Eroare p0098
Eroare p0098
Mesajde Daniel Pris » 12 Dec 2013, 18:58
Am un focus c-max din 2005 16 diesel 109 cp. Am o problema: in unele momente cand o accelerez nu se accelereaza normal are intreruperi. Iar la viteze de 160-170 se aprinde martorul la motor iar a doua zi dispare. Am pus-o pe tester si imi da eroarea de mai sus
Daniel Pris
Re: Eroare p0098
Mesajde Smiley » 12 Dec 2013, 21:19
P0098 Ford - Intake Air Temperature Sensor 2 Circuit High Voltage
Possible causes
- Faulty Intake Air Temperature sensor
- Intake Air Temperature sensor harness is open or shorted
- Intake Air Temperature sensor circuit poor electrical connection
The Engine Control Module (ECM) has detected a high voltage condition on the Intake Air Temperature (IAT) circuit.Possible symptoms- Engine Light ON (or Service Engine Soon Warning Light)P0098 Ford DescriptionThe Intake Air Temperature (IAT) sensor contains a semiconductor device which changes the resistance based on the temperature (a thermistor). The IAT sensor is located in the air intake passage of the engine air induction system. The IAT sensor has a signal circuit and a ground circuit.
Focus C-Max Ghia 2.0 TDCI
Smiley
Re: Eroare p0098
Mesajde turbojack » 12 Dec 2013, 21:33
Beton.
Se verifica temperatura de aer in parametri.Posibil doar probleme cablaj-mufe . Altceva decat erori nu se poate cauta pe testerele astea ? Se consuma curentul degeaba .
Daca apar -40 grade si cablajul e ok, se schimba debitmetru. Un fleac de vre-o 400-500 lei . De vizat unul ( bosch,pierburg,vdo siemens;pe altceva dati banii degeaba ) .
turbojack
Localitate: CJ
Re: Eroare p0098
Mesajde biking2 » 30 Aug 2018, 12:19
Se verifica se fie inchis pe ambele parti capacul la filtru aer,altfel se te umplii de erori gen turbo defect.
biking2
Localitate: iasi
Maşina: Ford Focus 2 facelift
VIN: WFOSXXGCDS9P22309
