
With Trunk Stowage Bin
Less Sun Blinds
Deluxe Headliner
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
With Instrument Panel Stowage Bin
Less Front Roof Grab Handle
Load Space Adjust Drivers/Stwg Box
With Load Floor Clover
Less Front Grille
Lower Grille - Hgh Gls W/Chrm Smile
Roof Rack - Aluminium
With Bright Door Frame Moulding
Less Spoiler
Less Drivers Exterior Mirror
Less Passenger Exterior Mirror
Less Driver Seat Back Map Pocket
Less Passenger Seat Back Map Pocket
Less Fold Flat Front Passenger Seat
Less Front Seat Centre Armrest
Less Under Seat Stowage Facility
Less Passenger Seat Armrests
Less Passenger Seat
Tray/Table - Front Seat
Less Rear Seat Fold Down
With Passengers Man Lumbar Support
With Drivers Heated Seat
With Heated Passenger Seat
Seat Belt Minder-D/P/2/3 EU TL/SD
Sec Row 60/40 (3 P)-Easy Entry
Third Row Dual Individual Seat
With Pass 4 Way Manual Seat Adjust
Ignition Key Combination Pack 1
Child Proof RR Door Lock + Elec Rel
With Keyless Start
Less Sun Roof
With Tonneau Cover
Rear Bumper-Painted Body Colour
Less Restraint Devices
Rear Seat Belt Pre-Tensioner
Less Beltminder
With Inertia Front Seat Belt
Rear Seat Belts-3rd Row
With Driver Air Bag
Tyre Pressure Monitor Sys-DDS
8X18 ET 55MM Alloy Wheel
Less Wheel Covers
Market Road Condition - General
Less Radiator Shutters
Frame Fuel Filter - Heavy Duty
With Preprogrammed Speed Limit
Less Remote Starter
Front Spring Load Class-R
Rear Spring Load Class-V
Single Exhaust
Less Handbrake Grip
Mechanical Hand Operated Park Brake
3.58/1.95/1.24/0.86/0.94/0.78
Standard Front Seat
With Rear Duct / B-Pillar
With Pollen Filter
Less Air Conditioning
Speed Control And ASLD
Less Park Heating
With Trip Computer
With Message Centre
Less Lane Departure Warning System
Less Automated Parking System
(-)ARI/RDS
Less Auxiliary Compact Disc Player
Less A/V Jack
Less Radio Antenna
Ice Feature Pack 3
Midline ICE ICP
With 6 Speakers
Less Radio Suppression
Less Sync
Voice Activated Module - British
Electrical Outlet
Less Camera
Less Cool Box
Less Style Pack
Less Homelink
With Auto Headlamps
With Chrome Fog Lamp Bezel
Interior Lighting-Ambient LED
Fr Individual and Rr Map Lights
Front And Rear Lamp LED
adrian.apreotesei
Mesajde dima_ro » 28 Dec 2017, 21:13
Salut, doresc informatii despre masina mea vin WF05XXGCD57L89343.
kilometrii nu iam verifcat la cumparare :)
dima_ro
VIN: WF05XXGCD57L89343
Mesajde buattila » 30 Dec 2017, 14:17
Buna Ziua , m-ar interesa si pe mine VIN-ul WF0LXXGCBLBL19093 , vreau sa cumpar masina ... multumesc mult.
Focus 2014, 2.0L Duratorq 163PS Panther Black (Metallic)
buattila
Maşina: Ford Focus MK3 Titanium
VIN: WF0LXXGCBLET41101
Mesajde costin.badoiu » 02 Ian 2018, 17:30
$1 scrie:$2in pacate nu te pot ajuta decat dupa 20 august deoarece sunt plecat din tara.
Sent from my LG-P500 using Tapatalk
Pe mine ma poti ajuta cu toate datele pt. un ofrd mondeo cu seria WF05XXGBB55D00717.TE ROG FRUMOS CU TOATE DATELE, KM, ACCIDENTE,ETC
costin.badoiu
VIN: WF05XXGBB55D00717
Mesajde VIPER » 02 Ian 2018, 22:04
@costin.badoiu: cu km si accidente nu te poate ajuta nimeni daca masina nu a fost cumparata de la 0km din tara si nu a facut reviziile la dealeri. Masina ta e de Danemarca...
Mondeo 2001-2007, 2.0L Duratorq DI HPCR (115PS), Platinum Metallic
VIN Number: WF05XXGBB55D00717
Primary Features
Build Date: 30.11.2005
Version: Series 40
Engine: 2.0L Duratorq DI HPCR (115PS)
Drive: LHD FWD
Territory: (+)"DK"
Paint: Platinum Metallic
Interior Fabric: Ink Blue Tria / Ebony
Minor Features
Genk Plant Build
Less Dress Up RSO
With Insulator
Less Roof Rack
Dual Power Heated Exterior Mirrors
Driver Heated Seat-Variable Temp
With Heated Pass Seat-Variable Temp
Heated Rear Seat - Variable Temp
With Seat Belt Warning Chime
Door Entry R/Cont Unit - 2 Keys
Less Sun Roof
6.5 X 16" Steel Road Wheel
With Fuel Fired Heater
With Speed Control
With Perimeter Anti-Theft
Ice Feature Pack 1
With 4 Speakers
With Cigar Lighter
VIPER
Localitate: Bucuresti, RO
Mesajde cosmindaniel » 07 Ian 2018, 16:31
Salut, stie cineva un link sau are cineva un etis cu crack? Ma chinui de 2-3 zile sa instalez unul si nu merge deloc...
cosmindaniel
Localitate: Jilava
Maşina: Ford CMax 2008 1,6TDCI 109HP,TITANIUM 17"
VIN: WF0EXXGCDE8S81359
Mesajde comisaru1368 » 07 Ian 2018, 17:41
Salutare as dori sa stiu si eu ce a avut masina de fabrica si ce pot sa mai adaug eu
fata de ce am acum mufe sunt destule am inteles ca este precablata WF0NXXGCDNXM58057 multumesc.
comisaru1368
Localitate: calarasi
VIN: WF0NXXGCDNXM58057
Mesajde Eddy19SEM » 09 Ian 2018, 00:53
$1 scrie:$2alutare as dori sa stiu si eu ce a avut masina de fabrica si ce pot sa mai adaug eu
Focus 1998-2005, 1.6L Zetec-S/Duratec EFI (100PS), Diamond White 73
VIN Number:
WF0NXXGCDNXM58057
REB140
18.02.2000
SE
Primary Features
Build Date:
26.11.1999
Vehicle Line:
Focus 1998-2005
Body Style:
4 Door Estate
Version:
Series 20
Engine:
Transmission:
Drive:
LHD FWD
Axle Ratio:
4.06
Emission:
EEC 96 Car (EEC 1)
Air Conditioning:
Territory:
(+)"S"
Paint:
Diamond White 73
Interior Fabric:
Finesse / Midnight Black
Minor Features
Security Lock Group #11
Less Power Equipment Group
Marketing Level 1
Less Dress Up RSO
Less Safety Packs
(-) C170 FOB CLX SVP
(-) C170 FOB SI SVP
(-) C170 FOB Ghia X SVP
(-)'Car Of The Year'Special Edition
Less Luxury Package
Less Roof Rack
Less Spoiler
Less LH Lumbar Support
Less RH Lumbar Support
With Illuminated Key
Remote Deck/Tailgate Release
Less Sun Roof
With Driver Air Bag
5 1/2J x 14" Steel Road Wheel
185/65 x 14H Tyres
With Heavy Duty Suspension
Less Attitude/Ride Height Pack
Standard Front Seat
Less Speed Control
Less Auxiliary Warning Display
Less ICE Pack
Less Speaker
Less Telephone
Eddy19SEM
Localitate: Curtea de Arges
Maşina: Ford Focus III Hatchback 1.6 EcoBoost 150HP Titanium X
VIN: WF0KXXGCBKBS61387
Mesajde dima_ro » 09 Ian 2018, 21:53
$1 scrie:$2alut, doresc informatii despre masina mea vin WF05XXGCD57L89343.
Ma ajuta cineva??
dima_ro
Mesajde Eddy19SEM » 10 Ian 2018, 09:59
Focus 04-08/Focus C-MAX 03-07, 1.6L Duratorq TDCi (90PS) - DV6, Moondust Silver (Metallic)
VIN Number: WF05XXGCD57L89343
Type Approval Number (TAN): E13*2001/116*0144, E13*2001/116*0157
Primary Features
Build Date: 03.05.2007
Version: Series 32
Drive: LHD FWD
Territory: (+)"RO"
Paint: Moondust Silver (Metallic)
Interior Fabric: Humy / Mondus / Dark Flint
Minor Features
Trend SVP
Silver Appliques - IP No.2
Less Roof Rack
Less 2nd Row Rear Seat
Less Sun Roof
Less Air Curtain Restraint RH
With Driver Air Bag
7.0 X 16" Alloy Style E
With Brake Emergency Assist
Less Skid Plates
Standard Front Seat
With Speed Control
(+)RDS
Less A/V Jack
With Centre Antenna
ICE Feature Pack 20
With 6 Speakers
With Cornering Lamp
Eddy19SEM
Mesajde BESTIA692 » 10 Ian 2018, 17:50
Ma puteti ajuta cu un numar de km pentru WF0WXXGCDW7L05797 si cand a fost ultima data intr-un service sau reprezentanta?
BESTIA692
Maşina: Ford focus 1.6 tdci
Mesajde Claudiu Neagu » 13 Ian 2018, 10:07
SAlutare!am constatat atunci cand am inmatriculat masina ca motorul nu are serie,deci probabil a fost schimbat iar acum sunt foarte curios daca pot afla cati km are acest motor fara serie! vin-ul este WF0NXXGCDNWG59843 !Va multumesc anticipat!
Claudiu Neagu
Localitate: Giarmata,Timis
Maşina: Ford focus 1.8 16v
VIN: WF0NXXGCDNWG59843
Mesajde comisaru1368 » 14 Ian 2018, 23:36
VIN Number:
WF0NXXGCDNXM58057
REB140
18.02.2000
SE
Primary Features
Build Date:
26.11.1999
Vehicle Line:
Focus 1998-2005
Body Style:
4 Door Estate
Version:
Series 20
Engine:
Transmission:
Drive:
LHD FWD
Axle Ratio:
4.06
Emission:
EEC 96 Car (EEC 1)
Air Conditioning:
Territory:
(+)"S"
Paint:
Diamond White 73
Interior Fabric:
Minor Features
Marketing Level 1
Less Dress Up RSO
Less Safety Packs
(-) C170 FOB SI SVP
Less Luxury Package
Less Roof Rack
Less Spoiler
Less Sun Roof
With Driver Air Bag
185/65 x 14H Tyres
Standard Front Seat
Less Speed Control
Less ICE Pack
Less Speaker
Less Telephone
... multumesc..
comisaru1368
Mesajde cloter » 17 Ian 2018, 18:01
Salutare!
Sunt nou pe aici iar de curand mi-am luat un mondeo mk4 1.8 tdci 125, fabricatie 29.10.2007 Imi poate spune cineva ce distributie are? daca se poate si alte informatii legate de ea. Multumesc frumos!
VIN : WF0EXXGBBE7U20090
cloter
