VIN - Date despre masina - eTis
Re: VIN - Date despre masina - eTis
Mesajde reptilaverde » 25 Ian 2024, 08:02
Salut! Mă puteți ajuta și pe mine cu lista de dotări? Mulțumesc! WF0JXXGAJJCA13750
reptilaverde
Mesajde jeffe » 25 Ian 2024, 10:30
DETAILED VEHICLE SPECIFICATION - WF0JXXGAJJCA13750
DESCRIPTION 2012 Fiesta - B1 (B299 EU)
PRODUCTION DATE 2012/03/22
VEHICLE LINE Fiesta 2008-2012
FUEL TYPE GASOLINE
BODY CAB STYLE 5 Door Saloon
VERSION/SERIES SERIES 30
PLANT OF MANUFACTURE NIEHL, COLOGNE PLANT BUILD
ENGINE 1.25L Duratec DOHC EFI(80PS)
TRANSMISSION 5 Speed Manual Transaxle - B5/ (IND=M)
DRIVE TYPE 2 WHL L/H FRONT DRIVE
AXLE RATIO 4.06 FINAL DRIVE RATIO
EMISSIONS STAGE V EMISSIONS
AIR CONDITIONING MANUAL AIR CONDITIONER
TIRE SIZE 195/50HR15 BSW
BUILD INFORMATION
LESS REAR SPLASH GUARDS
LESS FRT DOOR SILL PROTECTION
LESS ACCESSORY USB UNIT
LESS INTERIOR PACK
L/FRT SPLASH GUARDS/MUD FLAPS
LESS BRAKE SYSTEM-REGENERATIVE
LESS BULK HEAD
LESS TIE DOWN HOOKS
SECURITY LOCK GROUP #2
LESS SPECIAL EQUIPMENT PACKAGE
LESS CONVENIENCE GROUP
MARKETING FLEX PREP PACK 4
MARKETING FLEX PREP PACK 6
LESS SALES BADGE
LESS SPECIAL ORDER PAINT
LESS SVO APPLICATION/LABEL
LESS COLD WEATHER GROUP
LESS EXT APPEARANCE PACK
LESS ELECTRONIC GROUP
LESS POWER EQUIPMENT GROUP
LESS VISIBILITY PACK
LESS DRESS UP RSO
TREND S SIP
LESS SAFETY PACKS
LESS EXCEPT EAO SVP
LESS PAINT PACKAGE
DOOR DECAL-BLACKOUT
LESS COOLING PACK
LESS LUXURY PACKAGE
EXCEPT SVO EXCEPT PACKS
LESS INBOUND MODIFICATION CENT
LESS KIT-TIRE REPAIR SERVICE
PWR FRT W'DOWS ONE TOUCH UP/DN
MANUAL REAR SIDE WINDOW
TINTED GLASS-COMPLETE
STANDARD GREEN GLASS WNDSCRN
LESS WINDSHIELD HEAT SHIELDING
ELECTRIC WINDSHIELD DEFROSTER
LESS CENTER PANEL
INSTRUMENT PANEL-HIGH LEVEL
CONSOLE-WITH OPEN BIN
CONSOLE CUP HOLDER
INT ENVIRON COLOR-SYRACUS
INT FEAT-COLOR-SYRACUS
LHS/RHS POLYPRO PNL W/SPKR CO
LESS FRONT FLOOR MATS
LESS REAR FLOOR MATS
TRUNK STOWAGE BIN
MOLDED HEADLINER-COMPLETE
SNVSR-DRV/MIR/FLAP/TICK POCKET
DOOR HANDLES-INSIDE
DR TRIM PNL INSERT-PREM CLOTH
LESS REAR SEAT ASH TRAY
LESS REAR INTR ASSIST HNDL
LESS LOAD SPACE STOWAGE BOX
LESS CARGO AREA COVER
LESS LUGGAGE COMPARTMENT TRIM
FIRST AID RETAIN STRAP
LESS WARNING DEVICE RET STRAPS
LESS A PILLAR DEVICES
LESS DRIVER ROOF STORAGE
BRIGHT GRILLE
LESS GRILLE MOLDING
LESS EXTERIOR ROCKER PANEL MLD
LESS EXTERIOR BELT MOLDING
LESS RR WINDOW PROTECTOR
SINGLE WING REAR SPOILER-LARGE
DAY/NIGHT INSIDE MIRROR
DU PWR FOLD HTD SIGNAL MIRR'S
EXT MIRROR FINISH-BODY COLOR
DRV SEAT BACK MTD MAP POCKET
PASS SEAT BACK MTD MAP POCKET
LS PASS SEAT CUSHION EXTEN
LESS DRIVERS SEAT ARMRESTS
FRONT 2-WAY HEADRESTRAINTS
LESS SEAT-SPECIAL COVERS
REAR SEAT CUSHION-FIXED
REAR SEAT FOLD DOWN-SPLIT
REAR HEADRESTRAINT-2 WAY
HEADRESTRAINT-REAR CENTER
SEAT BACK MATERIAL-CARPETED
LESS LUMBAR SEAT SUP-DRIV SEAT
DRIVER HEATED SEAT
HEATED PASSENGER SEAT
ST BELT MNDR-DR&PAS/EU TEL&SND
SECOND ROW FOLDING SEAT
MANUAL 4-WAY DRV SEAT ADJUSTER
MANUAL 2-WAY PASS SEAT ADJUST
LESS TRAILER COUPLING
EXT DOOR HANDLE-BODY COLOR
LIFT/DECKLID HNDL EXT-BODY CLR
SOFT FEEL GEAR SHIFT KNOB
POWER DOOR LOCKS
LESS DOOR UNLOCK SYSTEM
DR ENT REM CNT UNIT-2 FLP KEYS
LESS KEYLESS ENTRY SYSTEM
LESS AUTO DOOR LOCKING DELAYED
TRANS LINKED RR WASHER/WIPER
VAR ITRMT WIPE+ANTI-DRIP WIPE
LESS MOONROOF PACK
LESS U/BODY CORROSION PROTECT
LESS ACCT STRIPE-BDYSD COLOR
LESS HOOD ACCENT STRIPE
FRNT BUMP-BODY COLR/LWR ACCENT
LESS FRONT BUMPER EXTENSION
REAR BUMP-BODY COLR/LWR ACCENT
LESS REAR BUMPER EXTENSION
BUMPER ENERGY REINFOREMENTS
LESS INFL KNEE BOLSTER-PASS
LESS AIR CURTAIN RESTRAINT-LH
LESS AIR CURTAIN RESTRAINT-RH
INFLATABLE KNEE BOLSTER DRIVER
RR SEAT BELTS-3 POINT/INERTA
AIR BAG RESTRAINT-DRIVER
AIR BAG RESTRAINT-PASS
DRVR SEAT AIR BAG HEAD-THORAX
PASS SEAT AIR BAG HEAD-THORAX
LESS PASS AIR BAG DEACTIVATION
ISOFIX HARD POINT ATTACHMENT
MANUAL ADJ FRT SEAT BELT MOUNT
FRT ST BLT BCKL PRE-TNS DRV/PS
SPARE WHEEL-CONVENTIONAL STEEL
6.0 X 15" STEEL ROAD WHEELS
195/50HR15 BSW
STANDARD TIRE TREAD-FRONT
STANDARD TIRE TREAD-REAR
ANY BRAND TIRE VENDOR
STYLED WHEEL COVERS
LESS HUB COVERS
NON LOCKING LUG NUTS
COMP UNIQUE FOR STEEL WHLS
LESS MPH SPEED GOVERNOR
STARTER EQUIPMENT (-25C)
STD ELECTRIC STARTER
STANDARD DUTY SUSPENSION
FRONT STABLIZER BAR
STAGE V EMISSIONS
LESS EXHAUST PIPE EXTENSION
PLASTIC HANDBRAKE GRIP
PARKING BRAKE - MECHANICAL
POWER FRT DISC/REAR DRUM
ELECTRONIC EMERG BRAKE ASSIST
EMER BRAKE LIGHT-HAZARD WARN
IVD/TRACTION CONTROL/ABS
LESS ANTI-SPIN TRACTION BRAKES
GEAR 3.58/1.93/1.28/0.95/0.76
SEAT-INDIVIDUAL-L/B DRV/PASS
FILTER COWL AIR INTAKE
RECIRCULATION HEATER
UNLEADED FUEL CAPABILITY
95 0CTANE LEVEL GASOLINE
FU/TNK FILL NK-WITH INHIBIT
FOOT PEDAL DESIGN - STANDARD
ELECTRIC POWER STEERING 1
STRG COLUMN-TILT/TELESCOPING
STEERING WHL-3 SPK LEATHER
LESS SPEED CONTROL
LESS STEERING WHEEL PACK
LESS AUXILIARY HEATER
LESS INTERIOR CLIMATE PACKAGE
LOW SERIES ANALOG CLUSTER
KPH SPEEDOMETER
TRIP COMPUTER
ECOMODE
TACHOMETER
SINGLE NOTE ELECTRIC HORN
OUTSIDE TEMP THERMOMETER
MATRIX MFD
LESS NAVIGATION CENTER
LESS NAVIGATION DATA
LESS REVERSE GEAR ALARM
LESS PROXIMITY SENSOR
LESS AUX WARNING DISPLAY
LESS ANTI-THEFT SYSTEM
ENG IMMOBILIZER THEFT SY-INTEG
LS INCLINATION ANTI-THEFT SENS
LESS FRONT PARKING AID
STANDARD DUTY BATTERY
A/V JACK + USB
BT/VC PHONE INTERFC+USB CONNEC
ROOF MOUNTED RADIO ANTENNA
ICE-MID LEVEL CD+AM/FM RADIO
ICE FEATURE PACK 74
HIGHLINE ICE ICP
LESS UPGRADED SOUND SYSTEM
4 SPEAKERS FRT/2 SPEAKERS RR
LESS CELLPHONE INTERFACE SYSTM
GERMAN LANGUAGE MODULE
STRG WHEEL RADIO CONTROLS
LESS SMOKERS PACKAGE
POWER POINT PLUG
LESS CAMERA
LESS AUTO HDLAMPS-FOL ME HOME
HM SAF LT DURATION-30 SECONDS
LESS FOG LAMP BEZEL
HEADLAMPS - LEVEL 1
DAYTIME RUNNING LAMPS
MIRROR MNTD TURN SIGNAL LIGHTS
FRONT FOG LAMPS
CONF INT LIGHT/BATT SAVER-30M
LESS INTERIOR LIGHT GROUP
HEADER COURTESY LIGHT
COURTESY LIGHT DELAY FEATURE
REAR OVERHEAD COURTESY LAMP
LOAD COMPARTMENT LIGHT
HIGH MOUNTED STOP LAMP
LESS PUDDLE LAMPS
FRONT HEADLAMP LEVELING
CONVENTIONAL HEADLAMP CONTROL
HOT MAGENTA
AUSTRIA
LESS NAVIGATION PACKAGE
2016 Mondeo Titanium 2.0TDCi 180CP, Powershift, Deep Impact Blue
2008 Focus Cabriolet Titanium 2.0 Duratec-HE 145CP, MT, Acqua Blue
2014 Ford Mondeo Titanium 2.0 Ecoboost 240CP, MT, Blazer Blue
2012 Ford Mondeo Trend 2.0 TDCi 163CP, MT, Lunar Sky
2005 Ford Escape Hybrid 2.3 AT, AWD, Light Tundra
2011 Ford Focus Trend 1.6 TDCi 115CP, MT, Moondust Silver
Mondeo Mk3 2007, Mondeo Mk4 2010, Mondeo Mk3 2001, Mondeo Mk4 2011, Kuga Mk1 2011, Kuga Mk2 2015, Kuga Mk2 2017, Galaxy Mk2 2011, Mondeo Mk5 2015,Focus Mk2 2006, Mondeo Mk4 2009, Kuga Mk1 2012, Mustang 2015, Edge 2016
jeffe
Maşina: Mondeo Mk5 2016, 2.0 TDCi 150CP, Titanium
VIN: WF0EXXWPCEFTXXXXX
Mesajde tenebre » 01 Feb 2024, 11:44
SAlutare. MA poti ajuta sa imi spui daca are adblue?
WF0UXXWPGUKS82813
tenebre
Maşina: Ford C-max 1.8 benzina 125 cp 2008
VIN: wf0exxgcde8k86390
Mesajde jeffe » 01 Feb 2024, 15:17
Salut, are AdBlue
DETAILED VEHICLE SPECIFICATION - WF0UXXWPGUKS82813
DESCRIPTION 2019 Tourneo Connect - HC
PRODUCTION DATE 2019/07/01
VEHICLE LINE Transit/Tourneo Connect 2013-
FUEL TYPE DIESEL
BODY CAB STYLE LWB Kombi
VERSION/SERIES SERIES 110V
PLANT OF MANUFACTURE VALENCIA (SPAIN) PLANT BUILD
ENGINE 1.5L EcoBlue (88kW/120PS)
TRANSMISSION 6 Speed Manual Trans - B6 Plus (IND=M)
AXLE RATIO 3.68 FINAL DRIVE RATIO
EMISSIONS EURO 6.2 EMISSIONS
AIR CONDITIONING MANUAL ELECTRIC AIR COND
TIRE SIZE 205/60R16
BUILD INFORMATION
LESS ROOF LINE CONVERSION
LESS ROOF WIRING HOLE
ACC MEDIA HUB 2X USB
LESS SEAT TRACK SENSORS
DUAL SIDE LOAD DOORS
HILL LAUNCH ASSIST
LESS MY KEY
LESS BULK HEAD
REAR CARGO DOOR-LIFTGATE
LESS CARGO DOOR CHECK ARMS
LESS MANUAL REGEN INITIATION
MAX PAYLOAD UPGRADE PK
BASE GVM RATING
LESS VERSION PACKAGES
LESS SPECIAL PURPOSE VEHICLE
COMPLETE VEHICLE
CALCULAT GVW OR PICK FRM TABLE
LESS MKT FLEX PREP PACK
LESS FUNCTIONAL UPGRADE PACK
MARKETING LEVEL 1
LESS DRESS UP RSO
LESS SVP
LESS EXCEPT EAO SVP
EXTERIOR PAINT - SOLID
2018 JOB #1 PROGRAM CONTROL
NORMAL TEMP ZONES
LESS DELETE PACK CATEGORY A
LESS MARKETING COMFORT PACK
LESS MARKETING DESIGN WHEEL PK
LESS MARKETING CV PACK
LESS MKT DRIVER ASSIST PACK
LESS MARKETING PROTECTION PACK
LESS MARKETING SEAT PACK
LESS MARKETING WINTER PACK
LESS REAR PACKAGE TRAY
LESS AIR DEFLECTOR-REAR WHEEL
LESS WINDOW/RF PNL AUTO CLOSE
PWR FRT WDO-1 TCH DWN-DR ONLY
POWER REAR SIDE WINDOW
REAR DARK TINTED GLASS
ACOUSTIC LAMINATED WINDSCREEN
SLIDING 2ND ROW R/H SIDE WNDOW
SLIDING 2ND ROW L/H SIDE WNDOW
FIXED 3RD ROW R/H SIDE WINDOW
FIXED 3RD ROW L/H SIDE WINDOW
FIXED REAR WINDOW
ELECTRIC REAR WINDOW DEFROSTER
LESS RR SEAT OVERHEAD CONSOLE
GLOVE BOX LID
LESS MID-VEH OVERHEAD CONSOLE
CENTRE CONSOLE-LEVEL 4
2 CUPHOLDERS
INT ENV COLOR- DK PALAZZO GREY
INT FEATURE COLOR-EBONY
SIDE/REAR DOOR TRIM PNL-LVL 2
FRONT THROW IN CARPET FLR MATS
FLR CVR-CARPET INS-PARTIAL
I/P STOWAGE BOX
SNVSR-PASS/MIRROR/FLAP
DOOR HANDLES-INSIDE BLACK
DOOR TRIM PANEL-LEVEL 2
REAR COAT HOOK
PVC DOOR ARMREST
B PILLAR ASSIST HANDLE
CARGO NET KIT (2)
CARGO COMPARTMENT NET
LOAD FLOOR CARPET
INTR GRAB HANDLES - FRONT
LESS ACCESS LADDER
GRILLE-SELF COLOR #3
ACTIVE GRILLESHUTTER
LESS ROOF RACK
WIDE BODYSIDE MOLDING
ELECTROCHROMIC INSIDE MIRROR
DUAL POWER/HEATED MIRRORS
EXT MIRROR FINISH-SELF COLOR
SMALL REAR VIEW MIRROR HOUSING
LS PASS ST BACK MTD MAP POCKET
SEAT PACK 25
LESS PASS SEAT ARMRESTS
DRIVER SEAT RECLINER-ROTARY
PASS SEAT RECLINER-LEVER
LESS TRAY/TABLE - FRONT
LESS REAR SEAT CENTER ARMREST
LUMBAR SEAT SUPT-DRIVER SEAT
LESS LUMBAR SEAT SUP-PASS SEAT
LESS UNDER SEAT STOWAGE-DRIVER
DRIVER HEATED SEAT
BLT MND-DR/PASS/2ND ROW/EU T&S
SECOND ROW 60/40 (3 P)-FOLDING
LESS THIRD ROW SEATING
FLIP/FOLD/TUMBLE PASS SEAT
LESS TRAILER TOW ATTACHMENTS
DETACHABLE TRAILER COUPLING
LESS TRAILER TOWING HITCH
LESS TOWING PRE-PACK
TRAILER SWAY CONTROL (TSC)
LESS DEVICE DOCK
LESS FUEL ECONOMY PACKAGES
LESS SMART ACCELER TRUNCATION
LESS CHILD MONITORING DISPLAY
EXT DOOR HANDLE-SELF COLOURED
LIFT/DECKLID HANDLE-SELF-COLOR
KEY COMBINATION PACK 1
URETHANE GEAR SHIFT KNOB
CHILD PROOF RR DOOR LOCKS
LESS FLEET KEY
LESS KEYED ALIKE OPTIONS
DOOR AUTO RELOCKING-ENABLED
CONFIGURABLE UNLOCKING-CONF 2
FREQUENCY - 433 MHZ
POWER DOOR LOCKS
LESS POWER LOCK GROUP
DOOR ENTRY REMOTE CNTR UNIT
REAR WINDOW WASHER/WIPER
AUTOMATIC WINDSHIELD WIPER
HEATED WASHER JETS-W'SHIELD
LESS BUMPER MOULDING - REAR
BODY COLOUR RR BUMPER END CAPS
FRT BMP-PLASTIC-BODY COLOR
REAR BUMPER - SELF COLOR
RESTRAIN DEVICE PACK 1
AIR CURTAIN LH LEVEL 6
AIR CURTAIN RH LEVEL 6
LESS RR SEAT SIDE AIRBAG RESTR
ACTIVE SEAT BELTS-FRONT
REAR SEAT BELTS-2ND/3RD ROW
DRIVER SEAT AIR BAG RESTRAINT
PASS SEAT AIR BAG RESTR
SEAT BELT-BLACK
LESS ISOFIX HARD POINT ATTACH.
LESS SPARE WHEEL
TIRE PRESSURE SENSORS-433 MHZ
6.5X16 ALUM PTD 7SPK WHL
205/60R16
LESS WHEEL COVERS
LOCKING WHEEL LUG NUT
MARKET ROAD CONDITION-GENERAL
LESS BLOCK HEATER RECEPTACLE
STARTER - STOP/START SYSTEM
EURO 6.2 EMISSIONS
POWER 4-WHEEL DISC
COLLISION MITIGATION SYS #2
EMERGENCY BRAKE LIGHT FLASHING
BRAKES-HLA/ESP/TC/ABS
LESS TRACKING SYSTEM-FIA
FRONT LIP SPOILER - FIA
LESS FLOOR MATS - DIO
LESS REMOTE STARTER-DIO/FIA
MANUAL SHIFT AUTO ECO MODE
LESS RR COMPT DUCT
LESS RR SEAT CLIMATE CONTROL
POLLEN FILTER W/O CARBON FLTR
PTC HEATER
A/C REFRIGERANT-HF01234YF
LESS LABEL-A/C CHARGE
DIESEL FUEL CAPABILITY
LESS GASEOUS FUEL PREP PACK
STEERING WHL-4 SPK LEATHER
LESS ELECTR SPEED LIMITATION
SPD CNTRL-INTLLGNT SPD ASSIST
LESS SPD CTL DISTANCE SENSING
HIGH SERIES ANALOG CLUSTER
KPH SPEEDOMETER
TRIP COMPUTER
ECO COACH
TIRE INFLATION MONITOR
LESS COMPASS DISPLAY
MFD TFT TOUCH SCREEN W/ NAV
NAVIGATION CENTER
DRIVER IMPAIRMENT MONITOR
LESS BLIND SPOT INFO SYSTEM
LANE KEEPING AID
SPEED SIGN RECOGNITION
ENGINE IMMOBILIZER'SECURILOCK'
REVERSE PARKING AID
FRONT PARKING AID
LESS AUTOMATED PARKING SYSTEM
HEAVY DUTY BATTERY
STANDARD DUTY ALTERNATOR
LESS POWER CONVERTOR
LESS AUXILIARY COMPACT DISC PL
ICE-5TH CH/TMC/DAB/PD
ICE FEATURE PACK 9
DIVERSITY ANTENNA
UNBRANDED ICP/MINI EFP
MICROPHONE
SYNC III
LESS WIRELESS CHARGING
ELECTRICAL OUTLET #2
12 AUX POWER POINT IN I/P
LESS POWER POINT PLUG - REAR
REAR VIEW CAMERA-FIXED
LESS SPARE WHEEL PACK
LESS CADS PACKAGES
OVERHEAD POD 1
AUTO HEADLAMPS-FOLLOW ME HOME
HALOGEN HEADLAMPS
LESS HEADLAMPS - WIPER ACTIVTD
FRONT FOG LAMPS
HEADER MNT COURTESY/2 MAPLIGHT
LESS GLOVE BOX LIGHTS
LESS LOAD COMPARTMENT LIGHT
REAR FOG LAMPS
AUTOMATIC HEADLAMP ON/OFF
LESS PRGRAMBLE INTERFACE MDULE
LESS WIRING HARNESS
FROZEN WHITE
GERMANY
jeffe
Mesajde danoct » 05 Feb 2024, 11:18
Buna ziua. Ma puteti ajuta cu o lista de dotari? - WF0AXXWPMAKL31711
Multumesc frumos.
danoct
Maşina: Ford Kuga 1.5 Ecoboost 4x4
Mesajde jeffe » 05 Feb 2024, 12:43
DETAILED VEHICLE SPECIFICATION - WF0AXXWPMAKL31711
DESCRIPTION 2019 Kuga - BS (C520 EU)
PRODUCTION DATE 2019/05/16
VEHICLE LINE Kuga 2013-
FUEL TYPE GASOLINE
BODY CAB STYLE Sport Utility Vehicle
VERSION/SERIES SERIES 57
ENGINE 1.5L EcoBoost 16V (180PS)
TRANSMISSION 6 Speed Auto Trans 6F35 (IND=A)
DRIVE TYPE 4 WHL L/H PART TIME DRIVE
AXLE RATIO 3.51 FINAL DRIVE RATIO
AIR CONDITIONING DUAL ZONE AUTO TEMP CONTROL AC
TIRE SIZE 235/55R17 7.5JX52.5
BUILD INFORMATION
FRT DR STAINLESS STEEL PLATES
ACC MEDIA HUB 2XUSB+AV+SD SLOT
LESS INTERIOR PACK
105.9IN CAR WHEELBASE
LESS SPLASH SHIELD-TRANSF BOX
LESS STAR RATING PERF LEVEL
MY KEY
LIFTGATE - POWER
LESS PARK LOCK CTRL (BTSI MOR)
LESS UNDERFLOOR STOWAGE
BASE PAYLOAD PK
FORD CORPORATE BADGE
4950 GVW
LESS SALES BADGE
EXTERIOR APPEARANCE - LEVEL 2
MARKETING LEVEL 1
LESS DRESS UP RSO
LESS SVP
LESS EXCEPT EAO SVP
LESS MEMORY PACKAGE
FEATURE CONTENT GROUP 2
LESS PAINT PACKAGE
2016 JOB #1 PROGRAM CONTROL
NAMEPLATE
NORMAL TEMP ZONES
LESS UTILITY PACKAGE
LESS TAILGATE BADGES
LESS WATER WADING EQUIPMENT
LESS LOCAL PLANT PROCESS
LESS MARKETING DESIGN EXT PACK
LESS MARKETING FAMILY PACK
PARKING PACK #4
MARKETING TECHNOLOGY PACK #1
MARKETING WINTER PACK #1
JACK-STANDARD MECHANICAL
LESS WARNING DISPLAYS
WINDOW AUTO CLOSE
PWR REAR 1 SHOT UP/DOWN WINDOW
PRIVACY GLASS
GRILLE-UPPER BARS PTD LT SLVR
WINDOWS-FRT SD STANDARD GLASS
CONSOLE ASHTRAY
MINI OVRHD CNSL W/SUNGLASS BIN
CONSOLE-FLOOR-FULL W/ ARMREST
INT ENVIRN COLOR-CHRCOAL BLACK
INT FEAT COLOR-CHARCOAL BLACK
REAR THROW IN CARPET FLR MATS
DELUXE HEADLINER
SUNVISOR,SINGLE-DRV ILLUM
SUNVISOR,SINGLE-PASS ILLUM
DOOR HANDLES-INSIDE ALUMINUM
LOAD COMPART. TIE DOWN LOOPS
LESS CARGO COMPARTMENT NET
LOAD FLOOR CARPET
LESS INTERIOR PARTITION
GRILLE-LOWER BARS DK SELF CLR
RF RACK-SILVER PAINTED RAILS
ROCKER PANEL MLD-SELF COLOR
BRIGHT EXT.DOOR FRAME MOLDING
LESS LOWER B/S MLDG
LESS REAR SPOILER
DU PWR/HEAT/FOLD/PUD LMP/SIG
LESS FRONT HEADRESTRAINTS
DRIVER SEAT RECLINER-LEVER
SEAT TRACK MOUNT COVERS
LUMBAR SEAT SUPT-PASS SEAT
DRIVER HEATED SEAT
SEC ROW 60/40 (3 P)-EASY ENTRY
MANUAL 6-WAY DRV SEAT ADJUSTER
MANUAL 6-WAY PASS SEAT ADJUST
LESS TRAILER TOWING PACKAGE
FRONT TOWING HOOKS
REAR TOWING HOOKS
LEATHER GEAR SHIFT KNOB
LESS DOOR LOCK SHIELDS
REMOTE DECK/TAILGATE RELEASE
AUTOMATIC GEARSHIFT
FREQUENCY - 433 MHZ
POWER DOOR LOCKS
DR EN REM CNT UNIT-SPECIAL SYS
KEYLESS ENTRY/START/TAILGATE
INTERMITTENT RR WND WASH/WIPE
RAIN SENSITIVE W'SHLD WIPERS
LESS HEATED WASHER JETS
HEADLAMP WASHER
TONNEAU COVER
BUMPER MOULDING-FRONT MIC
BUMPER MOULDING-REAR MIC
LESS FRT BUMPER SENSOR DEVICE
FRT BMP-PARTIAL BODY COLOR
REAR BUMPER-PLASTIC-BODY COLOR
LCNS PLATE HOLDER LARGE RECTAN
BLT/D&P FRT/1&2 ROW/D KNE BAG
KNEE PROTECTION-EU/OS GEOMETRY
LESS RR SEAT BELT PRE-TENSIONR
LESS SENSOR - OCCUPANT
LESS BELTMINDER
TETHER ANCHORAGE RESTR-STYLE 1
SPARE WHEEL-MINI STEEL
17 X 7.5 ALLOY WHEEL STYLE 4
235/55R17 7.5JX52.5
LIMIT SER/MINI SPARE TIRE
WHEEL HUB CAPS-PLASTIC PAINTED
CENTER HUB ORNAMENT-FORD OVAL
RADIATOR SHUTTER-KYSOR
COMP UNIQUE FOR ALLOY WHLS
FRAME FUEL FILTER-HVY DUTY
STARTER EQUIPMENT (-29C)
LESS REMOTE STARTER
EURO 6.2 EMISSIONS
NO POS SEL FROM THIS FAMILY
NO POS SELECT FROM THIS FAMILY
DUAL BRIGHT HORZ PIPE
PARKING BRAKE - ELECTRIC
STD DUTY FRT/RR CALP & PADS
REAR BRAKE - DISC
LESS COLLISION MITIGATION SYS
LESS CITY SAFETY
BRAKES-TS/HLA/ESP/TC/ABS
EXPORT FUEL FILL
LESS LUGGAGE COMPNT MAT-FIA
LESS CROSSBARS/RACKS-FIA
LESS SPLASH GUARDS-DIO
GEAR SET N/A ALL AUTO TRANS
SLCT SHF TECH (SST) W/THM SWTC
SEAT-INDIVIDUAL H/B DRV/PASS
REAR DUCT / B-PILLAR
POLLEN/CARBON FILTER
HEATED STEERING WHEELS
SPEED CONTROL & ASLD
CONVENTIONAL INSTRUMNT LEVEL 3
INSTRUM CLUSTER-RHEOSTAT
KPH SPEEDOMETER
TRIP COMPUTER
TIRE INFLATION MONITOR LVL II
COMPASS DISPLAY
NAVIGATION CENTER
EMERGENCY ASSISTANCE
LESS DRIVER IMPAIRMENT MONITOR
LESS SPD AUDIBLE WARN DEVICE
LESS LANE KEEPING AID
LESS SPEED SIGN RECOGNITION
REVERSE PARKING AID
FRONT PARKING AID
ADVANCED AUTOMATED PARK SYSTEM
VOLTAGE REGULATOR-12V SOCKET
LESS A/V JACK
ICE-MID AUDIO BRANDED +DAB+TMC
ICE FEATURE PACK 15
ICP/MINI EFP
9 RADIO SPEAKERS
SYNC III
ELECTRICAL OUTLET #1
HIGH INTENSITY DISCHARGE H/LMP
DTRL LAMP LIT IN POS 0 AND POS
HEADLAMPS-DYNAMIC BENDING
FRONT FOG LAMPS
INTR LGHT-AMBINT LED/MULTI CLR
LESS FLOORWELL LIGHTS
GLOVE BOX LIGHTS
TAILLAMPS - LED REAR
AUTOMATIC HEADLAMP LEVELING
AUTOMATIC HEADLAMP CONTROL OFF
EAO MARKET DERIVATIVE
DIFFUSED SILVER
LESS GENERIC COUNTRY GROUPINGS
ROMANIA
jeffe
Mesajde danoct » 05 Feb 2024, 12:58
Multumesc pentru raspuns. Pentru o corecta interpretare, am o intrebare. Acolo unde este specificat "LESS..." sa inteleg ca acea dotare lispeste? Multumesc.
danoct
Mesajde jeffe » 05 Feb 2024, 15:30
Da, exact
jeffe
Mesajde tm72pai » 12 Feb 2024, 22:25
Buna seara,
Ma poate ajut cineva cu detalii ptr o masina cu VIN WF0RXXGCDRCE05698.
Multumesc anticipat.
tm72pai
Maşina: Ford Kuga
VIN: WF0RXXGCDR8L87316
Mesajde lowenkonig » 17 Feb 2024, 16:47
WF0KXXGCBKCG64354
lowenkonig
Mesajde jeffe » 17 Feb 2024, 17:47
$1 scrie:$2una seara,
VIN-ul este incorect
jeffe
Mesajde jeffe » 17 Feb 2024, 17:49
DETAILED VEHICLE SPECIFICATION - WF0KXXGCBKCG64354
DESCRIPTION 2012 Focus - B8 (C346 EU)
PRODUCTION DATE 2012/04/10
VEHICLE LINE Focus 2011-2015
FUEL TYPE GASOLINE
VERSION/SERIES SERIES 40
PLANT OF MANUFACTURE SAARLOUIS PLANT BUILD
ENGINE 1.0L GTDI 12V TC(100PS)
AXLE RATIO 4.25 FINAL DRIVE RATIO
TIRE SIZE 215/50 X 17" W RATED BSW TYRE
BUILD INFORMATION
LESS ROOF REINFORCEMENT
FRT DR SCUFF PLATES-FORD OVAL
ACCESSORY MEDIA HUB 1XUSB
LESS INTERIOR PACK
HILL LAUNCH ASSIST
REAR PASSENGER DOOR
LESS MY KEY
LIFTGATE - MANUAL
LESS SECURITY LOCK GROUP
MARKETING FLEX PREP PACK 12
MARKETING FLEX PREP PACK 15
MARKETING FLEX PREP PACK 23
LESS SALES BADGE
MARKETING LEVEL 1
LESS DRESS UP RSO
LESS SVP
LESS EXCEPT EAO SVP
NORMAL TEMP ZONES
ECONETIC TAILGATE BADGE
LESS MASS CUSTOMIZATION PACKAG
LESS FIRE EXTINGUISHER FIXINGS
KIT-ENHANCED TIRE REPAIR SVC
LESS IN VEHICLE BIKE CARRIER
WINDOW AUTO CLOSE
GRL-UPPER BLK MSH/CHROME SURND
LESS CONSOLE ASHTRAY
LESS TEMP CONTROLLED GLOVE BOX
PADDED DASH
CONSOLE-WITH CLOSED BIN
LESS REAR FLOOR CONSOLETTE
LESS GENERAL STOWAGE BOX
LESS SUN BLINDS
DELUXE HEADLINER
L/H FRONT DOOR ARMREST
R/H FRONT DOOR ARMREST
GRAB HANDLE DRIVE SIDE-FOLDING
LESS STOWAGE BINS
REAR COAT HOOK
LESS CARGO NET KIT
CARGO AREA COVER
LESS LOAD COMPARTMENT LOOPS
LESS DECKLID/LIFTG/TAILG LINER
LOAD FLOOR CARPET
LESS FIRST AID RETAIN STRAPS
LESS ROOF BIKE CARRIER
LESS FRONT GRILLE
GRILLE-LOWER SURR HGH GLS CHRM
LESS ROOF RACK
LESS EXTERIOR BODYSIDE MLDGS
ROCKER PANEL MLD-CLADDING C/K
LESS DOOR EDGE GUARDS
LESS AUX ROOF RACK CROSSBARS
REAR SPOILER
PASS SEAT RECLINER-ROTARY
LESS SEAT TRACK COVERS
LESS SEAT SPECIAL COVERS FRONT
LESS SEAT SPECIAL COVERS-REAR
FOLDING REAR SEAT CUSHION-SPLT
RR SEAT-60/40 SPLIT-FOLDING
REAR HEADRESTRAINT-INTEGRATED
RR CENTER ARMREST WITH STOWAGE
LESS TEMP CONTROL DRIVER SEAT
LESS TEMP CONTROL PASSNGR SEAT
FRONT TOWING HOOKS
REAR TOWING HOOKS
LESS DRIVER DOOR TRUNK RELEASE
LESS TRAILER SWAY CONTROL
LESS ENGINE RELATED BADGE
ENGINE COVER - UNDER HOOD
LESS SECOND REMOTE IGN KEY
LESS DOOR AUTO RELOCKING
POWER DOOR LOCKS
KEYLESS START
CAPLESS FUEL FILLER W/O LOCK
HEADLAMP WASHER
LESS ROOF OPENING PANELS
LESS TONNEAU COVER
FRNT BUMPER-PAINTED BODY COLOR
LESS KNEE PROTECTION
3 PT SEAT BELT- EUROPN REGULTN
LESS SPARE WHEEL
LESS TIRE PRESSURE SENSORS
STANDARD DUTY REAR SHOCK ABS
7J X 17 STYLE 5 ALLOY WHEEL
LESS SPARE TIRE
LESS TIRE VENDOR
LESS WHEEL COVERS
LESS WHEEL SPEED SENSOR
LESS FRAME MNTD FUEL FILTER
LESS IMMERSION HEATER
STAGE V EMISSIONS
SINGLE EXHAUST SYSTEM
LESS HANDBRAKE GRIP
PARK BRK-MECHANICAL HAND OPER
REAR BRAKE - DISC
CITY SAFETY-MODE 1
LESS RR BMPR PROT APPL-FIA
LESS RR COMPT DUCT
LESS AIR PURIFICATION SENSORS
FUEL TANK SMALL
NON LOCKING CAPLESS FUEL FILL
LEAD/UNLEADED FUEL CAPABILITY
FIXED FOOT PDLS
LESS PARK HEATING
KPH SPEEDOMETER
TRIP COMPUTER
ECOMODE
LESS INSTRUMENT GAUGES
DUAL NOTE ELECTRIC HORN
LESS TIRE INFLATION MONITOR
MFD NAV LOW TFT SCREEN
MESSAGE CENTER
LESS NAVIGATION DISK
LESS SEC NAVIGATION DISK
NAV DATA - WESTERN EUROPE
LESS EMERGENCY SYSTEM
LESS EMERGENCY ASSISTANCE
BIS W/RADAR-BLIS/CAN LED
LANE KEEPING AID
REVERSE PARKING AID
FRONT PARKING AID
LESS SIDE PARKING AID
LESS RADIO HOUSING
LESS A/V JACK
ICE- MID AUDIO (1C) W/CNECTVTY
ICE FEATURE PACK 11
ICP NAV
6 RADIO SPEAKERS
LESS RADIO SUBWOOFER
LESS TELEPHONE PREP PACK
LESS MOBILE OFFICE PACK
LESS FAMILY ENTERTAINMENT SYST
LESS MEDIA GATEWAY MODULE
LS COLUMN STALK RADIO CONTROLS
LESS ELECTRICAL OUTLET
LESS CAMERA
LESS COOL BOX
LESS STYLE PACK
LESS COMFORT PACK
FOG LAMP BEZEL-CHROME
FRONT FOG LAMPS
LESS FRT DOOR EDGE WARN LAMPS
LESS RR DOOR EDGE WARN LAMPS
HEADLAMP BEZEL-ALUMINUM
FLOORWELL LIGHTS
FRT INDIVIDUALA AND RR MAP LTS
FRONT AND REAR LAMP LED
LESS RR OVERHEAD READING LAMPS
GLOVE BOX LIGHTS
LESS AUX INTERIOR LIGHTS
SINGLE REAR FOG LAMPS
AUTO HIGH LAMP HEADLAMP
LESS ACCESSORY-PACKAGES
RED CANDY TINT CC
OUTSIDE AIR TEMP PRESENT
NETHERLANDS
jeffe
Mesajde iavramescu » 19 Feb 2024, 12:27
Buna ziua! Ma puteti ajuta va rog si pe mine cu detalii despre WF0PXXGCHPLC82801? Multumesc anticipat!
iavramescu
Mesajde jeffe » 19 Feb 2024, 20:31
DETAILED VEHICLE SPECIFICATION - WF0PXXGCHPLC82801
DESCRIPTION 2020 Focus - GE (C519 EU)
PRODUCTION DATE 2020/05/19
VEHICLE LINE FOCUS (C519E)
FUEL TYPE GASOLINE
BODY CAB STYLE 4 Door Estate
VERSION/SERIES SERIES 12
ENGINE 1.5L Dragon
AXLE RATIO 4.056 FINAL DRIVE RATIO
TIRE SIZE 215/55 R17 94H
BUILD INFORMATION
FRT DR SCUFF W/LOGO
ACC MEDIA HUB 2XUSB+AU+SD SLOT
LESS STALL APPLY
DRIVE AWAY RELEASE
LESS INTERIOR PACK
FRONT LOAD BAR
REAR PASSENGER DOOR
MY KEY
POWER LIFTGATE W/HANDS FREE
LESS EXTERIOR PROTECTION GROUP
TERRAIN PACK-STANDARD DUTY
A-LINE SALES BADGE
MARKETING LEVEL 1
LESS SVP
LESS EXCEPT EAO SVP
NAMEPLATE
NORMAL TEMP ZONES
LESS SAFETY PACK
MARKETING COMFORT PACK #1
LESS MARKETING ITEMS
LESS MKT PERFORMANCE PACK
LESS MARKETING TECHNOLOGY PACK
WINDOW AUTO CLOSE
GRILLE - UPPER HONEYCOMB
PADDED DASH
MED LENGTH OVERHEAD CONSOLE
INT ENVIRON COLOR-EBONY
FRNT FLR MATS-VELOUR W/O LOGO
GENERAL STOWAGE BOX
HEADLINER-CONVENTIONAL
SUNVIS-DRV VINYL W/MIRR INSERT
SUNVIS-PASS VINYL W/MIRR INSRT
REAR COAT HOOK
LESS LOAD REST
LESS CARGO NET KIT
LOAD FLOOR CARPET
GRILLE-LOWER - BLACK MESH
ROOF RACK WITHOUT CROSSBARS
ROCKER PANEL MOLDING-FULL
LESS EXTERIOR DOOR FRAME MLDGS
REAR SPOILER
FRONT 4-WAY HD RESTNT ST 1
CONTRAST STITCHING #2
LUMBAR SEAT - 4 WAY DRIVER
LUMBAR PASS - 4 WAY
DRIVER HEATED SEAT
RETRACTABLE TRAILER COUPLING
FRONT TOWING HOOKS
REAR TOWING HOOKS
POWER DOOR LOCKS
KEYLESS ENTRY/START-PASSIVE
DAL-DEF OFF-NOT CUST CONFIGUR
LESS HEADLAMP CLEANING
TONNEAU COVER
BODY COLORED PAINTED ROOF
FRT BMPR-B/COL PLASTIC+GRILLE
BUMPER EXTENSION-FRONT-VP
REAR BUMPER-PLASTIC-SPORT
RR BUMPER EXTENSION-BODY COLOR
RR ST BLT-2ND ROW ACTIVE OUTBD
17X7" PAINTED ALUMINUM WHEEL
215/55 R17 94H
WHEEL HUB CAPS - BLACK
STANDARD TREAD-ANY VENDOR
2ND ROW BEZELS
EURO 6.2 EMISSIONS
HIGH RIDE SUSPENSION
LESS PERFORMANCE ED/PKG
REAR SUSPENSION - LEVEL 2
SPORT TUNED EXHAUST
LESS HANDBRAKE GRIP
REAR BRAKE - DISC
3.583/1.95/1.29/0.97/0.77/0.65
LESS MAN SHIFT AUTO TRANS
REAR FLOOR DUCTS
FIXED FOOT PDLS
INTELLIGENT SPEED ASSISTANCE
CONVENTIONAL INSTRUMNT LEVEL 2
KPH SPEEDOMETER
TRIP COMPUTER
ECO COACH
NAVIGATION CENTER
MESSAGE CENTER
AECS NO SMS/ROLL DETECT 2G
LANE KEEPING AID
LESS WRONG WAY ALERT
REVERSE PARKING AID
FRONT PARKING AID
ALTERNATOR - ECO INNOVATION
ICE-SCD DUAL/5TH CH/TMC/DAB/PD
ICE FEATURE PACK 47
ICP/MINI EFP
6 RADIO SPEAKERS
CELLPHONE INTERFACE SYSTEM 4
SYNC III
LESS CAMERA
LESS STYLE PACK
LESS OPTIONAL EQUIPMENT PACK
LESS HEAD UP DISPLAY
FOG LAMP BEZEL-BLACK
LED REFLECTOR LAMP
FRNT FOG LMPS- LED ADPTVE CORN
HEADLAMP BEZEL-BLACK
GLOVE BOX LIGHTS
TAILLAMPS-LEVEL 1
LESS PARKING BRAKE WARN LAMP
DESERT ISLAND BLUE
NETHERLANDS
jeffe
Mesajde catalinRDV » 22 Feb 2024, 21:52
As dori sa aflu dotarile masinii cu VIN WF0NXXGCHNRB75194. Cand am facut comanda am avut headup display inclus intr-unul din pachetele optionale, dar intre timp Ford Romania a scos din oferta headup display-ul.
Multumesc,
Catalin
catalinRDV
Mesajde tm72pai » 23 Feb 2024, 12:12
Da, ai dreptate am incurcat niste cifre WF0RXXGCDRCE05968.
tm72pai
Maşina: Ford Kuga
Mesajde jeffe » 23 Feb 2024, 17:43
DETAILED VEHICLE SPECIFICATION - WF0NXXGCHNRB75194
DESCRIPTION 2024 Focus - GE (C519 EU)
PRODUCTION DATE 2024/01/31
FUEL TYPE GASOLINE
VERSION/SERIES SERIES 13
ENGINE 2.3L 4V TI-VCT DI TC Gas
TRANSMISSION AUTO TRANS - 8F40 (IND=A)
AXLE RATIO 2.89 FINAL DRIVE RATIO
AIR CONDITIONING FULLY AUTO TEMP CONTROL A/C
TIRE SIZE 235/35 R19 91Y
BUILD INFORMATION
FRONT SCUFF PLATES - SILVER
ACCESSORY USB UNIT W/IPOD FUNC
MY KEY
LIFTGATE - MANUAL
STANDARD SERVICE CONTRACTS
ST SALES BADGE
LESS SVP
LESS EXCEPT EAO SVP
2022 JOB #1 PROGRAM CONTROL
LESS CARLINE BADGES
NORMAL TEMP ZONES
LESS SVO MARKETING PACKS
LESS MARKETING BUSINESS PACK
PARKING PACK #1
WINDOW AUTO CLOSE
PRIVACY GLASS
GRILLE-UPPER PAINTED
CENTRE CONSOLE-LEVEL 5
FRT FLR MATS W/DOUBLE STICHING
REAR FLR MATS W/ DBLE STITCHNG
GENERAL STOWAGE BOX
SPORTS DARK HEADLINER
REAR COAT HOOK
CARGO AREA COVER
LOAD FLOOR CARPET
GRILLE-LOWER DARK
LESS ROOF RACK
ROCKER PANEL MLD-SPORT
DOOR EDGE GUARDS
REAR SPOILER-PERFORMANCE PLUS
FRONT INTG NON-ADJ HDRESTNTS
POWER DRIVER SEAT RECLINER
POWER PASSENGER SEAT RECLINER
RED STITCHING
RR SEAT-60/40 FOLD W/SKI HATCH
LUMBAR PASS - 4 WAY
DRIVER HEATED SEAT
POWER 6-WAY DRIVER SEAT ADJUST
POWER 6-WAY PASS SEAT ADJUST
FRONT TOWING HOOKS
REAR TOWING HOOKS
ROTARY GEAR SHIFT KNOB
POWER DOOR DEAD LOCKS
LESS TONNEAU COVER
RR BMPR-SPORTY (BDY COLOR)
RR BUMPER EXTENSION-PTD ACCENT
SPARE WHEEL-17 MINI STEEL
STYLE 8 ALLOY 8J X 19 INCH
235/35 R19 91Y
17" MINI-SPARE TIRE
ECO TREAD - ANY VENDOR #3
LESS PARTITIONING BEZELS
DRIVER ASSISTANCE PACKAGE #2
REMOTE STARTER
EURO 6.2 EMISSIONS
PERFORMANCE SUSPENSION
DU EXH W/O RESONATORS
BRAKE CALIPERS-RED
BRAKES-ABS/ESP W/ELCT BRK BOST
4.6/3.3/3/2.4/1.9/1.4/1/.7/.61
SLCT SHF TECH (SST) W/PADL SHF
INDIVIDUAL PREMIUM-DRV/PASS
FIXED FOOT PDLS
FOOTPEDALS-UNIQUE METALLIC FIN
STRG WHEEL - SPORT LEATHER
ADP SPD CNTL AND TRAFFIC JAM
FULL TFT/LCD INSTR CLUSTER
KPH SPEEDOMETER
EFFICIENT DRIVE MODE
MFD HIGH TFT SCREEN
NAVIGATION CENTER
BLIS W/CTA W/TRAILER LITE
LANE CHANGE WARNING AND AID
WRONG WAY ALERT
PERIMETER /VOLUME THEFT SYSTEM
REVERSE PARKING AID
FRONT PARKING AID
STOLEN VEHICLE RECOVERY SYSTEM
CROSS TRAFFIC BRAKE ASSIST
ICE FEATURE PACK 70
BASIC ICP
10 HIGH SERIES RADIO SPEAKERS
CELLPHONE INTERFACE SYSTEM 5
SYNC IV
WIRELESS CHARGING
2 POWER POINT PLUGS - REAR
REAR VIEW CAMERA - LEVEL 2
FOG LAMP BEZEL-COLOR KEYED
ADAPTIVE DSS HEADLAMP
LESS FRONT FOG LAMPS
INTERIOR LIGHTING-AMBIENT LED
FLOORWELL LIGHTS
GLOVE BOX LIGHTS
AUTO HIGH LAMP GLARE FREE H/L
MAGNETIC
ROMANIA
LESS SPLASH GUARDS
LESS MRKT CB-A/C & AUX HEATER
LESS MK CB-FLR MAT/FLR COV
LESS ACCESSORY WHEELS
LESS WINDOW DEFLECTORS
LESS CARGO MAT
LESS CARGO MATS - SECOND SET
LESS CAMERA OFFERING
LESS ILLMINTED GEAR SHIFT KNOB
LESS DEALER ACCESSORY 8
LESS DEALER ACCESSORY 9
LESS DEALER ACCESSORY 11
LESS DEALER ACCESSORY 12
jeffe
Mesajde jeffe » 23 Feb 2024, 17:46
DETAILED VEHICLE SPECIFICATION - WF0RXXGCDRCE05968
DESCRIPTION 2013 Kuga - BV (C394 EU)
PRODUCTION DATE 2012/08/22
VEHICLE LINE Kuga 2008-2012
FUEL TYPE DIESEL
VERSION/SERIES SERIES 55
ENGINE 2.0L Duratorq CR TC (136PS) -
TRANSMISSION 6 Speed Manual Transaxle - MMT (IND=M)
AXLE RATIO 4.533/3.238 FINAL DRIVE RATIO
TIRE SIZE 235/50 R18 V
BUILD INFORMATION
ROOF CONV-PANORAMA ROOF
FRT DOOR SCUFF PLATE
LESS CARGO STOWAGE DEVICE
FRT FENDER GILL-BRIGHT
LESS INTERIOR PACK
LIFTGATE - WITH FLIP UP GLASS
UNDERFLOOR STOWAGE
CONVENIENCE GROUP #9
MARKETING FLEX PREP PACK 19
MARKETING FLEX PREP PACK 21
MARKETING FLEX PREP PACK 36
LESS SALES BADGE
LESS DRESS UP RSO
TITANIUM UPGRADE SIP
LESS SAFETY PACKS
LESS EXCEPT EAO SVP
KUGA BADGE
LESS INTERACTIVE VEHICLE DYNAM
NORMAL TEMP ZONES
LESS BODY STYLING KIT
WINDOW AUTO CLOSE
PRIVACY GLASS
WINDSHIELDING HEAT SHIELDING
LESS RUN FLAT SYSTEM
PADDED DASH
OVERHEAD CONSOLE-HIGH SERIES
INT ENVIRON COLOR-DARK FLINT
ANTI ALLERGIC INTERIOR
LESS FLOOR COVERING-PASS
LESS SUN BLINDS
DELUXE HEADLINER
LESS INTR GRAB HANDLE SIDE DR
FOLDING FRT ROOF ASSIST HANDLE
FOLDING RR ROOF ASSIST HANDLE
LESS CARGO NET KIT
LESS LOAD FLOOR COVERING
PAINTED GRILLE
LESS GRILLE MOLDING
HOOD ORNAMENT
ROOF RACK - CHROME
LOWER BODYSIDE/CLADDING
DUAL PWR/HEAT/FOLD/PUD LAMP MR
LESS STOWAGE-REAR SEAT BACK
TRAY/TABLE - FRONT SEAT
RR CENTER ARMREST W/ CUPHOLDER
DRIVER HEATED SEAT
MANUAL 4-WAY PASS SEAT ADJUST
LESS REAR SEAT PACKS
LESS CHILD PROOF RR DOOR LOCKS
PWR DR DEAD LOCK + ELEC REL
KEYLESS START
TONNEAU COVER
LESS BUMPER MOULDING - FRONT
BUMPER INSERT-BODY COLOR
FRT BUMPER-PLASTIC-GRAY
REAR BUMPER-GREY PLASTIC
LESS RR BUMPER LOAD PROTECTOR
LESS TETHER ANCHORAGE RESTR
LESS TIRE CARRIER
STYLE 1 ALLOY 7.5J X 18" WHEEL
235/50 R18 V
LESS WHEEL COVERS
STAGE V EMISSIONS
REAR BRAKE - DISC
BRAKE-EMERGENCY ASSIST
3.583/1.952/1.241/0.868/0.943
SEAT-SPORT-DRV/PASS
FIXED FOOT PDLS
SPEED CONTROL
INSTR CLUST-LIGHT WAKE-UP SEQ
KPH SPEEDOMETER
TRIP COMPUTER
LESS NAVIG SYSTEM SPEED LOCK
REVERSE PARKING AID
FRONT PARKING AID
LESS SOLAR CELL
LESS RADIO PRE-EQUIPMENT PACK
RDS RADIO INFORMATION DECODER
A/V JACK
DUAL BAND ANTENNA
ICE-NAV LOW CD+AM/FM RADIO
ICE FEATURE PACK 133
6 RADIO SPEAKERS
BRITISH LANGUAGE MODULE
SHIFT INDIC LIGHT
LESS CAMERA
LESS STYLE PACK
LAMP COLOR-CLEAR
PROJECTOR BEAM HEADLAMPS
FRONT FOG LAMPS
AMBIENT LIGHTING-INTERIOR
FLOORWELL LIGHTS
SUBMARINE LIGHTING-INTERIOR
GLOVE BOX LIGHTS
REAR FOG LAMPS
LESS COURTESY LIGHT
BRISBANE BROWN
BELGIUM
jeffe
Mesajde tm72pai » 23 Feb 2024, 20:46
[quote="jeffe"][size=85]DETAILED VEHICLE SPECIFICATION - WF0RXXGCDRCE05968
Multumesc, oricum vad ca e 4x2 iar vanzatorul zicea ca e 4x4
Imi permit sa va ma deranjez cu un VIN WF0AXXWPMAHM84441.
tm72pai
Maşina: Ford Kuga
Mesajde jeffe » 24 Feb 2024, 07:16
DETAILED VEHICLE SPECIFICATION - WF0AXXWPMAHM84441
DESCRIPTION 2017 Kuga - BS (C520 EU)
PRODUCTION DATE 2017/03/27
FUEL TYPE DIESEL
VERSION/SERIES SERIES 66
ENGINE 2.0L Duratorq-TDCi (132kW/180P
TRANSMISSION 6 Speed Powershift 6DCT450 - M (IND=M)
AXLE RATIO 4..533/3.091 FINAL DRIVE RATIO
EMISSIONS EURO 6 EMISSIONS
TIRE SIZE 235/50 R18 VS SST
BUILD INFORMATION
FRT DR SCUFF W/LOGO
LESS INTERIOR PACK
MY KEY
LIFTGATE - POWER
UNDERFLOOR STOWAGE
4950 GVW
MARKETING FLEX PREP PACK 8
MARKETING FLEX PREP PACK 14
MARKETING FLEX PREP PACK 38
LESS SALES BADGE
MARKETING LEVEL 1
FULL DRESS UP RSO
LESS SVP
LESS EXCEPT EAO SVP
LESS MEMORY PACKAGE
FEATURE CONTENT GROUP 8
LESS PAINT PACKAGE
NAMEPLATE
NORMAL TEMP ZONES
WINDOW AUTO CLOSE
PRIVACY GLASS
GRILLE-UPPER BODY COLOR
FRT FLR MATS-RED PIPING
RR FLR MATS-RED PIPING
LOAD FLOOR CARPET
GRILLE-LWR SELF CLRD BLK, CHRM
ROOF RACK - BLACK
ROCKER PANEL MLD-BODY COLOR
BLACK EXT.DOOR FRAME MOLDING
LOWER PAINTED CLADDING
DRIVER HEATED SEAT
FRONT TOWING HOOKS
REAR TOWING HOOKS
LEA GR SH KB W/UNIQUE FINISH A
AUTOMATIC GEARSHIFT
FREQUENCY - 433 MHZ
POWER DOOR LOCKS
HEADLAMP WASHER
TONNEAU COVER
BUMPER MOULDING-FRONT BLACK
BUMPER MOULDING - REAR BLACK
REAR BMPR-BDY CLR/CHROME INSER
LESS BELTMINDER
18X7.5" ALUM WHL - UNIQUE PNT
235/50 R18 VS SST
LESS REMOTE STARTER
EURO 6 EMISSIONS
DU EXH OLET W/TAILPIPE GARNISH
REAR BRAKE - DISC
CITY SAFETY-MODE 1
EXPORT FUEL FILL
3.583/1.952/1.194/.829/.943/.7
FOOT PEDAL DESIGN-ALUMNM SVT
STRG WHL-LEATHER W/GREY STITCH
KPH SPEEDOMETER
TRIP COMPUTER
COMPASS DISPLAY
NAVIGATION CENTER
BLIND SPOT DETECTION 2
LANE KEEPING AID
REVERSE PARKING AID
FRONT PARKING AID
HEAVY DUTY BATTERY
LESS A/V JACK
ICE-MID AUDIO +TMC
ICE FEATURE PACK 12
ICP/MINI EFP
6 RADIO SPEAKERS
SYNC III
FRONT FOG LAMPS
FLOORWELL LIGHTS
GLOVE BOX LIGHTS
TAILLAMPS-LEVEL 1
MAGNETIC
FRANCE
jeffe
Mesajde LongingIngernot » 25 Feb 2024, 09:13
Va pot deranja si eu cu o serie de sasiu? WF0AXXWPMAHB44100
LongingIngernot
VIN: WF0AXXWPMAHB44100
Mesajde jeffe » 28 Feb 2024, 08:58
DETAILED VEHICLE SPECIFICATION - WF0AXXWPMAHB44100
PRODUCTION DATE 2017/05/13
FUEL TYPE DIESEL
ENGINE 2.0L Duratorq (110kW/150PS)
BUILD INFORMATION
LESS INTERIOR PACK
MY KEY
LIFTGATE - MANUAL
UNDERFLOOR STOWAGE
4950 GVW
LESS SALES BADGE
MARKETING LEVEL 1
LESS DRESS UP RSO
LESS SVP
LESS EXCEPT EAO SVP
LESS MEMORY PACKAGE
FEATURE CONTENT GROUP 1
LESS PAINT PACKAGE
NAMEPLATE
NORMAL TEMP ZONES
WINDOW AUTO CLOSE
WINDOWS-FRT SD LAMINATED GLASS
LESS ELECT WINDSHIELD DEFROST
FRONT FLOOR MATS-VELOUR
REAR FLOOR MATS-VELOUR
DELUXE HEADLINER
LOAD FLOOR CARPET
LESS ROOF RACK
LESS LOWER B/S MLDG
LESS REAR SPOILER
DU PWR HTD SIGNAL MIRR'S
FRONT TOWING HOOKS
REAR TOWING HOOKS
AUTOMATIC GEARSHIFT
FREQUENCY - 433 MHZ
POWER DOOR LOCKS
TONNEAU COVER
LESS BELTMINDER
235/55R17 7.5JX52.5
LESS REMOTE STARTER
EURO 6 EMISSIONS
REAR BRAKE - DISC
LESS CITY SAFETY
EXPORT FUEL FILL
LESS HEATED STEERING WHEELS
SUPPLEMENTAL AIR HEATER
KPH SPEEDOMETER
TRIP COMPUTER
COMPASS DISPLAY
LESS REVERSE PARKING AID
HEAVY DUTY BATTERY
LESS A/V JACK
ICE FEATURE PACK 6
ICP/MINI EFP
6 RADIO SPEAKERS
SYNC III
LESS CAMERA
HALOGEN HEADLAMPS-NAS
HEADLAMPS - UNIQUE
FRONT FOG LAMPS
GLOVE BOX LIGHTS
TAILLAMPS-LEVEL 1
MOONDUST SILVER C/C MED SOLID
ITALY
jeffe
Mesajde Oboseala » 29 Feb 2024, 16:37
Salutari! A fost o surpriza placuta sa descopar serviciul pe care Jeffe il ofera aici pe forum legat de VIN. Am tot incercat sa gasesc un loc unde pot verifica o masina pe care intentionez sa o cumpar si ma bucur sa vad acest thread.
Daca se poate o verificare si pentru mine te rog: WF0FXXWPMHLD24256
Astept mesaj cu detalii despre cum pot sa dau o bere/suc. Vorbesc serios!
Multumesc frumos
Oboseala
Mesajde japkone30 » 23 Mar 2024, 11:41
Ma puteti ajuta cu date despre masina ce urmeaza sa o achizitionez WF0EXXWPCEJR04663. Va multumesc.
japkone30
VIN: WF0EXXWPCEJR04663
Mesajde adip1962 » 27 Mar 2024, 17:34
Salut Jeffe!
Am revenit si eu pe site dupa ce mi-am vandut FF2-ul din 2010. Buna masina a fost!
Doar ca mi-am luat acum alta, un mk4 cu VIN-ul:WF0NXXGCHNLS80478.
Poti sa mi-l decodezi, te rog? Mai ales ma intereseaza ce cutie automata am... Mecanicul meu personal - care mi-e prieten de atatia ani - mi-a zis ca nu a vazut niciodata asa ceva.
Pana si motorul este cumva diferit de cel normal de 2000...
Iar pagina de etis unde intram si eu odata... nu mai este!
Multumesc mult.
PS. Dar tu parca nu mai aveai niciun ford sau gresesc?
[i]Am avut 8 masini. Am condus multe altele. Dintr-un motiv total necunoscut, Focus imi place cel mai mult, asa ca am recidivat si sunt la al 3-lea. Si ultimul...[/i]
adip1962
Maşina: Focus 4 Titanium, 1995 Ecoblue, 150cp, 8+1 viteze
VIN: WF0NXXGCHNLS80478
Mesajde nevyan » 01 Apr 2024, 10:01
Ma poate ajuta si pe mine cineva cu o fisa pentru : WF04XXGCC4HR03915
nevyan
Maşina: Ford Focus II 1.4
VIN: WF05XXWPD57M79033
Mesajde dani27ro » 23 Apr 2024, 21:36
ma ajuti si pe mine cu niste informatii cu privire la masina cu vin WF0GXXGBBGBJ79734
mersi mult
dani bodor - Ford MondeoMk4 2011 InkBlue - Bihor
[img]http://clubford.ro/public/6.jpg[/img]
dani27ro
Localitate: Marghita, Bihor
Maşina: Ford Mondeo mk4 Ink blue
VIN: WF0GXXGBBGBJ79734
Mesajde anerbota » 25 Apr 2024, 11:07
Buna
Ma puteti ajuta si pe mine in legatura informatii despre VIN: WF0PXXGCHPKD06761
Mersi mult
anerbota
Mesajde lbanias » 02 Mai 2024, 22:18
Va rog o decodare pentru WF04NBER74RG55726 , e Transit Courier nou de serviciu si as fi curios ce extrase are.
2001 Focus Turnier Futura TDDI 90 CP
lbanias
Mesajde AnnaCrap » 07 Mai 2024, 19:22
Avem o problema cu Fordul achizitionat sh acum 1 an. Va rog sa imi spuneti ce gasiti pe eTis despre masina. VIN: WF0HXXGAJH8R25897
AnnaCrap
