probleme esp , motor , airbag audi tt
Mesajde lokoom » 31 Ian 2011, 22:16
salut , ma poate ajuta cineva?
am scanat cu vag com si mi`a dat urmatoarele erori:
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Control Module Part Number: 8L0 906 018 Q
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 11500
Work Shop Code: WSC 01236
Additional Info: TRUZZZ8NZ11037074 AUZ5Z0A2062156
5 Faults Found:
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
17938 - Shareware Version. To Decode all DTCs
P1530 - 35-00 - Please Register/Activate
17697 - Shareware Version. To Decode all DTCs
P1289 - 35-00 - Please Register/Activate
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
16396 - Shareware Version. To Decode all DTCs
P0012 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Control Module Part Number: 8N0 907 379 D
Component and/or Version: ESP 20 CAN V006
Software Coding: 23049
3 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
01423 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
01434 - Shareware Version. To Decode all DTCs
57-10 - Please Register/Activate - Intermittent
Address 15: Airbags Labels: None
Control Module Part Number: 8N8 909 601
Component and/or Version: Airbag Front+SeitE 2008
Software Coding: 10102
Work Shop Code: WSC 51454
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
va rog daca imi puteti da o explicatie la toate
lokoom
Maşina: ford escort
Re: probleme esp , motor , airbag audi tt
Mesajde mac01 » 31 Ian 2011, 23:25
cred ca ai gresit forumul.daca era un ford atunci poate gaseai ceva.
cauta la vag.acolo sigur afli raspunsuri.
cu respect.
mac01
Mesajde lokoom » 31 Ian 2011, 23:29
da stiu , am postat si acolo dar nu pot deschide un nou topic , si nu ma baga mai nimeni in seama , speram sa gasesc aici raspunsul
lokoom
Maşina: ford escort
Mesajde Alin! » 31 Ian 2011, 23:36
Nu vreau sa fiu rautacios dar cam cat de mult vrei sa fii bagat in seama cu un AUDI pe un forum de FORD?!?!
Vinde TT-ul de fitze, cumpara un ford de familie si mai vorbim...;)
Focus Fanatic
Alin!
Localitate: Vaslui
Mesajde lokoom » 31 Ian 2011, 23:39
pai acolo am posta de ieri si mi`a raspuns doar 2 si aici am postat de vreo 2 3 ore si m`au bagat 2 in seama , si dupa parerea mea daca este vreun mecanic bun pe aici nu stie doar ford , daca nu .. asta este :D
lokoom
Maşina: ford escort
Mesajde marilyn.m » 04 Feb 2011, 21:20
rai mai sunteti...
nu cred ca o sa gasesti vreun raspuns aici...mai bine incearca si pe forumul de la skoda, motorul tau e si pe octavia.
Si incearca sa citesti codurile si in alt service. Cel care ti-a citit ce ai postat tu aici nu are o versiune activata de vag com.
marilyn.m
Localitate: Ploiesti
Maşina: 2003 Mondeo TDDI
Mesajde bricy » 04 Feb 2011, 21:43
Din ce vad eu acolo sunt unele probleme (care pentru noi) nu au legatura una cu alta, insa un inginer cu experienta ii poate da de capat.
Spre exemplu un prieten a avut un passat 1.8T care mergea prost, consuma mult si nu-i mergea abs-ul si esp-ul si care la testere expirate (la care vad k ai apelat si tu) nu-i dea nici o eroare, insa cand s-a dus la reprezentanta i-a zis clar; debitmetru.
Stiu k suna aiurea dar dupa ce i la schimbat totul a revenit la normal. Bine si pretul a fost pe masura, dar cel putin a rezolvat-o.
Daca ai fi de prin sau langa Bacau as stii sa te indrum la cineva bun.
Cel mai bine nu te zgarcesti, faci un efort si o duci la reprezentanta, macar sa iti spuna ce are.
Off, cineva a supus k e masina de fite; daca ai merge si tu cu un astfel de motor, nu ai mai avea parerea asta.
bricy
Localitate: Tecuci
VIN: WF0NXXGCDN1P72637
Mesajde adyamg » 04 Feb 2011, 22:22
adyamg
Maşina: Ford Focus 1.6 Zetec
Mesajde Alin! » 05 Feb 2011, 07:39
$1 scrie:$2Off, cineva a supus k e masina de fite; daca ai merge si tu cu un astfel de motor, nu ai mai avea parerea asta.
Eu am spus ca e masina de fite!!! Atunci ce parere as avea, ca e masina normala...ca iti poti lua familia la o plimbare prin oras, iar soacra si copiii ii bagi impreuna cu poseta nevestei, in portbagaj?!...asta daca iti mai ramane loc.Si ce legatura are motorul?!
Cum adyamg a gasit atatea forumuri cu audi si alte minumi putea cauta si el daca avea vointa...
Focus Fanatic
Alin!
Localitate: Vaslui
