Dig Mileage Unlocker
Mesajde Alex_Alimpie » 16 Aug 2007, 12:09
$1 scrie:$2lex_Alimpie ti-e iti arata consumul?
Mie deobicei nu imi arata consumul deci e varianta la care nu imi arata niciunde consumul si defapt asta as dori sa pot face sa mil arate!
Ford Modeo 2011 MK4 2.0 TDCI 140 HP Powershift!
Alex_Alimpie
Maşina: Ford Modeo 2011 MK4 2.0 TDCI 140 HP Powershift
Mesajde FordFIESTA » 21 Aug 2007, 16:11
zic eu computeru isi face media de consum dar o arata in cati KM mai ai de parcurs cu benzina din rezervr
FordFIESTA
Maşina: Ford fieSTa
VIN: WF0HXXGAJH6B38113
Mesajde matei.virgil » 23 Aug 2007, 01:55
Sper sa ajute: - le-am gasit pe un site englez
Test Syntax Displayed Gauge/Indicator/Display Tested Description
1. Gauge sweep GAGE Tachometer, speedometer, temperature and fuel. All gauges go through a full up and down pointer sweep smoothness check, which takes approximately 5 seconds.
2. Fill in all LCD 8888 LCD display built into Speedometer. Fills in LCD display therefore seeing if display functioning correctly.
3. Indicator bulbs BULB Instrument cluster illuminates indicator and warning indicators Illuminates all the warning indicators that are controlled by the instrument cluster.
4. ROM level rXXX Instrument cluster read only memory (ROM) Displays the instrument cluster ROM revision level.
5. NVM level EXXX Instrument cluster non volatile memory (NVM) Displays the instrument cluster NVM revision.
6. DTC XXXX or NONE Diagnostic trouble codes (DTCs) To list the DTCs stored, press the RESET button. REFER to the instrument cluster diagnostic trouble code (DTC) index. The DTC codes will scroll through if there is more than one.
7. Road speed mph XXX.X Speedometer Displays the speed signal input in mph.
8. Road speed Km/h XXX.X Speedometer Displays the speed signal input in Km/h.
9. Engine speed XXXX Tachometer Displays the tachometer input signal (RPM).
10. Fuel volume FXXX Fuel sender system Displays the fuel volume signal input.
11. Engine coolant temperature XXXC Engine coolant temperature Displays the engine coolant temperature signal input.
12. Battery voltage bXXX Battery Voltage (t) Displays battery voltage input.
13. ABS fail Ab-[H/L] ABS system. Displays ABS raw cluster input. (H = over-charging or battery, L = ground).
14. Electronic brake distribution (EBD) failure Eb-[H/L] EBD system. Displays EBD raw cluster input. (H = over-charging or battery, L = ground).
15. Illumination. IL-[H/L] Cluster and instrument panel illumination. Displays instrument cluster and instrument panel illumination. (H = ON, L = OFF).
16. Crank Sense Cr-[H/L] Cluster and instrument panel crank sense. Displays Cluster and instrument panel Crank sense. (H = Ignition, L = Ground or over-charging).
Ford Fiesta - o masina FORDmidabila!
matei.virgil
Localitate: Cisnadie
Maşina: Ford Fiesta Comfort 1.25i
Mesajde ripperu » 23 Aug 2007, 09:29
bine, bine
dar da-ne si noua linkul
ripperu
Localitate: San Pedro de la Paz, Region VIII, Bio-Bio
Maşina: Focus Trend Collection, 1.8 TDCi - 115CP, Hatchback, Ocean Blue
VIN: nu_mai_bine_bere_
Mesajde matei.virgil » 23 Aug 2007, 12:09
$1 scrie:$2ine, bine
OK! :roll:
Nu stiu la ce te-ar putea ajuta link-ul, pentru ca acolo sunt aceleasi informatii.
Oricum trebuie sa-ti faci cont ca sa poti sa citesti mesajele si pe deasupra nici nu mai stiu exact unde l-am gasit. :?:
http://www.ukfiestanetwork.com/ - sper sa reusesti sa gasesti mesajul pentru ca nu mai stiu unde era (sigur la sectiunea New Fiesta).
matei.virgil
Mesajde matei.virgil » 23 Aug 2007, 12:10
Si inca ceva - - - am incercat eu - vedeti ca sunt decalate unele dintre ele - spre exemplu de la 4 pana la alea cu viteza mai sunt cateva in plus!
matei.virgil
Mesajde mercenarul » 09 Sep 2007, 14:37
ma intereseaza si pe mine afisajul consumului, etc la un Mondeo Tdci din 2003. sunt novice in materie de tehnica, spuneti-mi ce trebuie sa fac ca sa activez C.B.Momentan nu imi indica decat temperatura exterioara.Masina nu este in garantie asa ca dati-mi sfaturi putin costisitoare.
mercenarul
Mesajde mariush » 10 Sep 2007, 21:58
salut!
a reusit careva sa inteleaga tot ce indica acel computer de bord?!
ma refer la acele masini kre nu au CB activ, si nu numai...
Ford Fiesta 1,3 8V 60CP - 2004
mariush
Localitate: Craiova
Maşina: Ford Fiesta,2004,1,3,60CP.
VIN: WF0HXXGAJH3P42999
Mesajde 4focus » 08 Oct 2007, 14:02
nu marius,si vad ca mie imi mai apar valori in plus
si vad ca nimeni nu prea stie exct tot ce inseamna
sa speram ca pana la urma o scoatem la capat
numa bine!
4focus
Mesajde kevyn_str8 » 08 Oct 2007, 15:48
alte chichite mai cunoasteti care tine de orice model ford?
FORD FOCUS 1.8 TDDI 90 CP
FORD FOCUS 2.0 TDCI 136 CP
kevyn_str8
Mesajde kevyn_str8 » 11 Oct 2007, 11:53
si la mine merge am incercat ieri ,dar sunt multe valori care nu stiu ce e cu ele
kevyn_str8
Mesajde xdocx » 11 Oct 2007, 12:05
$1 scrie:$2i la mine merge am incercat ieri ,dar sunt multe valori care nu stiu ce e cu ele
si la mine la fel
xdocx
Mesajde ripperu » 11 Oct 2007, 20:09
la mine apare uneori (in loc de TEST)
SHIPPING MODE:
ON / OFF
nu nimeresc mereu combinatia
trebuie sa apas de vreo 2-3 ori pe ambreiaj pina la fund
ripperu
Mesajde dzamars » 01 Noi 2007, 19:27
Stie cineva si cum se poate salva setarile? Adica, daca eu vreau sa ramana doar pe vitezometru digital de ex chiar si dupa ce opresc motorul, pot face ceva ?
Ford Focus Hatchback, 1.6i 101 CP, 2001.
http://www.fordreporter.com
dzamars
Maşina: Ford Focus, 2001, Hatchback 5usi, 1.6i 101CP
Mesajde alecsutzu » 02 Noi 2007, 11:46
nop....
http://www.casa-galbena.com
alecsutzu
Proud Fiesta Owner
Localitate: Radauti
Maşina: Fiesta 1.6TDCi 90CP
Mesajde Adrian75PAB » 02 Noi 2007, 16:39
$1 scrie:$2erge pe orice ford cu afisaj electronic, deasemenea mergi si pe alte marci cum ar fi logan, renault, seat etc
salut... eu am incercat pe un chevrolet aveo si nu merge... ai idee daca se procedeaza altfel?
mersi
fiesta 1.3i 60cp, 2002 diamond white.
focus 1.4i 16v 80cp, trendstyle, red tango sau tango metalic
Adrian75PAB
Mesajde horatzyu004 » 08 Noi 2007, 16:14
vroiam sa va intreb si eu. am masina de aproape 1 luna jumate si mi s-a intamplat de 3 ori pana acum, si anume: cand pun contactul se duc toate indicatoarele la maxim (adik vitezometrul la 220, turometrul la 7000 si indicatorul la benzina la maxim si tot asa). stau acolo vreo 2 secunde si isi revin la normal, dupa care pornesc motorul normal...
ce sa fie ? motiv de ingrijorare ??
mi se intampla asta fara sa apas pe niciun buton sau ceva... asa pur si simplu cand pun contactul
pls help
Ford Focus 2001, motor 1,8 TDDI 90 hp
horatzyu004
Localitate: Craiova
Maşina: Ford Focus 2001, 1.8 TDDI, 90 cai
Mesajde ripperu » 08 Noi 2007, 21:29
foarte interesant!
exact ca in TEST
ripperu
Mesajde horatzyu004 » 08 Noi 2007, 21:31
$1 scrie:$2oarte interesant!
exact ca in TEST
incercai si eu azi ..dar nu imi merge sa fac "testu"
cand apesi butonu ala trebuie sa fie pus contactul sau cum ?
nu reusii...
horatzyu004
Localitate: Craiova
Mesajde ripperu » 09 Noi 2007, 13:42
exact ca in TEST
nu reusii...
trebuie sa urmezi pas cu pas instructiunile de aici:
http://www.focushacks.com/index.php?modid=37
ripperu
Mesajde horatzyu004 » 09 Noi 2007, 23:31
nu merge.
dar ti-am zis ca inainte sa incerc, sau macar sa aflu de asta...... cand pun contactu se reseteaza kilometrajul mic si se duc acele la maxim... ce naiba are ? ca ma enerveaza ca se reseteaza.... sa nu fie vreo problema ceva..
horatzyu004
Localitate: Craiova
Mesajde ripperu » 10 Noi 2007, 09:17
mda
nu e normal
trebuie sa mergi in service cu ea
n-ai incotro
ripperu
Mesajde stdanm » 11 Noi 2007, 17:29
la mine nu am reusit.... fiesta 2007, tdci, fara comp de bord :(
fac in felul urmator (va rog sa ma corectati daca gresesc ceva):
apas ambreiaj, scot din viteza (tin in continuare apasat pe ambreiaj), apas pe buton, invart cheia in poz 1, poz 2 (toti timpul asta tin apasat ambreiaj si butonul), poz 3, porneste motorul, mai stau cu toate apasate, si tot degeaba... :(
stdanm
Localitate: Bucuresti, Nord
Mesajde horatzyu004 » 11 Noi 2007, 22:11
$1 scrie:$2a mine nu am reusit.... fiesta 2007, tdci, fara comp de bord :(
asa fac si eu la a mea si nu imi merge.
fiesta de la semnatura..
horatzyu004
Localitate: Craiova
Mesajde alexx_gan » 12 Noi 2007, 01:04
La chestia cu test am incercat-o si eu si intradevar nici la mine nu s-au resetat km mici da mi-a mai aparut un beculetz care nu se aprinde cand pun conatctu esp si nu am nici buton de activare-dezactivare esp ....oare am esp pe masina...cum pot sa imi dau seama?
FIESTA 1.3i -60 CP -2003
alexx_gan
Localitate: Vaslui
Maşina: Ford Fiesta 1.3I - 2003 -60 Cp
Mesajde alexx_gan » 12 Noi 2007, 01:05
alexx_gan
Localitate: Vaslui
Mesajde horatzyu004 » 22 Noi 2007, 22:28
$1 scrie:$2da
nu e normal
n-ai incotro
am rezolvat problema. era din cauza bateriei. era de 6 ani si nu mai avea putere... dea aia cand puneam contactul se dadeau acele cu capul de pereti si se reseta km mic.
acum am pus baterie noua si problema a disparut.
treaba e ca nu pot sa ajung la "testul" ala. am incercat si nu imi intra acolo
horatzyu004
Localitate: Craiova
Mesajde mihai_florescu_09 » 24 Noi 2007, 22:40
am incercat si eu. merge si la mine. doar ca ce am citit pe aici k trebuie sa se duca acele la maxim la mine nu se intampla si am mai mult de 16-17 chestii pe acolo...trebuie sa ma uit e posibil sa am o eroare ceva. e tare k acum vad si eu temperatura de afara
cu aproximatie pt ca este mai cald motorul deci cu 1 grad 2 mai mare imi arata
mihai_florescu_09
Mesajde FordFIESTA » 25 Noi 2007, 01:41
temperatura de afara (reala) poti sa o vezi cand e motorul rece dar dupa ce ii dai drumu creste foarte repede
FordFIESTA
Maşina: Ford fieSTa
Mesajde mihai_florescu_09 » 25 Noi 2007, 15:37
mda ... am obs k de fapt aia e temp lichidului de racire a motorului
mihai_florescu_09
Utilizatorii ce navighează pe acest forum: Daniel29 şi 8 vizitatori
În total sunt 9 utilizatori conectaţi :: 1 înregistrat, 0 invizibili şi 8 vizitatori (date care se bazează pe utilizatorii activi în ultimele 5 minute)
