Urgent-Cine poate sa-mi spuna ???
Mesajde cal » 14 Mai 2007, 22:40
Cine stie daca pe Ford Fusion se pot pune jante cu urmatoarele caracteristici ???
dimensiune 16 inches
distanta intre prezoane 108 mm x 4 prezoane
latimea 7J
ET 25
Am nevoie de sfat urgent...nu stiu cum e cu et-ul ala...din ce stiu eu restul ar fi beton
cal
Localitate: HDDistrict
Maşina: FFC-max 2.0d ghia+ BMW 320cd E92
Despre ET
Mesajde Maddogul » 15 Mai 2007, 06:52
Nu stiu exact la Fusion da pot sa-ti spun ca la Fiesta Et este 38 si merge si 40
Insa 25 este ET de Peugeot :D
You'll notice it reads "6J x 14 H2 ET45". The "6J x 14" part of that is the size of the wheel rim - in this case it has a depth of 6 inches and a diameter of 14 inches (see the section directly below here on wheel sizes for a more in-depth explanation). The "J" symbolises the shape of the mounting surface of where the tyre sits. This runs around the front and back of the wheel rim. You may have noticed that some wheels have a "JJ" description; this is mainly on 4x4s as the tyre can be held on more securely with a double mating face.
The "H2" means that this wheel rim is designed to take "H" speed-rated tyres. The "ET45" figure below that though symbolises that these wheels have a positive offset of 45mm. In other words, they have an inset of 45mm. In my case, the info is all stamped on the outside face of the wheel which made it nice and easy to photograph and explain for you. On most aftermarket wheels, they don't want to pollute the lines and style of the outside of the wheel with stamped-on information - it's more likely to be found inside the rim, or one one of the inner mounting surfaces.
Cu Stima
Mondeo MK2 '98 2.0 130Cp '97
Maddog Garage
Maddogul
Maşina: Fiesta Mk5 1.7 VCT
VIN: WF0FXXGAGFRA56025
Mesajde cal » 15 Mai 2007, 09:52
10x, se pare ca nu pot sa le cumpar fara sa le probez
[size=50][color=#FF0000][b]......[/b][/color][/size]
cal
Mesajde ff-ghia-136 » 15 Mai 2007, 23:08
pai de ce sa le cumperi fara sa le probezi?
FF.2.GHIA.2.0 TDCI 136.CP SEDAN.ARGINTIU
ff-ghia-136
Warned
