Golire instalatie racire Ka
Mesajde adicristea » 24 Mar 2008, 22:04
Va rog sa ma ajutati, pas cu pas daca se poate, cu ordinea operatiilor pentru a schimba lichidul de racire la Ford Ka. Acum am alt lichid decat cel care trebuie, unii dintre cei care au fost la intalnire au vazut. Am cumparat antigel rosu si as vrea sa fac eu schimbarea. Ma puteti ajuta, va rog?
PS. Am TIS 2004, dar la sectiunea Cooling System Draining, Filling and Bleeding (241220) apare "1. Information not available at this time."
adicristea
Localitate: Reading, UK
VIN: 00000000000000000
Re: Golire instalatie racire Ka
Mesajde adicristea » 25 Mar 2008, 14:11
Ok, am gasit pe un forum cateva informatii. Le adaug aici, poate e si altcineva interesat de operatia asta. Mai trebuie sa specific ca eu NU am gasit buşonul la radiator. Daca ma poate ajuta cineva cu o informatie, e binevenit.
$1 scrie:$2rain
1. WARNING:
When releasing the system pressure, cover the coolant expansion tank cap with a thick cloth to prevent the
possibility of coolant scalding.
Relieve the cooling system pressure.
Unscrew the coolant expansion tank cap slowly.
2. Remove the coolant expansion tank cap.
3. Raise and support the vehicle. For additional information, refer to «Section 100-02».
4. Remove the radiator undershield.
5. Remove the radiator drain plug.
Drain the coolant into a suitable container.
6. Refit the radiator drain plug when all coolant has drained.
7. Install the radiator undershield.
8. Lower the vehicle.
Refill
1. Note:
For vehicles with a diesel engine, it is necessary to add a further one litre of coolant above the MAX mark to make
sure that the correct level is achieved after the system degasses.
Refill the coolant expansion tank to the MAX mark.
2. Start the engine and run until normal operating temperature is achieved. Check for coolant leaks and add coolant
if necessary.
adicristea
