a demontat cineva gratarul de aer al bordului
Mesajde sictiritu » 17 Iul 2006, 13:37
Adica alea doua din mijloc...Problema ar fi ca tre' sa le dau jos sa-mi recuperez o placuta de-aia mica, se pare ca a cazut inauntru
multzam
Mondeo nov.2003,TDCI 130HP, 6SP
sictiritu
Localitate: Oradea
Mesajde OvidiuB » 21 Iul 2006, 17:05
si eu am aceeasi problema, si nu as merge in service pentru atata, dar nici nu mi-as baga degetele aiurea, ca nu ma pricep.
dar eu am focus
2003 FF1 Turnier 1.8 TDDI 90CP
2008 FF2 Turnier 1.6 TDDI 109CP
OvidiuB
Localitate: Bucuresti / Ploiesti
Maşina: FF1 Tournier TDDI, 90CP/2003 + FF2 Tournier TDCI, 109CP/2008
Mesajde sictiritu » 22 Iul 2006, 21:46
E relativ simplu...vb de Mondeo, dar cred ca Ford pastreaza principial acelasi sistem. Eu am fortat in lateral cu o surubelnita, am lasat doar o zgarietura fina...Placutza nu am mai recuperat-o, a cazut undeva in tevile de aer.
Am mai demontat inca o data dar de data asta fara surubelnita. L-am pus pe pozitia sa bata in jos si am fortat cu mana in partea superioara. Greu, dar am reusit si asa. In principiu, din cate mi-am dat seama, asta este metoda, fara surubelnita
sictiritu
Localitate: Oradea
Mesajde ffocus » 02 Aug 2006, 11:55
Side/Corner Vents
Insert a butterknife on the underside of the vent. push-n-pry until you hear a "pop", that's one clip undone. Now, grab onto the vent, and put the knife on the side of the vent closest to the center of the dash. now push-n-pry until you hear another "pop", that's 2 clips. now just pull up and out (towards the door).
The Main Vents
Insert a butterknife underneath of the bottom side of the vent and pull up. Then pull on the vent. You will hear a 'snap', but that's just the clips popping out of place. Once you have that out, you'll have to remove the actual vent from the circle. Just pull on the black vent portion and it will pop out. Now, the little vent aimer thingy, it's inserted between 2 plastic pieces that makes it able to spin in a direction. pop the directioner thing out. You will see what I mean when you do it. Then you will haev to remove the circle from the vent tube. there are 4 clips (2 at the top and 2 at the bottom). Unclip, and pull on the circle.
Magnum Grey 2006 Mondeo TDCI / 115cp
225x40x18" / -30 mm Eibach
ffocus
Localitate: 44°24'49"/26°05'48"
Maşina: 2006 Ford Mondeo 2.0 TDCI 115cp
VIN: WFO4XXGBB45E13841
